#1 |
Member#: 117018
NWIC
Vehicle:79 Rexor on Dubs Paws McGillicutty |
Just got back from KITO.
03 wrx Helix up Invidia down Cobb cat back Open sourced tuning by Master2192 (Base MAP) Mustang DYNO WHP 204 @ 6400 TQ 193 @ 3800 AFR 11.6 min 12.9max 12.2 AVG (tailpipe not Wideband) MAX boost 16.5 ![]()
#2 |
Member#: 25027
What do stock WRXs dyno there?
#3 |
Member#: 74167
NESIC
Vehicle:2011 WRX Sedan WRB Cobb Stage 2 OTS |
Sounds a bit low...I'd love to see your map...
Hows the car feel? |
#4 |
Member#: 117018
NWIC
#5 | |
Member#: 117018
NWIC
Showing the map might not be possible, as its not "mine". ![]() Also this is just a Stage 2 Base map, needs to be worked over. This is just a base dyno run so we have something to compare it to. |
#6 |
Member#: 25027
#7 |
Member#: 117018
NWIC
#8 |
Member#: 151994
NWIC
Vehicle:05 STI "Stage 2" 13.10@103.6mph, 1.78 60's |
Sean (master) Tuned mine too. I am happy with it.
#9 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
Its ok, you can post the map if you want. It is freely available on enginuity.org
From looking at the AFRs he reported it is running leaner now than when I put the basemap on there. I need to head out there and log his car, but when we flashed it the logs show perfect timing and MAF flow numbers about equal to the car the basemap was developed on. Map is available here. http://www.enginuity.org/viewtopic.p...566&highlight= |
#10 | |
Member#: 117018
NWIC
#11 |
Member#: 24038
South East
#12 |
Member#: 10276
Vehicle:2001 Impreza RS 2002 WRX, 2012 535i |
I put down 203awhp when I was stage 2 tuned by Dynocomp on a DynoDynamics dyno with Ecutek. Mine felt strong. Stock WRX's put out 160 or so there.
#13 |
Member#: 23071
TXIC
Vehicle:2005 OBP Forester XT 2005 OBP LGT |
I put down 243.3hp and 240.0tq on a mustang dyno at only 14.5psi. This was at stage 2. Stock STI on the same dyno was 255 / 265 less than 10 minutes prior to my run. It was probably the same dyno as Vahnatai since I was in Dallas when it pulled those numbers.
#14 |
Member#: 25027
#15 |
Member#: 130230
SCIC
Vehicle:2002 WRX-totaled =[ 2011 G37-S |
hmmm this does seem kinda low... I have a stage 2 4eat .. (uppipe, downpipe, headers, colder plugs, drop in K & N and a good tune) And i was able to pull on my friend who has an all motor 215whp civic (lighter than me also)....
#16 |
Member#: 128549
Vehicle:2006 Benz |
Yeah. I agree. I am at stg 2 as well and I was told by the previous owner that it made 230 whp. I have turboxs turbo back exhaust, intake, utech. And stock 02 are about 170.
#17 |
Member#: 128549
Vehicle:2006 Benz |
I have a friend that said with headers you get around 260whp.
#18 |
Member#: 117018
NWIC
Added the dyno sheet
#19 | |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
hi sean ![]() |
#20 |
Member#: 23071
TXIC
Just for you, same setup made 200hp / 210tq on a dyno dynamics dyno at Dynocomp in Phoenix on 91. Only mods difference between the two was Ecutek tuned in Phoenix and Unichip tuned in Dallas. The other 20hp was the altitude difference.
#21 |
Member#: 113777
SWIC
Vehicle:2000 miata silver |
204 awhp seems just a tad bit lower than mine. i have catless downpipe, catback, k&n drop in filter, and an aps bov with the ecutek flash and dynotune @ dynocomp in phx. my car dyno'ed at 216hp with a little over 200 ft/tq. that 240 awhp sounds damn good!
#22 |
Member#: 126499
NWIC
Vehicle:2004 Dodge Ram 2500 Cummins Turbo Diesel |
Just to put in my .02, my car put down exactly the same numbers on the same dyno the following day. I talked to Kito and Dominic who tunes for them and also tuned my car as well as some other guys and they said stock wrx's usually put down in the 160ish range on that dyno. I'm pretty happy with it for a road tune without and WB02. I'm still running a catted downpipe as well. I'll try to post up my graph later.
#23 |
Member#: 157119
Yeah, im with everyone else on the numbers seeming low but it was also on a MustangDyno which typically reads lower then a DynoJet or DynaPack.
What kind of weather were you having when you dynoed the car? Temp makes a big difference, the roomates STi, made near 40 whp more when it was about 15 or so degrees cooler outside |
#24 |
Member#: 20784
TXIC
Vehicle:2002 Impreza WRX WR Blue |
Another Texas guy here about to spew some dyno numbers. I have a TurboXS uppipe, and full catback with 1 racing cat in the midpipe. K&N airfilter and unichip and made 228/231 on a Mustang dyno. If the difference is 15-20 hp/tq for 93 octane then let's meet in the middle and say 17. So you should be around 211/214 hp/tq. This was running around 15 psi with no other mods. It does sound a bit low, but all cars put out slightly different numbers. Just for refence I gained 61 hp over my stock (baseline). I went from 167 to 228 hp with full catback, uppipe, EM, and air filter. Look at your stock gains to really see how well you're doing, adjusting for percentages obviously. So I gained roughly 36.5% versus stock. Take your stock hp numbers and see what percentage you increased, and you should be within 5% of my gains or anyone else here with the same mods.
Chad |
#25 |
Member#: 78018
NWIC
Vehicle:2003 WRX Green PPG Aspen White |
I also got my car tested there this weekend. I have a 03 wrx opensource tuned, vf30, sti pinks, walbro fp, ssautochrome tmic and catless exhaust. At first I had cobb 2.5 map and now with the opensource tune I felt a pretty good increase in power. And I only managed to pull a 232 hp on that dyno. Back to the drawing board for more power
| Thread Tools | |
| Display Modes | |
| FS: (SoCal) 02-03 WRX Stage 2 Package (Downpipe+AP) | nofriends | Engine/Power/Exhaust | 2 | 05-28-2010 09:23 PM |
| Smoking from exhaust my 03 wrx stage 2 | xevets | Newbies & FAQs | 4 | 11-24-2008 05:25 PM |
| 03 wrx stage 2 unichip | SQ3.0dotJP | MAIC Private Classifieds | 0 | 01-05-2007 05:43 PM |
| 03 Cobb Stage 2 WRX 1/8 mile time | Erexxx | Proven Power Bragging | 9 | 06-09-2006 06:08 PM |
| COBB Access Port w/part's for 02-03 WRX Stage 2.5 | BLUE WRX | Private 'For Sale' Classifieds | 7 | 06-16-2005 10:59 PM |
