Old 08-23-2007, 03:48 PM   #26
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
You can replace shims without having to remove the cams, but you need a $250 special tool to do it.
Acostafan is offline   Reply With Quote
Old 08-23-2007, 11:18 PM   #27
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Originally Posted by wigglesxjr View Post
Oh yeah, quick question too...I've put 5 quarts of oil in the engine, but it's still reading low on the dipstick..should i just add more? My guess is yes...
-Joseph
Did you start it and get the engine up to running temp? Also, your not checking this on an incline are you?
Manual states 4.8qts - so theoretically it should be at the full level.
Oh - stupid question here - did your dipstick seat ALL the way down before being pulled back up and checked?
good luck
kingtut12 is offline   Reply With Quote
Old 08-23-2007, 11:45 PM   #28
WRXEcho
Member#: 96372
2002 WRX Wagon 4EAT
I thought there were special cometic headgaskets you were supposed to use for a hybrid. I know that Axis has them. I don't think that the headgaskets are the noise obviously, but just putting my $.02 out there if you're gonna take it apart, you may wanna' make sure the STi HG's are up to the challenge.
WRXEcho is offline   Reply With Quote
Old 08-24-2007, 12:20 AM   #29
Acostafan
Member#: 67398
2002 Now with 100%
You only use the Cometic's if you want to alter the compression ratio down. Run a search on "quench", long standing argument on that.
Nothing wrong with the STI gasket, it's arguably the preferred way to go.
Old 08-24-2007, 01:11 AM   #30
Drink
Member#: 102682
... ripper's
sister.
-Joseph
Did you replace the oil pan with a STi pan? If so, you have to replace the oil-pickup with a STi one. If you don't, you will get a very inacurrate reading and have WAY too much oil in the motor if you go off the markings.
Drink is offline   Reply With Quote
Old 08-24-2007, 11:12 AM   #31
wigglesxjr
Member#: 4293
Midnight Black Pearl
SOrry I haven't been too attentive to this thread (just busy withwork and travel), but I am using the stock 2002 WRX oilpan/tube/dipstick
-JT
wigglesxjr is offline   Reply With Quote
Old 08-28-2007, 07:37 PM   #32
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
-JT
Yeah thats not rod knock. This is rod knock. http://www.youtube.com/watch?v=x9LJP1mw0es
I just replaced my SB to the EJ257 too. I am getting what sounds like some kind of valve noise but its not as loud as yours. I am going to give it about 2k to quite it self. if it gets louder or is still there I am going to take it back to the shop.
Keep us posted with what you find. Maybe I have the same issue as you.
As for the oil issue. not to sure. During my 1k break in i pretty much stayed at the same oil level. I am using the stock 2002 oil pan, dipstick etc., but my tuner did recommend upgrading my oil and water pump.
What kind of oil are you using?? 5w30?
MindzeyeWRX02 is offline   Reply With Quote
Old 08-28-2007, 08:03 PM   #33
TURBOTOD
Member#: 97130
2004 WRB STI on RG-D
COBB/TIC/CUSCO/DSS/TSSFAB
Originally Posted by MindzeyeWRX02 View Post
Yeah thats not rod knock. This is rod knock. http://www.youtube.com/watch?v=x9LJP1mw0es I just replaced my SB to the EJ257 too...
WOW! That's gotta be the worst sounding Subie block I've EVER heard!
Peace-
Tod
TURBOTOD is offline   Reply With Quote
Old 08-28-2007, 08:34 PM   #34
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
Peace-
Tod
It IS the worst sounding subie you've ever heard!!
That thing sounded like a machine gun under my hood.
Old 08-28-2007, 10:14 PM   #35
jays05
Member#: 78165
05 STI 35r + e85
I dunno, burnin4's blown cobb block sounded pretty bad too http://www.youtube.com/watch?v=11I_TOQLgOU
jays05 is offline   Reply With Quote
Old 08-28-2007, 10:16 PM   #36
wigglesxjr
Member#: 4293
holy crap those are bad...i guess mine doesn't sound liek THAT...sheesh..
sorry about the lack of updates by the way, just have been way too busy, and by the time i get out of work I'm pooped. I'll run some tests tomorrow though, for sure. Stay tuned, and thanks for all the thoughts and help.
