Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 08-20-2007, 01:43 AM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Explain the Oil Pump #, and shim relationship!
So I have torn down a dozen or so motors now. And everyone has had a different oil pump. Since only a few were newer, only a few had numbers (7, 10) cast into the inside of the housing. The rest were blank.
Some of the older blank ones had 2 shims.
The 7 cast one, out of a 2.5 2006 RS, had 0 shims.
The 2002 WRX was a 10, havent torn it down yet for shim #.
Whats it all mean?
Old 08-20-2007, 10:54 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
The stamped numbers are the thickness of the rotor. 7mm, 9mm, 10mm and now 12mm pumps are available.
The shims effect the oil bypass. More shims = more oil pressure before the bypass opens.
mick_the_ginge is offline   Reply With Quote
Old 08-20-2007, 10:59 AM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I have a WRX shortblock and also an EJ22T in the garage. Should I go inspect them? I also have my '99 2.2L NA shortblock as well.
FuJi K is offline   Reply With Quote
Old 08-20-2007, 09:19 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
id love to have a 12mm oil pump when i go turbo, just added insurance.......
<----wonders where to get one...
~Josh~
Old 08-20-2007, 10:22 PM   #5
LastResort
Member#: 99289
LastResort is offline   Reply With Quote
Old 08-21-2007, 09:56 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
So I guess on the non-numbered older ones, I could just measure the thickness of the rotor?
Old 08-21-2007, 10:06 PM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
yep, the only difference seems to be the shims and thickness of the rotor
Old 08-22-2007, 02:27 PM   #8
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Could the spring rate of the bypass mechanism also differ?
I've been wondering about this since I install the 12mm pump + 1 extra shim and I'm seeing pressures of less than 6 bars @ 6k+
- I'm running 10w-30 - still need to change the break-in oil to something heavier after 1500 miles (2nd oil change)
engineerx is offline   Reply With Quote
Old 09-15-2007, 04:21 PM   #9
02RSBRP
Member#: 159398
I think everybody has kind of misunderstood what pressure each oil pump runs at. Below is the numbers out of the manual for the 9mm and 10mm oil pumps.
Capacity at 80C (176F)
700 rpm Discharge
- pressure 98 kPa (1.0 kg/cm2, 14 psi)
- quantity
4.2 l (4.4 US qt, 3.7 Imp qt)/min. (9mm)
4.6 l (4.9 US qt, 4.0 Imp qt)/min. (10mm)
5,000 rpm Discharge
- pressure 294 kPa (3.0 kg/cm2, 43 psi)
- quantity
42.0l (11.10 US gal, 9.24 Imp gal)/min. (9mm)
47.0l (12.41 US gal, 10.33 Imp gal)/min. (10mm)
Relief valve operation pressure
490 kPa (5.0 kg/cm2, 71 psi) (9mm)
588 kPa (6.0 kg/cm2, 85 psi) (10mm)
Oil capacity (at replacement)
4.0 l (4.2 US qt, 3.5 Imp qt) RS
4.5 l (4.8 US qt, 4.0 Imp qt) WRX
Notice how even at 5000 RPM, that both pumps only put out 43psi. I agree that the relieve setpoints are different, but would you even get close to that setpoint? Maybe if you where spining at 8k, but more than likely you would be in the 65 psi range. So are you really increasing you oil pressure by putting shims into the relief valve?
02RSBRP is offline   Reply With Quote
How does the oil pump and bypass work? udelslayer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-16-2009 02:43 PM
F/S;VA; STi fuel pump, BCS,oil pump, shifter and knob ALL OEM moorebl Engine/Power/Exhaust 0 06-14-2009 05:15 PM
Oil Leak From Front Bottom Center of Engine that Isn't the Oil Pump? williaty Service & Maintenance 4 05-21-2009 02:54 PM
wrx oil pump, baffle, and pick up and some other stuff ronzogonzo MWSOC Private Classifieds 1 02-29-2008 12:47 AM
Is this sealant the right stuff for sealing the oil pump??? 2slofouru Service & Maintenance 3 08-08-2007 04:03 PM
