Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Notices
Old 08-20-2007, 09:47 PM   #1
bluesube2000
Member#: 54446
03 WRX
Question Question about the effects of A/F, Timing, and boost change in Version 5.8 UTEC
I haven't upgraded the version for my UTEC in a while (haven't touched it in almost 2 years). I have a professionally tuned map, and I am worried that the A/F, Timing, and Boost would change drastically (mostly scared of A/F because my wideband A/F stopped working correctly, and I don't really feel like buying a new one).
I was wondering if anyone had problems in reusing their old maps in the new version of utec? Were there severe A/F, Timing, or Boost Change for anyone?
Please share if you have or haven't experienced any change.
Thanks in advance!
bluesube2000 is offline   Reply With Quote
Old 08-20-2007, 11:06 PM   #2
bluesube2000
Member#: 54446
03 WRX
First person to say something... gets... a banana!
Old 08-21-2007, 12:25 AM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
As long as when you have loaded the new firmware you set the parameters to the same as what they are today then the map will run the same.
So manually write down all the parameters, you cannot upload them between firmware.
Save off all your maps
Upgrade firmware
Manually enter parameters, don't screw with any that were not in the last firmware. Make sure you run the same modes.
Load your old maps
GO
I don't need a banana, thanks
Oh- but if you don't plan to use any of the new features why upgrade?
mick_the_ginge is offline   Reply With Quote
Old 08-21-2007, 04:14 AM   #4
bluesube2000
Member#: 54446
03 WRX
woot thanks for the reply! here you can have a banana anyways
I believe I have like firmware 4.2B or something?
The reason why I want to upgrade is because..
My car knocks a little bit in weird areas only on certain days...
and I heard from a friend that the new firmware makes the car run more smooth / fewer knocks?
And ... I remember u were in the hospital like 2-3 months ago. Hope all is going well for u .
Old 08-21-2007, 11:01 AM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
To be honest unless you are going to get a retune I expect the knock will not go away. As you will be running the same parameters and map you are in effect running the same code so the knock will still exist.
Sounds like the car is tuned to the edge, which is why it only knocks once in a while. Just pull a degree of timing in the areas that it knocks. Or just lower the boost in those areas.
Post some logs and I am sure people will help.
Cheers
Question About the Number of Ports in an enclosure Rayman21287 Car Audio, Video & Security 10 12-15-2008 08:31 PM
Question about the end of time... aerostar Off-Topic 56 12-11-2007 02:03 PM
idle issues on the version 5.8 utec? jemar2169 UTEC 8 01-23-2007 11:08 PM
Question about the founders of the U.S. JonnySubaru Political Playground 17 05-28-2004 04:25 PM
worried about the effect of a lightweight flywheel on the weak RS tranny, HELP! subyguy2 Transmission (AT/MT) & Driveline 5 10-09-2001 12:28 PM
