Old 08-21-2007, 05:08 AM   #1
rexoutofhell
Member#: 155858
06 wrx/sti
black
Default what would you do if you had a sti block
I have looked and searched, but i want to know what people have done and has worked for them, that have fully built there sti block 2.5??? Which have been the best parts you use, pistons, rods, cams. everything??
Also wondering for a fully built motor which turbo would you go with gt35r .82 or 1.06? when is full boost going to come in
rexoutofhell is offline   Reply With Quote
Old 08-21-2007, 04:09 PM   #2
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
id use it as a paper weight!
if you're gonna build it with forged internals get a gt35r for sure!!
mxpunk is offline   Reply With Quote
Old 08-21-2007, 05:58 PM   #3
jbones
Member#: 149667
2006 wrx
goal-build a 500+whp =)
woogie boogie
jbones is offline   Reply With Quote
Old 08-21-2007, 05:59 PM   #4
rexoutofhell
Member#: 155858
06 wrx/sti
black
hah funny, dont think im a newb, i forgot my password on my other account. the turbo isnt really the problem. its just what exact parts. I dont want to go full race block, but really reliable if im planning on getting 400+whp. I have talked to a couple shops. and all said thats it up to me. didnt make since to me neither
Old 08-22-2007, 03:38 PM   #5
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
if your hp goal is 400whp,
just pick between GT30R or GT35R in 0.82 trim - easy as that
of course you'll need the supporting mods
800cc - 1000cc inj
dual Walbros or Bosch 044
etc....
engineerx is offline   Reply With Quote
Old 08-24-2007, 04:28 AM   #6
rexoutofhell
Member#: 155858
06 wrx/sti
black
oh trust me that 35 is getting slapped on, i just want the best reliable supporting block mods, i have been searching for months, but you still dont know what works best without asking people that have tested it before. anyone best piston,rods,cams,etc
Old 08-24-2007, 09:17 AM   #7
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
A set of pistons will make it reliable.
SloRice is offline   Reply With Quote
Old 08-24-2007, 10:04 AM   #8
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
I'd consider rods as well. Forged rods are pretty cheap insurance in my opinion considering if they go you've pretty much trashed a block. And I have seen 2 blocks with a blown rod, 1 was un-salvageable, and the other need around $2k in machine work/parts to run again.
ai42 is offline   Reply With Quote
Old 08-25-2007, 04:32 AM   #9
rexoutofhell
Member#: 155858
06 wrx/sti
black
ya, but which would be better rods, pauter or crower, or etc which are the strongest. and are cp pistons the strongest or are there other. and whice cams would be the best. anyone can research. but i need proof
Old 08-25-2007, 11:22 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'm running Pauter's as do all my customers...I hate eagle...carrillo are too expensive for most. Crower's are nice too.
Old 08-25-2007, 12:46 PM   #11
rustyzipper
Member#: 79175
2004 FXT
Red
While you are in there , I would pick up some good bearings. I have seen some forged blocks fail , and everything looked great...except a bearing.
rustyzipper is offline   Reply With Quote
Old 08-25-2007, 02:31 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
true that...so pistons, rods, bearings and arp headstuds for a bit more insurance as it is easy to turn up the boost on race gas but not so easy to put a headgasket back together
Old 08-25-2007, 04:58 PM   #13
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Does it really matter? Do you just want bragging rights? at 400whp with a ZERO Det. tune, you won't even break a stock rod. why even want to know which forged aftermarket is 'stronger'? You aren't gonna break those either.
Go to the race shops near you and talk to them. Those guys blow up motors for fun and R&D. THEY know what will handle how much/when/where/why.
You shouldn't ask the 16yr olds on here......Daddy is still paying for everything.
(Well, with the exception of Micah....dear lord I look forward to pics.....and your destruction pics too!!!! )
modaddict is offline   Reply With Quote
Old 08-25-2007, 05:56 PM   #14
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by modaddict View Post
...at 400whp with a ZERO Det. tune, you won't even break a stock rod...
According to Gadiel's research, make that 600whp. Oh, and lay off the children...someday they'll be paying into SS for you and me.
flycaster is offline   Reply With Quote
Old 08-25-2007, 07:12 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
trust me they will be coming...guess I could start a build pieces thread, but don't where I should put it
now I dumped the billet crank to find where the new subaru oem crank will die (for oiling system ****s and giggles)...and that will be my excuse to run back through the block and o-ring before running the 4202R and 6-spd dogbox
Old 08-25-2007, 09:34 PM   #16
Drink
Member#: 102682
... ripper's
sister.
I'd sell it and buy a closed-deck engine .
Drink is offline   Reply With Quote
Old 08-26-2007, 03:56 AM   #17
bugeyes
Member#: 64494
2001 V7 sti
What would I do? Eactly what I just did!
USDM EJ257 block. Sleeved with heavy collar top sleeves and finished to suit 100mm bore.
CP pistons 8.5-1 comp coated skirts. Altered compression height so I can use long rods
New EJ25 crankshaft with extra oil holes.
Argo billet rods (as your in the US use the Pauters)
ACL race series bearings
12mm JDM oil pump
Block has ported internal oil passages.
Custon large capacity oil pan to eliminate chance of oil aeration
Thats what I curently have in the garage, just in the process of starting to blueprint, final machining and assembly.
Last edited by bugeyes; 08-26-2007 at 03:57 AM. Reason: Forgot to add something.........
bugeyes is offline   Reply With Quote
Old 08-26-2007, 08:46 PM   #18
rexoutofhell
Member#: 155858
06 wrx/sti
black
haha, i hope your not talking about me exploding my engine. but ya wow this kinda exploded, thanks for all the input. im not looking to get a certain power range obviously alot is really nice, if anyone cared i want this to be a really fast dd =). but with all my research and your guys help, its kinda coming more clear on what/not to get. im going to have to search for a closed deck engine see what there about. peace
What would you do if you had a million dollars? imprezton Off-Topic 52 07-11-2005 06:12 PM
What would you do if you had a million dollars? imprezton Off-Topic 50 04-20-2005 12:20 AM
What would you do if you had 72 hours to live? LinuxGuy Off-Topic 16 08-04-2003 02:43 AM
What would you do if you were me! HELP! Subi Ru Mid West Subaru Owners Club Forum -- MWSOC 9 06-24-2002 11:05 PM
What would you do if you won the Big Game? DonA Tri-State Area Forum 13 04-09-2002 09:28 PM
