Old 08-21-2007, 08:06 PM   #1
lgt2000
Member#: 140073
2005 LGT
Red
Default Rear Diff Bushing for BE
My diff is clunking and I think I need to replace my rear diff bushing, do the WRX bushings fit on the Legacy?
Also could there be anything else other than the bushing causing the clunking?
lgt2000 is offline   Reply With Quote
Old 08-21-2007, 10:57 PM   #2
ten80
Member#: 53625
00 16' FXT
nope, they don't fit as the bushing are built into the rear subframe, whereas a wrx has them pressed into a small, rear diff support that bolts to the subframe. You also can't use WRX rear cross-member bushings, such as those by Kartboy, because the cross-member is absent on the BE/BH (if I remember my car correctly!)
If you haven't already done the swap, a good synthetic lube (I like Amsoil and Redline for rear diffs) will make things smoother. It is also possible that your diff is toast. How many miles do you have on it?
ten80 is offline   Reply With Quote
Old 08-21-2007, 11:40 PM   #3
lgt2000
Member#: 140073
2005 LGT
Red
its at 111k, if its toast whats recommended?
Old 08-22-2007, 12:36 PM   #4
flanders
Member#: 76382
2000 BH
BP Wannabe
I bought all the bushings that Kartboy sells. Send him a PM, let him know what car you have and ask what fits.
flanders is offline   Reply With Quote
Old 08-22-2007, 02:13 PM   #5
lgt2000
Member#: 140073
2005 LGT
Red
so what the final verdict, are there bushings that I can change out, or do I have to change out the diff
Old 08-22-2007, 03:20 PM   #6
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
I'd change your fluid first. You don't have to pay extra for shipping or bits you might not need.
If you need to change your bushings, then flanders already answered that.
Huffer is offline   Reply With Quote
Old 08-22-2007, 04:29 PM   #7
lgt2000
Member#: 140073
2005 LGT
Red
i changed fluid a few months ago
Redline 75w90
Old 08-22-2007, 04:44 PM   #8
flanders
Member#: 76382
2000 BH
BP Wannabe
Try the bushings or go to a good suby mechanic. I have no idea otherwise.
Old 08-22-2007, 05:00 PM   #9
lgt2000
Member#: 140073
2005 LGT
Red
so you order the diff bushings from kartboy and those worked for you?
Old 08-23-2007, 02:20 PM   #10
flanders
Member#: 76382
2000 BH
BP Wannabe
I didn't have any problems, I just felt like wasting money. Everything is much tighter.
Whiteline rear diff bushings for 2008 WRX Shohin Transmission (AT/MT) & Driveline 2 08-10-2008 10:46 AM
WTT: rear diff bushings for stock ones (NY) txl146 Tri-State Area Private Classifieds 6 06-20-2007 02:49 AM
rear diff. bushings for GC8 elpapi336 Transmission (AT/MT) & Driveline 30 03-08-2007 04:26 PM
NY: Rear Diff Bushings & Rear Subframe Bushings wrxnavigation Drivetrain 4 09-11-2006 07:49 PM
Rear diff bushings - full rear bushing front mounts? full set available? Back Road Runner Brakes, Steering & Suspension 2 01-02-2006 04:16 AM
