Old 01-08-2002, 12:17 AM   #1
HomerJay
Member#: 1135
2005 WRX WAGON
Default Help: Loud "clunk" when backing out of garage?
My car had been sitting idle in the garage for about a week. I hopped into the car, started the engine and put the car into reverse. As I was backing out of the garage, I heard a kind of loud "clunk" sound like something was braking free. It didn't sound good. I investigated and couldn't visibly find anything wrong w/ the car, so I proceeded to back out and drive. It drove fine and I didin't notice anything. The only thing I can think of was the e-brake had gotten slightly rusty and didn't release properly. Any input would be appreciated.
-JOE
HomerJay is offline   Reply With Quote
Old 01-08-2002, 03:58 AM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Possibly the e-brake... I've had my tires stick to the floor before.
CosmoTheCat is offline   Reply With Quote
Old 01-08-2002, 08:44 AM   #3
GRWRX
Member#: 4129
2002 WRX sedan
Either the pads were breaking free from the rotors, or you left the garage door closed.
GRWRX is offline   Reply With Quote
Old 01-08-2002, 02:23 PM   #4
Jim Lewandowski
Member#: 10124
Aspen white
Default Re: Help: Loud "clunk" when backing out of garage?
-JOE
Does your clunk occur when you bounce down from the garage floor level down to the driveway level?
If so, I have the same symptom and have not figured it out yet. It's to loud for me, that I can feel it through the armrest of the passenger seat (where I have my arm when backing out).
JL
Jim Lewandowski is offline   Reply With Quote
Old 01-08-2002, 03:18 PM   #5
Tex-WReX2
Guest
Member#:
Default maybe
............you clipped Marges Canyonero? Or Barts skateboard?
Old 01-08-2002, 04:17 PM   #6
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
Aftermarket swaybar? If so then it's the endlink bolts. Happens to me ALL the time. Even if you don't have an aftermarket bar, it could still be the endlinks. Happened to the front right of a friend of mine's 01 RS.
Orion is offline   Reply With Quote
Old 01-08-2002, 07:38 PM   #7
HomerJay
Member#: 1135
2005 WRX WAGON
Thanks guys for all the input. Orionf, I didn't even think of my sway bar, and yes I do have an aftermarket one. I think it was the e-brake breaking free because it was impeding my reverse until I engaged the clutch. I figured it was but always safe to check! Thanks guys!
-JOE
(By the way, Marge's canyonero doesn't fit in the garage, don't forget, it's 2 lanes wide! )
Old 01-09-2002, 12:28 AM   #8
Jademonkey
Member#: 9213
2000 RS
Red
12 yards long, 2 lanes wide, 65 Tons of American Pride. I wish I had a garage that could fit that!
Jademonkey is offline   Reply With Quote
Old 01-10-2002, 02:05 PM   #9
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Here's something I found interesting. I too, have that loud "clunking" noise when I'm making left hand turns over bumps.
Jason
"This could be the infamous "front end clunk". Something else for you to learn about if you are new to Subarus.
In a nutshell, a clunking like noise can be produced in the front end under certain conditions. Usually, it occurs when turning across an irregularity ie: turning into a driveway etc where the wheel goes across the "little ditch" at the curb between the road and the driveway. Basically anything that makes the suspension work while turning. One doesn't have to be going fast, or even turning that sharp. Eg slow driving where right wheel goes over a slight bump at a storm sewer drain can produce it. Does this sound like what you are experiencing?
I don't think there has ever been a full resolution on this issue. Various attempts by Subaru have had various levels of success. One theory is power steering hoses (sometimes helps). Another is struts. (I had one changed, it helped, but I couldn't talk them into changing the other one.) To some degree, it is just a quirk of the car. Some have it worse than others (mine is slight - 97 OB). Overall, I haven't heard of anything failing or obviously wearing out faster as a result."
2.5GT is offline   Reply With Quote
Old 01-12-2002, 02:33 AM   #10
Foz
Member#: 1776
2000 2.5RS
BRP
I heard the same thing as well. This is the 2nd time it happened. It's a loud "CLUNK" when you have it in gear and about to drive off.
Both times happened when I haven't driven the vehicle for over 2 weeks (one in reverse, and the other going forward).
