Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 08-22-2007, 02:16 AM   #1
Kaldar142
Member#: 151090
S197 boosted V8 FTW
Default car tuned today
i had my car tuned today by TXS in gaithersburg,
hks uppipe, invidia catless downpipe, hks hi power, turboxs tmic, turboxs intake and UTEC, stock turbo.
i put down 247torque and 245 hp when it was all said and done.
what do you guys think?
Kaldar142 is offline   Reply With Quote
Old 08-22-2007, 02:24 AM   #2
iheartmysuby
Member#: 83638
stock boost?
iheartmysuby is offline   Reply With Quote
Old 08-22-2007, 08:33 AM   #3
jack klompus
Member#: 152885
2014 Malibu LTZ
Those look like good numbers for a stock turbo, depending on the dyno used. You might want to talk to your tuner about a new BCS. I couldnt get more than 15 psi with mine. Then he put in a GM bcs and it gained a lot of power.
jack klompus is offline   Reply With Quote
Old 08-22-2007, 09:38 AM   #4
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
i think their dynapack reads high.
AWDWRXLOVER is offline   Reply With Quote
Old 08-22-2007, 11:07 AM   #5
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
Did he try changing the brass restrictor pill inside the boost line?
StarDogChampion is offline   Reply With Quote
Old 08-22-2007, 12:17 PM   #6
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
good numbers... I'm hoping for that and more from a stg2 + pinks/pump/tmic protune
FCmaniac is offline   Reply With Quote
Old 08-22-2007, 01:48 PM   #7
Kaldar142
Member#: 151090
S197 boosted V8 FTW
he said it was set at around 17psi i think
anyways i'm very pleased, the car pulls realllllyyyy hard my baseline run was 195 torque and 215 hp.
a GM BCS? whats that
Old 08-22-2007, 02:34 PM   #8
DemonPossessedNinja
Member#: 116610
2005 wrx vf-34
psm
bcs = boost control solenoid
DemonPossessedNinja is offline   Reply With Quote
Old 08-22-2007, 02:49 PM   #9
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
very good with stock turbo.. how bad does it drop off near redline?
PaulRex is offline   Reply With Quote
Old 08-23-2007, 04:34 AM   #10
Kaldar142
Member#: 151090
S197 boosted V8 FTW
ahhhhh i wish i had the dyno sheet with me, but um i can tell it defiently drops off a little near redline.
i'm pretty happy with it, but um tonight... i was little blown after a little bit of playing around with my buddy, anyways heres what happened:
he has a 07 wrx tr w/ TBE, flywheel/clutch and AP stage 2...
and mine of course (txs intake, uppipe, utec, tbe, tmic and protuned) and when we raced i wasnt even that much faster then him, it seemed like his car defiently pulled harder on the highway in somecases, im not sure it just didnt feel like my car was all that much better.
i know the 07s 2.5l wrx makes alot more torque but would that really make that much of a difference? i was thinking if im doing basically 250hp/trq and hes only rated for like 225whp that i would blow him away, because he was right there with me.
would his flywheel close the gap alot more or what? are the ej25s just that much better then ej20s? lol
Old 08-23-2007, 09:23 AM   #11
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
you basically have the same mods outside of tmic, they come with catless pipes and a larger shelf of torque......what do you think was going to happen
bren wrx is offline   Reply With Quote
Old 08-23-2007, 10:01 AM   #12
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
The stock turbo is not really a highway hard pulling turbo. You will get fast spool and good responce in the lower gears and that is about it. If you want a turbo for highway pulls it's time to upgrade.
JMK508 is offline   Reply With Quote
Old 08-23-2007, 01:53 PM   #13
Kaldar142
Member#: 151090
S197 boosted V8 FTW
i see, i do alot of backroad runs and some autox and do plan on road courses so response and spool up are a big factor to me, what kind of turbo do you think i should go with? i want my car to be faster then most cars on the street but i also want good drivability and response... what do you guys think i should go with?
Old 08-23-2007, 02:33 PM   #14
WOR440
Member#: 106807
---> 2011 EVO X
I believe TXS tunes on a Dynapack
WOR440 is offline   Reply With Quote
Old 08-23-2007, 03:07 PM   #15
KOERLONIOUS
Member#: 120129
Congratz, it always feels good to get a new tune....
