Old 08-17-2007, 06:17 PM   #1
vulpina
Member#: 131903
GC8 PPG EJ25 GT3082
dark blue 95H
Default BCS , 2 way or 3 way iam lost .
Hi all ,
I would like to get the prodrive BCS , everyone says it is so good , the only problem is my GC8 originally use a 2 way BCS , is there an easy way to use the prodrive one ?
What difference with 2 or 3 way BCS ?
vulpina is offline   Reply With Quote
Old 08-18-2007, 01:09 AM   #2
ironhead1230
Member#: 66419
2008 STI
Read through the following. They should answer your questions.
http://forums.nasioc.com/forums/showthread.php?t=870619
http://www.tarmacwolf.org/dokuwiki/d...boost_solenoid
Here is a detailed description from Cobb of how the stock boost control system works.
http://www.cobbforums.com/forums/ima...mWorksv109.pdf
These should have all the answers you need.
-Mike
ironhead1230 is offline   Reply With Quote
Old 08-18-2007, 09:53 AM   #3
CynicX
Member#: 48199
06 WRX
Originally Posted by vulpina View Post
Hi all ,
All Subarus have 2 port BCS. The reason people go with a Prodrive or GM BCS is because its 3 port. If you look at that link thats posted from Cobb, scroll all the way to about 3/4 maybe a little bit more. There are 2 diagrams of the difference between 2 port and 3 port....
This is something that needs tuning. It wont run right if you install a Prodrive 3 port BCS without tuning and adjustments...
CynicX is offline   Reply With Quote
Old 08-18-2007, 12:01 PM   #4
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
that cobb article is a good read....just finished it
geddesk2 is offline   Reply With Quote
Old 08-18-2007, 09:05 PM   #5
vulpina
Member#: 131903
GC8 PPG EJ25 GT3082
dark blue 95H
Thanks,
from what i understand ,the 3 way BCS allow for better boost controlling , i know it will need lower wastegate duty cycle .
Iam runing 24 psi on the stock BCS , i hope the Prodrive one will be an imrpovement
WTB: 2 ohms or 3.3 ohms RESISTOR HighOctaneMan Private 'Wanted' Classifieds 18 07-14-2009 01:12 PM
Morel's 2-way or 3-way and how? SilentShadow Car Audio, Video & Security 14 11-26-2005 06:35 AM
2-way or 3-way speakers? clsmooth Car Audio, Video & Security 10 08-13-2005 08:15 PM
Exhuast Pipe 2, 2.5, or 3 inch? StealthfishWRX Newbies & FAQs 4 07-30-2005 05:43 PM
2-way vs 3-way speakers pio!pio! Car Audio, Video & Security 3 05-29-2002 04:40 AM
