#1 |
Member#: 25195
SCIC
Vehicle:2007 STI |
I have an 07sti , Up until recently the car was running like a champ. However about a 2 weeks ago I was driving aggressively, and I missed the shift from 2 to 3rd. The car was on the rev limiter for no more than 2 seconds. Immediately after doing so, the car was still fine. After parking the car for about an hour, I went to drive home and noticed that boost in all gears was limited to about 7-8 psi. Went home checked to hoses and everything was fine so I reset the ecu and took it out for a spin. The car acted normal again, and boost was hitting target ranges.
All was going well for about 150 miles when I started to drive hard again. I went from a 4 to 3rd downshift but accidentally shifted into 2nd. I caught it in time and had not even fully released the clutch, but I am pretty sure I caught the rev limiter. Once again, after parking the car for 3-4 huors, I got in the car to drive home and boost once again was limited to about half of what it normally hits in all gears. Got home, reset the ecu and all if fine again.... What is going on? Any thoughts? I am worried b/c 07' STI's seem to be having all sorts of problems.
#2 |
Member#: 143391
Vehicle:2007 WRX TR R.I.P Colin! :( |
#3 |
Member#: 86356
I've never head of this before, but if you go from 4 to 2 and overrev the motor, the rev limiter won't stop it from revving past redline.
#4 |
Member#: 25195
SCIC
Vehicle:2007 STI |
On the 4 to 2 mishift, I knew almost instantly and I don't think I ever fully got off the clutch, so if I overreved, maybe it was for a second at the most. I will just have to take it easy and drive like a granny I suppose, but the ecu should not be going into limp mode from a single incident like this should it?
#5 |
Member#: 151683
im wondering how on earth you mistaked 3rd for 2nd.. it sounds like valet mode after it bounces off redline, but i couldnt tell you why, just put the car in gear, quit missing and your good...
#6 |
Member#: 143391
I found out why its doing that for you.
I was right its a protection in the ECU. (From Cobbs web site) "Most critical is the fact that the ECU (on DBW vehicles) forces the boost control system to shut down completely (so the vehicle runs mechanical boost pressure) if detonation events are continuing to occur." Thats from the EBC FAQ. Its saying that your car is shutting off the EBC and going off the waist gate spring set at 7-8Psi because you are getting mad KR do to over reving the motor and toping out the fuel injectors. Thats really bad! Keep doing that and your motor will be blown in no time! I had a car brake a shift cable during my 3-4 gear change one time and I got 2nd gear at the top of 3rd. Only for 1/2 a sec and that was enough to blow my motor. You said "I'm worried about all th problems with the 07 STIs." And yet your beating the **** out of yours. I'm surprised you didn't blow the motor with what you did. Vary surprised actually. Later Last edited by Badmunky; 08-18-2007 at 10:23 PM. |
#7 |
Member#: 86356
The ECU stops listening for knock past a certain RPM, so that's not it. It could be running off wastegate spring pressure, but that doesn't seem like the reason.
#8 |
Member#: 143391
That was one posable reason. THe other that the EUC may do the same thing if it sees an over rev.
Ether way what he did was not good for that motor. Later. |
#9 | |
Member#: 25195
SCIC
Vehicle:2007 STI |
I added 104 octane booster at 1/4 tank and filled up with fresh 93 oct b/c I thought the ecu might be doing this to a bad tank of gas, but the problem is still occuring. Last edited by Varanont; 08-19-2007 at 07:35 AM. |
#10 |
Member#: 143391
Have it checked to see if it stored any codes and get back to us.
Later. |
#11 |
Member#: 48199
Vehicle:06 WRX WRB |
Seems like the solution would be stop over revving the motor. Since we all know its not good for the motor (spun bearing) there really isnt a reason to fix a problem that is occurring during an accidental misshift.
