Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 08-20-2007, 02:53 PM   #1
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
Default grr targetboost!
Okay.. so was tuning a bug eye this past week, and I cannot for the life of me get it past 12psi! new bcs, new hoses, stock restricter pill. adjusted wg warm 3 full turns, got .5psi out of it. I will post logs and maps when I get home.. But I know its the WG.. under wot it will boost 11-12psi @ 9x.x% wastegate duty cycle.. The WG Duty Cycle mapping is set to low 80's, boost is set to 17.4psi. Any ideas? (03 bug eye, TXS turbo back, stage 2)
t4nk is offline   Reply With Quote
Old 08-20-2007, 06:19 PM   #2
TheShad0w
Member#: 91925
2005 Saabaru 92-x
AWDTuning.com
sounds like aboost leak to me - when you say new bcs, you mean like a 3 port not an OEM 2 port, right?
TheShad0w is offline   Reply With Quote
Old 08-20-2007, 06:20 PM   #3
wuuusaa
Member#: 92894
its a oem 2 port
Old 08-20-2007, 07:03 PM   #4
t4nk
Member#: 129905
2005 WRB WRX
oem 2 port. But the fact of the matter is a good BCS will boost 17psi or more, a bad one wont go past wg boost. And now that you mention boost leak....... the vac. line from the turbo inlet came off.. and it overboosted a few times to 22ish psi.. it could have caused a boost leak.. it pulls pretty damn good for being at 12psi tho!
Old 08-21-2007, 08:22 AM   #5
gabedude
Member#: 10108
07 STI
60Trim TQ monster
Use a grainger valve (make your own MBC from home depot) to bleed off some boost to the air and disconnect the stock solenoid. If you can control boost with an MBC, then it is the solenoid or the solenoid wiring. You said a vac line came off and it overboosted, so I am thinking that the solenoid is not getting power.
gabedude is offline   Reply With Quote
Old 08-21-2007, 11:08 AM   #6
t4nk
Member#: 129905
2005 WRB WRX
okay ill look in to that.. thanks for ur input gabe. as always its highly appreciated
argh! grr! :( Valien South East Region Forum 10 11-13-2001 11:08 PM
Grr. Im so busy. T-REX Vancouver Impreza Club Forum -- VIC 8 10-01-2001 06:09 PM
('93-'01) Grr :( How do I get gum off floor mat? Hyudra Impreza Forum 12 06-28-2001 12:22 PM
rant: Blankety-Blank Bank of America! GRR. CosmoTheCat North West Impreza Club Forum -- NWIC 24 05-18-2001 10:52 AM
GRR! My windshield fractured overnight! Fido General Forum Archive 5 11-28-2000 12:55 AM