-JT
Old 08-29-2007, 01:08 AM   #37
Acostafan
Member#: 67398
2002 Now with 100%
Go listen again. It ain't the same. I've heard both types on my engine and I got a shiny gold dollar says it's his valves.
Old 08-30-2007, 02:26 AM   #38
wigglesxjr
Member#: 4293
ok, got some testingdone...
I pulled off the injector harnesses on thedriver's side one and at a time, and to me it didn't sound like the noise diminished at all...so that's a good sign it isn't the rods...
but i pulled the dipstick and looked closely and saw little flecks of metal could this be normal though? it's an engine with about...5 miles on it at this point...
Thanks for bearing with me!
-JT
Old 08-30-2007, 12:34 PM   #39
jays05
Member#: 78165
05 STI 35r + e85
Have you changed your oil since the first startup?
Some people say that it's normal. I dunno, we changed my oil right after the cam break-in, and I did it every 300 miles for 1500 miles after that, and I never saw any fleks of metal in the oil. And I looked at it pretty closely.
Old 08-30-2007, 03:27 PM   #40
wigglesxjr
Member#: 4293
No, haven't changed the oil yet, i will probably try that today...ugh.
-JT
Old 08-30-2007, 09:23 PM   #41
Drink
Member#: 102682
... ripper's
sister.
Slight metal gathering in the pan is normal for intial start-up of any engine. Subarus OEM oil filters are some of the most efficient in the world, so don't stress it. Your valve lash is off, I wouldn't even bother beating around the bush hoping something else will fix your problems.
Old 08-31-2007, 04:39 AM   #42
youpers
Member#: 8988
2000 L GT
White & blue
-Joseph
good guess, but make sure its not using oil, also you got to remove the cams to replace buckets, sux.
youpers is offline   Reply With Quote
Old 08-31-2007, 12:05 PM   #43
Acostafan
Member#: 67398
2002 Now with 100%
Negative ghostrider, he has a 2002 so he can replace shims without removing the cams. What sucks is you need a $250 tool to do it with the cams on. Otherwise, yes, you will need to remove the cams. I think I've said this before....
Old 08-31-2007, 02:50 PM   #44
wigglesxjr
Member#: 4293
hey guys, sorry i haven't been on here in awhile -- busy.
I doubt it has even had the chance to burn much oil if any at all... I've driven it about 5 miles, and no sign of smoke. I'll check the oil soon though, probably change it.
I'm going to be taking it to a respected subaru shop here -- hoping they can just fix the valve adjustment for me if that's the case. Thanks for all the support again guys, I'll make sure to get back here with a resolution -- hopefully a positive one.
-JT
Old 08-31-2007, 08:11 PM   #45
youpers
Member#: 8988
2000 L GT
White & blue
I did not know that, good call, you can be my wingman anytime!
Old 12-09-2012, 05:36 PM   #46
danger1138
Member#: 279525
04 rex luger!
Bumping an old thread.. Any update on the ticking noise, did it end up being the valve clearences? Hows the car running?
danger1138 is offline   Reply With Quote
Rod knock = Hybrid Swap! tshivers00 Built Motor Discussion 29 08-06-2013 03:08 PM
Some knocking...rod knock or piston slap? mtcs Built Motor Discussion 41 12-03-2012 06:47 AM
FS: in wNY Project car 2002 WRX Wagon WRB would be $6500, Rod knock = $3500 - SOLD stutz342 Private Vehicle 'For Sale' Classifieds 25 06-03-2010 11:27 AM
Strange WRX Hybrid Noise, not ticking or knocking. alex02wrx Built Motor Discussion 3 12-10-2009 05:32 PM
rod knock or valve knock Zerogravity Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 06-01-2009 01:28 PM