KOERLONIOUS is offline   Reply With Quote
Old 08-23-2007, 03:22 PM   #16
bbong
Member#: 141258
2006 Evo 9 GSR
GG
Very nice numbers, what's next for you?
bbong is offline   Reply With Quote
Old 08-23-2007, 03:56 PM   #17
djdimensions
Member#: 95204
2007 Toyota Prius
thats wierd i hit those #s with just a stage 2 protune no intake and no bigger TMIC.
djdimensions is offline   Reply With Quote
Old 08-23-2007, 04:39 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
different dyno different location different temp etc
And TXS' dyno reads more on the low side. Most others put down 550-600whp to hit that trap.
http://forums.nasioc.com/forums/showthread.php?t=953705
DEF trapped 128 mph putting down 450 whp at TXS
Old 08-23-2007, 05:44 PM   #19
brickhoss
Member#: 84183
1994 Geo
Prism
TXS's dyno reads a little on the high side compared to other dynos (they use a dynapack), but I certainly don't think its the highest reading dyno around. My 03 rex dyno'd EXACTLY the same numbers as your car, on pretty much the exact same setup on the same dyno. Your quarter mile should be in the 13.5-13.8 range (I'm sure it could be a little better/worse depending on your driving and the track you run at) at about 101-102ish. That's a sweet daily driver setup, I loved my car at those power levels for almost 2 years.
IMHO The intake and bigger TMIC do not really make a huge difference in your numbers on the dyno w/ that sort of setup. I saw a graph of a guy who came in the day after I dyno'd mine who had stock TMIC and intake and dyno'd exactly the same. I did notice a difference after some time at the track, because the heatsoak seemed to be a much bigger issue with the tiny stocker.
Good numbers man! Very little lag, and super fun to drive. It drove very similar to my small-block camaros in acceleration characteristics.
brickhoss is offline   Reply With Quote
Old 08-23-2007, 09:03 PM   #20
Kaldar142
Member#: 151090
S197 boosted V8 FTW
I was thinking of a 18G turbo, possibly a 16G or a VF34 and all the rest of the bolt ons and i might switch over to FMIC.
but before that, i'll be upgrading my wheels/tires, brakes and suspension (first is swaybars/endlinks)
Old 09-22-2007, 06:42 PM   #21
Kaldar142
Member#: 151090
S197 boosted V8 FTW
bumpppppp
um
wheres a stock td04 turbo sopposed to hit full boost by on a tuned setup like mine? because i seem to be hitting it around 3500rpms ... seems a bit high, if im doing 5mph and stomp it in first gear, it takes a bit for it to hit boost.
i DO have an exhaust leak somewhere between the manifold/uppipe or uppipe/turbo, i dont think its a big one but i know i have one, would that cause my problem?
Old 09-22-2007, 07:10 PM   #22
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
yes! pre turbo leaks affect spool up time, even small ones.
Old 09-23-2007, 02:24 PM   #23
Kaldar142
Member#: 151090
S197 boosted V8 FTW
would it make me lose power or just take longer to spool? because ive noticed im getting boost by 3400-3800 on the td04 lol
my car was tuned by jermaine at turboxs and he does excellent work so i know its not my tune
Old 09-23-2007, 02:34 PM   #24
jdmgto
Member#: 159008
1999 2.5 RS-swapped
good numbers!!
jdmgto is offline   Reply With Quote
got my car tuned at Drift Office today... suberdave North West Impreza Club Forum -- NWIC 2 01-01-2009 01:13 AM
Got the car tuned today Rodan Texas Impreza Club Forum -- TXIC 12 03-12-2004 10:59 PM
So I had my car dyno tuned today... Need4Boost Proven Power Bragging 15 04-14-2003 10:47 PM
Got the Car tuned today Jon Martin Texas Impreza Club Forum -- TXIC 3 03-29-2003 03:04 AM
So, 2manycars got his car tuned today jetfan8178 Tri-State Area Forum 2 11-23-2002 11:36 PM
