Old 08-18-2007, 08:02 PM   #1
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
Default There aren't green jumper connectors under dash of 06 STi are there ?
I'm prettty sure that's not the source of the error that i get when trying to read ECU's stock ROM image, but figured i'd ask...
Steps I'm following :
1. Connect cable to car and laptop.
2. OPen ECU flash.
3. CLick "read ecu"
4. Select proper car.
5. Click read.
6. Turn ignition to on when prompted, and quickly clicking okay.
7. Recieve error message, back in a min.
OKAY the error code is :
SSM2 validating kernal ram area addr: FFFF3000 len:0C98
WTF?
If you see a big prob so far , let me know...
Thanks -
Joe
joe-6STi is offline   Reply With Quote
Old 08-18-2007, 08:16 PM   #2
WeldingHank
Member#: 98645
2002 WRX Wagon
there are green jumpers on an 06 sti. that is why you cannot read your map.
WeldingHank is offline   Reply With Quote
Old 08-18-2007, 09:26 PM   #3
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
hi welcome to "reading things owns you" land, joe -
population - ME.
thanks Welding Hank.
You sir are rock and roll...
Old 08-20-2007, 02:55 PM   #4
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
lol.. you get it workin bro?
t4nk is offline   Reply With Quote
Old 08-20-2007, 05:03 PM   #5
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
After i got a friend who's NOT color blind and who wasn't exhausted after TBE install (*which was a PITA, one of the DP flange bolts was crossthreaded or galled from factory, so we had to cut it ... and i'm anal about how ish get done - everything was protected from metal chips*) to look under the dash - we were rolling.
I took some logs from about 30 miles after the XPT stg 2 reflash (giving the ecu time to recover from it's concussion so to speak...) and have posted them on the XPT owners section at osecu roms.
I'm taking it easier than normal on the car untill i have more time to look at the logs and properly aquaint myself with exactly what's happening. All the theoretical tuning knowledge i can absorb cant compare with actual Logging, Discussing, tweaking, etc. Would you mind if I emailed you a few logs tonight to take a a look at? I'll include my comments on what i think needs to be done...
On a side note, My cousin who spent the entire summer at a fishing camp in Cooper Landing, AK said that it was the most mind blowing experience of his life. He urged all of us in houston to leave the "cesspool" as he called it
Apparently you work in a beautiful state...(not knocking Katy, but i meant AK).
Thanks -
Joe
green connectors under dash? bugeye829 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-07-2007 01:48 PM
Loose green connectors under dash. L80Killa87 Electrical & Lighting 5 05-04-2006 12:00 AM
Help: Green Connector Under Dash wrxraj Newbies & FAQs 4 09-15-2002 11:45 PM
That green connector under dash DDMan Car Audio, Video & Security 0 01-20-2002 04:38 PM
Weird green connector under dash? Eric SS Technical Forum Archive 4 08-27-2000 05:51 PM
