Old 08-18-2007, 05:13 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default knicked gasket surface
Is this gonna be a problem for me? Im thinking its gonna lead to a blown headgasket sooner or later since the engine will be seeing boost..
Unfortunetly the knock goes into the cylinder too, a tiny bit.
mxpunk is offline   Reply With Quote
Old 08-18-2007, 05:24 PM   #2
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
It's pretty small.......I wouldn't worry about it.
Curious to see more experienced members thoughts tho.
Kosmic is offline   Reply With Quote
Old 08-18-2007, 09:41 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
The actual head gasket is outside that point, or close to it. I personally wouldnt worry about it. But I have a bad reputation for being a cheap ass punk.
Old 08-18-2007, 10:08 PM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I wouldn't worry about it either.
disclaimer: But like reddevil I am a cheap bastard too. I reuse headbolts.
LiquidForce is offline   Reply With Quote
Old 08-19-2007, 03:21 AM   #5
Drink
Member#: 102682
... ripper's
sister.
You can see where it falls in relationship to how the gasket seats... look at the markings from the old HG.
You should be A-okay.
Drink is offline   Reply With Quote
Old 08-19-2007, 10:58 AM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Yes, I am a cheap ass too! lol
Thanks guys. I think I might of knicked it cleaning the surface with a gasket scraper and a razor blade (gotta be more careful)
Old 08-19-2007, 11:49 PM   #7
bboy
Member#: 56468
04 Improved STI
Dirty White
That's not a problem unless the underside has been gouged out underneath.
Old 08-20-2007, 04:31 PM   #8
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
You mean the outer part of the cylinder, the water jacket?
Old 08-20-2007, 09:14 PM   #9
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
make sure that there isnt any kind of a burr on the gasket surface or cylinder wall. use a fine file to smooth it out.
~Josh~
Old 08-21-2007, 04:10 PM   #10
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
^ yeah its pretty smooth, i ran my finger over it last night but i still think i might hit it with a file gently..
Old 09-15-2007, 09:45 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
if theres a knick on the outer part do u guys think im gonna have problems?
i wasnt paying attention when i was cleaning this **** up and got sloppy..i feel like an idiot!
would a silicone gasket work with this? i dont want to be dealing with head gasket problems
help!!
Old 09-16-2007, 08:22 AM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
got another picture?
Old 09-16-2007, 08:37 AM   #13
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Sharp egdes have the potential to create hot spots which may make that cylinder more likely to detonate. I'm not sure if that knick would result in that, though.
PeteDucati is offline   Reply With Quote
Old 09-16-2007, 11:18 AM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
here they are :: stabs self in the eye :: .. lol
what should i do now?!
Old 09-16-2007, 11:51 AM   #15
bearpaws1973
Member#: 145025
1992 Typhoon
06 wrx built to the hilt!
Do you have a machine shop in the area? You can have them deck the surface .003-.005 of an inch, and that should clear it up, or try using a large flat stone with a fine grit, and possibly add a 280-320 lapping compound, slowly and carefully make small circular motion over the entire surface, then when you are done use a feeler gage and straight edge, and make sure you have no valleys.
bearpaws1973 is offline   Reply With Quote
Old 09-16-2007, 12:05 PM   #16
hotrod
Member#: 14141
2002 Impreza WRX
That knick goes into the cooling jacket so your only worry is to keep the wet stuff out of the burning stuff.
Clean it off so there is no burrs sticking up above the surface. Clean the groove with acetone, and put a dab of JB weld on it, then wipe it smooth with a flat object. After it sets Gently smooth it off with 400 grit sand paper if you have any lumps sticking up above the surface. (if you do the wipe off carefully with an absolutely flat object it should be very close to perfectly flat) If it is a smooth surface the gasket should be happy.
Larry
hotrod is offline   Reply With Quote
Old 09-16-2007, 01:09 PM   #17
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
yes i do..but like all that work will cost more then the block itself
Larry
i may try this..thanks
Old 09-16-2007, 01:11 PM   #18
LiquidForce
Member#: 12811
2002 2.5l Wrx
When I clean off the heads and the cylinders I use 220 grit paper on an orbital sander. Takes about 2 seconds to clean up and it barely removes any material.
With your recent luck I'd head to a machinist to get that fixed. You may find yourself in a bigger hole trying to fill and sand that flat.
Old 09-16-2007, 07:21 PM   #19
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
^ yeah you're right...im just concerned that the compression will be off alittle and make things weird..dammit!
Old 09-17-2007, 11:09 AM   #20
bearpaws1973
Member#: 145025
1992 Typhoon
I did my math for compression on sti block and wrx heads, so it may not match, but the #'s I came up with looked about .2 cr for ever .01 of an inch, so 3-5 thousandths sould be less than .1 on the cr (If my #'s are off someone please correct me, cause I just decked my heads and have them on my block!) I like the jb weld idea, give it a try.
Old 09-17-2007, 02:02 PM   #21
hotrod
Member#: 14141
2002 Impreza WRX
Don't worry about that small of a change in CR, .002-005 inch off the deck height would hardly be measurable if you CC'd the engine.
Larry
Old 09-17-2007, 03:05 PM   #22
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
blasphemy!
you mean you don't automatically jump on the ARP bandwagon??!?
your block is gonna assplode dude.
Old 09-17-2007, 07:20 PM   #23
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thanks guyys
Old 09-17-2007, 08:51 PM   #24
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Larry
Hey Larry.. at what point does the piston to head clearance become an issue?
Old 09-18-2007, 02:54 AM   #25
hotrod
Member#: 14141
2002 Impreza WRX
You should always check it when the build is done, but quench is about .039 as I recall so a couple thousandths should not get you in trouble on most builds. There is always a chance you have a cylinder where you have a tall piston, a long rod and a long stroke all in the same hole. That sort of tolerance stack up can get you in trouble using all stock parts on occasion.
I don't think I would be comfortable with less than 0.32-035 quench depending on plans for high rpm.
Larry
3" exhaust gaskets Oreotsi New England Impreza Club Forum -- NESIC 10 06-04-2010 09:11 AM
*sold*New donut gasket lakai5 Engine/Power/Exhaust 2 06-03-2010 11:27 PM
Do the OEM crush gaskets seal scratches / scrapes between mating surfaces? Bad Noodle Newbies & FAQs 12 11-10-2009 04:13 PM
long shot knicks EklEktEk79 Tri-State Area Forum 2 11-06-2002 04:45 PM
OT - for those who like the Knicks Joe LI Tri-State Area Forum 10 07-29-2001 06:57 AM
