Old 08-19-2007, 04:45 PM   #1
Donzo
Member#: 95337
2012 Jeep Overland
Default Putting stock springs back in... which ones are which?
I'm having a tough time figuring out which springs are for the front and which are for the rear. One has a green and yellow dot, the other has purple and orange. I've been searching for the past 20 minutes but every single thread has "stock" and "springs" in them.
Donzo is offline   Reply With Quote
Old 08-19-2007, 04:48 PM   #2
jezzy
Member#: 121883
The front springs are shorter in height than the rears.. for my wagon anyway, same in a sedan ?
jezzy is offline   Reply With Quote
Old 08-19-2007, 04:49 PM   #3
tuskenraider
Member#: 65699
15 WRX
WR Blue
Yep, fronts are always shorter.
tuskenraider is offline   Reply With Quote
Old 08-19-2007, 04:57 PM   #4
Donzo
Member#: 95337
2012 Jeep Overland
They're the same friggin height... nothing seems to be going right today. I may smash my face through a brick wall out of frustration.
Old 08-19-2007, 06:13 PM   #5
Donzo
Member#: 95337
2012 Jeep Overland
due to uncertain weather conditions I had no choice but to put the Prodrive springs back on. I'll try again next weekend or maybe I'll just pay a shop to take everything (sways, endlinks, springs) at once and put the stock parts back on.
Old 08-19-2007, 07:19 PM   #6
Donzo
Member#: 95337
2012 Jeep Overland
I still need to know the answer to this question so that I can tackle the job next weekend.
Old 08-19-2007, 08:03 PM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Did you actually try 'offering up' the spring to the strut and/or tophat? The front and rear spring perches have noticeably different diameters - it should be quite obvious that one does not fit t'other.
UkNuck is offline   Reply With Quote
Old 08-20-2007, 08:39 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Exactly. The rears have a much smaller diameter on top than the fronts.
Tony
Old 08-20-2007, 10:41 PM   #9
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
yea match them up to the tophats and u will find ur answer.
Subydude81 is online now   Reply With Quote
Old 08-21-2007, 05:23 PM   #10
Donzo
Member#: 95337
2012 Jeep Overland
I started with the rear springs. I lined both stock springs on the lower strut perch and neither seemed to sit perfectly, IMO. Eventhough they seem to be the same height, one has coils that are spaced apart more. I will find a pic of stock springs and post them. Give me a minute.
Old 08-21-2007, 05:43 PM   #11
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
A front spring will only fit on a rear lower perch if it is upside down (i.e. \ / rather than / \) - and then it would obviously NOT fit the rear UPPER perch - which has the smallest diameter of the lot.
Old 08-22-2007, 02:19 PM   #12
Donzo
Member#: 95337
2012 Jeep Overland
I think I'm going to take springs from each side of the car off first instead of both rears, then both fronts so that I can compare.
Old 08-22-2007, 04:17 PM   #13
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Take pictures for us and we can tell you.
- Andrew
RaceComp Engineering is online now   Reply With Quote
Old 08-22-2007, 07:05 PM   #14
DrSeuss
Member#: 70170
2005 WRX Wagon
I checked the springs sitting my shelf here are the color dots
Left Rear: Yellow and Red
Right Rear: Red and Purble
Fonts: Green and Yellow on 1 coil with an orange dot on the coil above.
Oh these are for a wagon BTW
DrSeuss is offline   Reply With Quote
Putting stock bushings back in diff and shifter Eluder Transmission (AT/MT) & Driveline 3 07-08-2007 10:37 AM
anyone put stock injectors back in sti after changing? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-14-2005 02:57 PM
Help! Putting stock springs back on... phantom309 Brakes, Steering & Suspension 2 05-26-2005 01:43 PM
Need help putting stock intake back in. suburbantrix Mid Atlantic Impreza Club -- MAIC 3 04-07-2004 12:12 AM
putting stock airbox back in... questions. alastair Tri-State Area Forum 16 03-24-2001 12:59 AM
