#1 |
Member#: 156974
Vehicle:EJ20 MY 2000 Blue |
Well im new here but was told this is the place to get a bit of help with my project. Anyway as the title sais its a 2.35 im doing.
I have an EJ22T Block that has been modified to take the 79mm Phase 2 Crankshaft ive also got my ACL bearing Kit. Im about to buy a set of Wiseco OR CP 97.5mm Pistons. The part im stuck on is what Conrods to use. I was realy thinking Pauter BUT do I need custom one's for the 2.35 or is it just 79mm rods that will work ? Any help would be great. Thank you.
#2 |
Member#: 149827
Vehicle:2000 600 bhp p1 sonic blue |
iam in the process of building my 2.33 and tbh i would go for crower rods or as you say pauter
you will need these if your running 500bhp |
#3 |
Member#: 94013
Vehicle:2000 2.35 Impreza Blue |
Oh for sure im using Pauter,Carrillo,Crower but what length rods are they. Im gonna do a spare 2.5 aswell.
#4 |
Member#: 79175
Vehicle:2002 wrx |
Stock Phase II rods size. Make sure your machinist adjusts the thrust bearing for the Phase II crank. Wiesco makes drop in pistons for this build. Sounds fun good luck.
#5 | |
Member#: 99140
E. Canada
Vehicle:GD Racing chassis Slowly in construction |
With the Wiseco pistons you need 5.180" rods to have an acceptable CR, the problem is all WRX or STI rods are at ~5.137" You could get some custom pistons to try bring up your CR but I don't know if you can recuperate the 0.043" difference with relocating the piston pin. The problem also with Pauter rods @ 5.180" is that they are 48mm, your phase II crank rod journals are @ 52mm IIRC. I'm thinking about a crazy setup that will bring the CR to 9.0:1 using STI/WRX 5.137" forged rods, Wiseco pistons K602M975, phase II crank 79mm and WRX heads. I will post later tonight in my thread and you guys tell me if it make sense. ![]() |
#6 |
Member#: 71348
TXIC
Vehicle:1999 EJ207 RS.TI VW Golf TDI 40mpg baby! |
I've researched this quite a bit and I have all the parts sitting in my garage for a similar setup.
For EJ22t w/ Phase 1 EJ25 Crank, Wiseco Pistons the only rods that will work is... Factory Phase 1 EJ25 Rods (I have a set PM me if you want to deal) Pauter SUB-230-510-1315F (Roughly $850 + ship) Outback Motorsports EJ25 rods ($500 + ship) - This is the way I went. For EJ22t w/ Modified for Phase 2 Crank, EJ257 Crank, Wieseo Pistons rod options... Factory Phase 2 EJ251 Rods (or any after market equivalent, FYI this is on SOHC EJ25 2000+) Scat 2-5180-2047-842-905 ($300ish, I think these are the correct ones, I've emailed Scat and they told me the measurements and it should work, I'm not sure they were intending on making rods for an NA motor, but I think the idea was for a EJ20 stroker but I am not aware of anyone using this size for that application) Pauter SUB-230-550-1315F (Roughly $850 + ship, note this is different than above) There are probably some more, just make SURE the rod length = 5.180" (in either build). Just make sure you pay attention to your journal size, first build = 48mm, second = 52mm. Last edited by ai42; 08-18-2007 at 06:06 PM. |
#7 | |
Member#: 71348
TXIC
#8 | |
Member#: 99140
E. Canada
I will post my setup in my thread, I hope to see you post your thoughts there. Sorry cruizer22b for the hijack, but it's kinda related to your setup also. |
#9 | |
Member#: 156974
No problem Kosmic keep me updated. Thanks to everyone for posting. |
| Thread Tools | |
| Display Modes | |
| 2.5i to 2.5turbo engine build checklist, thoughts, opinions, and help | 07ImprezaMB | Built Motor Discussion | 21 | 10-19-2012 01:24 AM |
| Frankenstein 2.2/2.5 Engine Build questions. | Not All There | Normally Aspirated Powertrain | 36 | 06-01-2007 02:28 PM |
| 2.65L Engine Build - 9,000RPM Redline?? | nomorem3 | Built Motor Discussion | 11 | 09-10-2006 10:34 PM |
| my 2.5 motor build, and questions? | spoolinred | Built Motor Discussion | 0 | 06-08-2006 12:35 AM |
| Ugh, my stomach is killing me... little help? | rogue | Off-Topic | 9 | 12-24-2003 09:42 AM |
