Old 08-18-2007, 05:51 PM   #1
rexoutofhell
Member#: 155858
06 wrx/sti
black
Default How much can a built 06 wrx motor handle??
Just as the title says. How much power is the 06 wrx motor able to handle if you build it up. pistions, rods, cams. porting it out? dont know what route to go down?
rexoutofhell is offline   Reply With Quote
Old 08-18-2007, 06:01 PM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
If you want to drop the money into it you can build it to handle 500+hp. Of course that would require, sleeves, pistons, rods, maybe even crank, heads, and around 5k in machine shop work. I think a better question is how much power do you want to make and figure out your build list based on that. Certainly if are wanting to get into the really high hp range you are probably better off swapping it for an EJ257 (STI) shortblock at least.
ai42 is offline   Reply With Quote
How much can a stock EJ20 short block handle? sub_rho Built Motor Discussion 2 02-24-2009 12:07 PM
how much can an STI Type RA Gearset Handle? 03SuBbYWrX Transmission (AT/MT) & Driveline 2 11-01-2007 07:00 PM
How much can a stock WRX intercooler handle Jutboy Normally Aspirated with bolt-on Forced Induction Powertrain 18 04-29-2007 08:08 PM
How much WHP is the 06 WRX good for on stock turbo? riggs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 11-14-2005 12:24 AM
How much can you lower your WRX ??? White4drWRX Brakes, Steering & Suspension 3 01-25-2002 01:14 PM
