Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 08-21-2007, 11:36 AM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default Will utec log knock events in log when not in control? MAP 0
I believe with the 5.0 and up firm it will not flash the CEL and the utec will not retard timing, if knock has occured. I know it will only listen for knock when it is in control of timing.
However, does this mean it will not log knock in the logger? for example using MAP 0.
I am trying to get a baseline tune on my stock ecu using enginuity.
NITROS is offline   Reply With Quote
Old 08-21-2007, 11:55 AM   #2
jays05
Member#: 78165
05 STI 35r + e85
Yes, it will.
To clarify... (I am running the latest firmware on the sti utec) in map 0 it will log knock counts and even flash the cel, but it won't pull timing.
jays05 is offline   Reply With Quote
Knock event stage3 logs included WRXsponge UTEC 0 04-24-2006 02:25 PM
UTEC last knock event TexRex2002 Engine Management & Tuning 6 11-03-2005 04:11 PM
Should utec show any values in dashboard when not connected to the car? vadim Engine Management & Tuning 3 08-25-2005 09:24 AM
Cel on. Will utec detect knock? dddnuts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-29-2004 08:32 PM
question on RPMS when not in gear moogooob Transmission (AT/MT) & Driveline 5 09-23-2002 06:20 PM