Not sure what it is, but it didn't sound nice. Nothing broken that I noticed.
Foz is offline   Reply With Quote
Old 01-14-2002, 11:51 PM   #11
HomerJay
Member#: 1135
2005 WRX WAGON
Mine doesn't ever happen while driving. Only after it rains and I've let my car sit around a week, not driven. Unfortunately, I have to drive a company car during the week and my scooby sitts and gets a little neglected. I have STI struts and springs so I've negated the possibility of that problem.
Old 02-10-2002, 06:08 PM   #12
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
This sounds to me like the e-brake pads sticking to the drums. I had similar issues with my old truck after using the e-brake after raining and letting it sit overnight. The brake shoes seize to the drums and make an awful noise when you start to move. My solution was to park on level ground in gear without the e-brake on.
Did you notice any resistance when you first starting moving your car? If your situation is the same as mine was, I wouldn't be concerned.
AnimalMother is offline   Reply With Quote
Old 02-12-2002, 09:52 PM   #13
ringer
Member#: 4121
2005 impreza obs
grey/grey
i get the same "clunk" when backing out of my garage. not all the time, but i think the the only reason it's audible is because it's bouncing off the walls into the cab. i swear mine is coming from the drivetrain somewhere. probably something in a bind when i shove it into reverse. i've had no problems from it though.
ringer is offline   Reply With Quote
Old 02-13-2002, 05:56 AM   #14
Subie Nut
Member#: 4821
2004 STI
Blue on Gold
Mine makes the exact same noise, it only does it while starting in
reverse from a dead stop, the noise happens mostly when
backing into my garage. But sometimes it will happen on level
ground. The noise is a very audible metallic "clunk" and it is not a
noise that a strut or swaybar would make.
My speculation is that it has something to do with driveline lash.
With that being said my car has 23,000 vey enthusiasticly
driven miles on it, for 16,000 of those miles the car has been
modded. I have yet to experience any issues with shifting or
abnormal noises besided the "reverse clunk". I don't feel any
need for ME to worry about the noises that MY car makes. This is
my 3rd Impreza. All of them have made one strange noise or
another and not a one of them has given me any problems.
Subie Nut is offline   Reply With Quote
Old 02-16-2002, 04:12 PM   #15
outback2.5HO
Member#: 15135
95 GF WRX
Don't rule out rear diff noise either, that is very common on these AWD beasts as well. Also the less fluid in your rear diff, the louder it will be.
outback2.5HO is offline   Reply With Quote
Old 02-20-2002, 12:12 AM   #16
DangeRS
Member#: 4579
MY01 XxNiKi
XxNiKi
Default mee too
Mine just started happening, when i start the car i get a few clunks for the clutch, like i feel pedal pulsation...and whenever i put it into first and lift up on the clutch and 2nd as well i feel one clunk...what do you think it might be?
DangeRS is offline   Reply With Quote
Old 02-20-2002, 02:11 AM   #17
Suebee2
Member#: 13669
2002 Forester
Sedona Red
Talking Source of Clunk !
Once when backing out of my garage, I clobbered a skunk, hence the noise "clunk". (and boy did it reek!)
Suebee2 is offline   Reply With Quote
Old 02-26-2002, 08:23 PM   #18
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
i hear the same clunk in my00 RS. definately sounds like its the front driver side brake. i dont see anything amiss, and it only happens once in a while from a dead stop. Once i'm out of the driveway i dont hear it again.
moogooob is offline   Reply With Quote
FS: HOU: Get out of garage BlkSubie07 TXIC Private Classifieds 6 01-12-2010 01:02 PM
Need to empty parts out of garage sale!!! 03SuBbYWrX Engine/Power/Exhaust 18 03-31-2008 09:26 PM
Need to empty parts out of garage sale!!! 03SuBbYWrX MWSOC Private Classifieds 4 01-13-2008 04:36 AM
A "clunk" when backing up? Badluckguy Warranty Issues & SOA Problems 1 04-26-2002 09:37 PM
Loud click when shifting out of 1st & 3rd... Whit Transmission (AT/MT) & Driveline 8 02-22-2002 10:09 AM
