Old 08-19-2007, 08:23 PM   #1
JasonRan
Member#: 163
1999 2.5 RS
Rally Blue
Default Lights on decklid do not work...Help!
I just realized that none of the lights on the decklid of my 2000 Legacy Outback work. That includes the tag lights, back up lights, tail lights, and brake lights. The only lights on the back of the car that work are the tail/brake lights on the quarters and the 3rd brake light. I have checked all the bulbs and fuses and they are all fine. Seems weird that the ones that don't work are all on the decklid. Someone told me that it might be a bad ground wire of a corroded socket. Has anyone else had this problem? Thanks a million!
JasonRan is offline   Reply With Quote
Old 08-20-2007, 11:25 AM   #2
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Have you traced the wiring harness back into the body of the car?
Huffer is offline   Reply With Quote
Old 08-20-2007, 04:44 PM   #3
JasonRan
Member#: 163
1999 2.5 RS
Rally Blue
I have not. I pretty much stopped after checking all the bulbs and fuses. You think the harness may be damaged further up into the car?
Old 08-21-2007, 09:58 AM   #4
Huffer
Member#: 36735
99 GF8 Impreza 2.0
It's a possibility - I know that a lot of the harnesses come with connectors to allow multiple harnesses to be hooked into the entire car - extra accessories etc.
It's possible that a wire might have been caught between two panels and is pinched?
Old 08-21-2007, 10:49 AM   #5
JasonRan
Member#: 163
1999 2.5 RS
Rally Blue
I will definitely check that out! Thanks!
Old 08-26-2007, 11:31 AM   #6
JasonRan
Member#: 163
1999 2.5 RS
Rally Blue
Huffer, you are the man!!! I checked the harness and sure enough, the connector on the decklid side was all messed up. The wires had totally pulled away from the connector. Wired it all back up and it works perfect. Thanks again...you rule!
AIRBAG light on, turbo timer not working. shadysalezmen Electrical & Lighting 3 05-20-2009 12:02 AM
I'm doing a paper on people surfing the web at work instead of doing their work, help rice h8r Off-Topic 33 04-17-2008 04:31 PM
Lights on Decklid Do Not Work...Help! JasonRan Electrical & Lighting 10 08-28-2007 08:40 AM
Interior light does not work... HELP? Rookie84 Electrical & Lighting 12 08-25-2006 08:19 AM
Back up lights Do not work?? 03WRX83 Electrical & Lighting 2 01-15-2006 12:33 PM
Message Board Statistics All times are GMT -4. The time now is 01:09 PM.
