Old 08-21-2007, 08:41 PM   #1
BradsWRX
Member#: 157249
2003 WRX
Default Car may not have flash as I was told
I just bought my 03 and it was supposed to be flashed with the free stage 1 from enginuity or something like that. Anyway at WOT the gauge goes to .1 in third, fourth, and fifth, but in 1, 2 it goes 2 notches before .1 . I was told by one person that I was running stock boost, then told by another that the boost had been upped.
BradsWRX is offline   Reply With Quote
Old 08-21-2007, 08:47 PM   #2
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
sounds like normal stock boost - .1 being somewhere around 13.5-14psi. and in 1st or 2nd you will likely not hit full boost with this tune.
kingtut12 is offline   Reply With Quote
Old 08-21-2007, 09:04 PM   #3
Mitsu
Member#: 93557
2002 STid wagon-SOLD
defiantly stock boost...you'll have to check the air fuel ration to really see if it is tuned, but if the boost isn't upped then i would guess A/F isn't changed.
sounds like you got scammed(it was free though)
Mitsu is offline   Reply With Quote
Old 08-21-2007, 09:29 PM   #4
J. Steinbeck
Member#: 140575
2007 Magnum SRT-8
Hmmm.... I'm a little confused by the above replies. I've been in several stock 2.0 liter wrxs, and I've never seen the stock boost gauges in any of them actually touch the .1 mpa mark. I've seen them come CLOSE, but never actually touch it...
When I flashed the Cobb stage 1 map on my car, it just then began to actually hit .1 mpa, and according to the live boost reading on my accessport, it was hitting target boost (it often hit 15 psi in fourth and fifth gears).
Maybe my observation is useless, though.... the enginuity maps may be different.
Edit: I should also probably point out that all that I remember driving were 04 and 05 models... maybe there is something different about 03s that I'm not aware of.
J. Steinbeck is offline   Reply With Quote
Old 08-21-2007, 09:37 PM   #5
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
sounds like a stg1 flash to me. 1st and 2nd gear will not hold as much boost at redline as 3rd and 4th.
AWDWRXLOVER is online now   Reply With Quote
Old 08-21-2007, 10:15 PM   #6
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
From what I understand you wont have time or load enough in 1&2nd gear to hit target boost. Mine doesn't develop in 3rd every time...4th & up its a lock though...if you get a tactrix cable you can pull the rom with enginuity and compare to a stock (or free stg 1 for that matter) boost target table and see if it is indeed stock...
joe-6STi is offline   Reply With Quote
Old 08-21-2007, 10:16 PM   #7
AWDWRXLOVER
Member#: 50267
02 built hybrid
exactly
Old 08-21-2007, 10:26 PM   #8
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
and it's a lock like a gorilla on fire that's late to a free banana stand 3 mins before closing.
Old 08-22-2007, 01:29 AM   #9
Redboss
Member#: 152141
2007 WRX exit stg L
Pearl
Gotta write that one down
Redboss is offline   Reply With Quote
So my boss may not like me as much any more... DrBiggly Off-Topic 17 10-03-2008 11:21 AM
I may or may not have to vomit soon coop119 Off-Topic 11 10-02-2006 09:40 PM
some photos you may or may not have seen (summer mods come to an end) Impreza2003 Member's Car Gallery 16 09-19-2005 09:41 PM
This may or may not have been discussed mafiamotorsports Subaru Conversions 6 11-28-2004 12:43 AM