I dunno the operation of an over rev event so this is just a WAG but its pretty certain to say the ECU is shutting off the boost control and limiting you to mechanical pressures (7-8psi). This may be a built in function of the ECU during an over rev on the 2007 sti, or maybe you stayed on the gas and cause the car to over boost or something of that effect. Like I said thats just a guess though. Down shifting into the incorrect gear will mechanically over ride the rev limiter. ECU may just be trying to save the car from your driving.... ![]() Have you tried calling cobb? |
#12 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
Your Advance multiplier fell to a lower number which caused the boost system to be disabled. This happens when the car is knocking or if its banging off the rev limiter. ITs a protection feature. I really suggest you calm down and focus on making the shifts smooth. Over rev is not good for these cars.
Clark |
#13 |
Member#: 76826
NWIC
Vehicle:2013 delorean P.I.T.A. to clean silver |
limp mode dude. happens when the ecu recognizes unsafe situations within the gazillion sensors in and around your car.
learn how to drive properly, make sure you arent forcing the car past the rev limiter. Just consider the 'no-boost' situation a sign that your ECU is doing its job in protecting your 26,000 dollar investment.... kor www.myspace.com/projectalphaproductions |
#14 | |
Member#: 25195
SCIC
Vehicle:2007 STI |
#15 |
Member#: 155489
NWIC
Vehicle:07 STi |
hmmm, how many miles are you putting on a reset before you give up and reset it again? i would put a couple hundred miles on a reset and see if it sorts itself out.
#16 |
Member#: 25195
SCIC
Vehicle:2007 STI |
I just drove about 80 miles today and the ecu is still limiting boost.
#17 |
Member#: 134190
South East
Vehicle:2007 WRX-STi OBP |
take it to the dealer
#18 |
Member#: 25195
SCIC
Vehicle:2007 STI |
I bet the dealer will say, it is normal, and they cannot do anything about it.
#19 |
Member#: 143391
Try removing the Cobb tune and then reinstalling it.
See if that works. Later. |
#20 |
Member#: 25195
SCIC
Vehicle:2007 STI |
I thought it was not safe to run the car with a TBE, without some sort of EM.
#21 | |
Member#: 120057
Vehicle:2004 "Bugeye" WRB |
#22 |
Member#: 143391
#23 |
Member#: 159891
Vehicle:2007 STI Limited. Silver |
I have the same problem , but I dont beat on mine its just some mystery to me. See my thread: "07 STI boost problems". please help!!!
#24 |
Member#: 142286
this happens on my 07 lgt. i have a 5eat and after being ecutek'ed this happened to me. it happens on a 1-2 shift if i punch it. ecutek did endless data logging on my car to resolve the problem. it's been a month so far and still no answer. it shows a lean condition during the actual shift. the car hits fuel cut and then runs at 8-11 psi of boost. you're probably not resetting the ecu properly. disconnect neg. battery terminal, step on brake, and then turn ingnition to full power (don't crank motor) wait for gauges to sweep, listen for a click and then start car. this is per ecutek.
#25 |
Member#: 154959
Vehicle:04 JDM STI White |
Poopy, you forgot to reconnect the battery, gauges can't sweep without power etc.
| Thread Tools | |
| Display Modes | |
| 4EAT Occasionally Hits Rev Limiter After Launch | g00fy | Transmission (AT/MT) & Driveline | 17 | 11-28-2007 09:01 PM |
| Hitting Rev Limiter | TJRCS | Factory 2.0L Turbo Powertrain | 14 | 11-18-2004 04:12 PM |
| Hitting Rev Limiter | Rally Punx | Factory 2.0L Turbo Powertrain | 18 | 05-26-2004 01:05 AM |
| I hit rev limiter by accident. Something is wrong... | blackwrx127 | Factory 2.0L Turbo Powertrain | 19 | 05-13-2003 04:45 PM |
| Hit Rev Limiter Early ?!? | goobie | Normally Aspirated Powertrain | 6 | 05-05-2003 07:15 PM |
