Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 08-21-2007, 08:00 PM   #1
vwown3d
Member#: 69991
Leh Keen
Approved
Default 2.2 Block Question.
So i have the chance of picking up a 2.2 block but I wanted to know if it was a closed deck or open deck block. I am looking for a closed deck to do a turbo project on.
Here is what the guy sent me:
Motor is pulled from a 1999 Subaru Legacy Wagon. It's a 1999 2.2L Subaru Engine with approximately 30,000 miles on it. It is missing the cam gears, timing belt, timing cover, spark plugs, plug wires, and distributor/coil.
Also I was not sure where to post this so hopefully this is the right place!
thanks!!!
vwown3d is offline   Reply With Quote
Old 08-21-2007, 09:31 PM   #2
that one legacy
Member#: 103665
that one is going to be open deck, with single port heads.
as far as i know, the only closed deck 2.2 was the EJ22T from the 91-94 Legacy Sport Sedans and Touring Wagons (which were turbo'd). all other EJ22s are open deck, with the exception of the engine in the 22B Impreza.
also, i think it was the '95-'96 models that had the dual port heads, while '97-'99 had single port heads. the later models are not prone to the vicious lifter tick that the earlier models are notorious for however.
that one legacy is offline   Reply With Quote
2.5 block question STiWagin Built Motor Discussion 8 02-12-2009 10:45 AM
2.2 block + heads dropmech Built Motor Discussion 10 11-19-2007 07:08 AM
Upgrading to 2.5 block questions Chemlab23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 01-16-2007 01:33 PM
2.2T block questions Whiteghost 2.5 Pre-2002 Factory Turbo Powertrain 8 11-04-2005 01:28 AM
2.2 n/a block question,how much boost? aigburth Normally Aspirated with bolt-on Forced Induction Powertrain 17 11-12-2004 03:43 PM
