Old 12-05-2001, 11:26 AM   #1
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
Question Which Synthetic to use?
Hey everyone, I am doing my first oil change on my WRX and its my first one doing myself (only 3k miles).
I know I want to put a synthetic brand in but I dont know a thing about what _w_ (ex: 0w40, 10w30). I live in pittsburgh pa and it can get pretty cold here, down to about 10 degrees or colder if its a bad winter.
I was planning on changing it today so if I could get any help on what oil to go buy. I was thinking of using Mobil one as well.
Last, do I have to buy an oil filter from subaru or would they sell them at a store like advance auto parts?
Bryan
2k2 is offline   Reply With Quote
Old 12-05-2001, 12:09 PM   #2
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Mobil 1 10w-30 seems to be a popular choice. You can even use 5w-30 since it flows better at start-up during cold weather. Check out this link for more info.
I personally like the OEM Subaru oil filter (made by Purolator). Plus, if you use Subaru oil filter, then you won't get a lecture from the service department if you need to take your car in for service.
Richard
Richard L. is offline   Reply With Quote
Old 12-05-2001, 05:24 PM   #3
GOT_WRX
Member#: 7241
I put Mobile 1 10w30 and it is really good. I could feel the difference right away for real.
It runs more smoothly and especially at very low rpm, the car doesn't bog anymore.
I put in the oil for the 7500 mile oil change, installed fumoto valve, and used OEM filter (with gasket). No leaking, runs fine.
Definitely I'd recommend this oil.
GOT_WRX is offline   Reply With Quote
Old 12-06-2001, 01:49 AM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
If not too late I'd hold off on going synthetic. Most people recommend waiting until about 10k miles to switch. It may be total hooey, but then again maybe not.
Chalk up another vote for Mobil 1 10w30, and the Purolator PureOne PL14460 filter, the 2.0 might use a different filter, but I doubt it. The PureOne is a crazy metallic blue. Way cool filter.
CosmoTheCat is offline   Reply With Quote
Old 12-13-2001, 12:02 AM   #5
chileewili
Member#: 13080
2002 wrx waggy
my choice is Amsoil all the way with a oem filter. do a search for mobil 1, there's been some long discussions about this subject.
also, check out amsoil.com and see some of the tests they did, perhaps it will keep you from going to the dark side (mobil1. hehe).
chileewili is offline   Reply With Quote
Old 12-18-2001, 08:43 PM   #6
javalee
Member#: 11006
2002 wrx wagon
black
Default Re: Which Synthetic to use?
Amsoil 0-30
its expensive.. but great product
javalee is offline   Reply With Quote
Old 12-19-2001, 09:09 AM   #7
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
I have easy access to any Motul product, so if SWRT uses it I guess I will too! I'll be putting in Motul RBF 600 brake fluid this weekend, and my next oil change (just changed 500 mi. ago) will most likely be a switch to Motul. I always use the OEM filters and replace the crush washer with every change too.
Orion is offline   Reply With Quote
Old 12-20-2001, 03:27 PM   #8
subarurabbit
Member#: 4083
2011 OB 3.6R
I've got different grades of Amsoil running in my different Subarus.
daily driver: 5w-30 xl-7500 stock filter. Switching to Amsoil soon - has run 0w-30 for over a year.
WRX : 5w-30. Amsoil SDF-20 filter.
legacy #2: 5w-30. Amsoil SDF-20 filter.
legacy #3: 10w-30. Amsoil SDF-20 filter.
Roger
subarurabbit is offline   Reply With Quote
Old 12-20-2001, 09:27 PM   #9
Usacjudge
Member#: 11628
2004 VW R32
Deep Blue Pearl
I use Mobile 1 5w30 right now, it gets cold in Iowa
Usacjudge is offline   Reply With Quote
Old 12-30-2001, 04:03 PM   #10
mturmel
Member#: 2473
World Rally Blue
Default Motul...
I'll be putting in Motul 10w40 in my next oil change... I also have the RBF 600 brake fluid, good stuff!
Matt
mturmel is offline   Reply With Quote
Old 12-30-2001, 10:26 PM   #11
AutoXr
Member#: 2047
'04 Audi S4
Red
I use Castrol Syntec 5w50 and have had no problems with it winter or summer. I usually change at 5K miles.
AutoXr is offline   Reply With Quote
Old 12-30-2001, 10:51 PM   #12
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Here is an interesting reading about Castrol Syntec:
http://www.pecuniary.com/newsletters...csdefined.html
Old 01-01-2002, 09:28 PM   #13
stikboy
Member#: 6697
2011 WRX 5-door
Look-At-Me Red
Default Mobil 1 all the way
Yeah, I know that it is too late for input, but the line was just screaming for me. I use Mobil 1 5w-30 in my car. I change it anywhere between 6000 and 7500 and it works great. Living in Wisconsin, the 5w-30 lets the engine start really easy and the mileage doesn't suffer too much. (Unless it is really friggin' cold, like the 3 degrees it is outside right now!!!)
stikboy is offline   Reply With Quote
Old 01-02-2002, 11:11 AM   #14
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default Castrol Syntec
Get back to us when you have 300k miles on your car.
I tried Castrol Syntec 5W-50 once and I am sorry I did. I had a lot of valvetrain noise on cold mornings. If you look at the specs, you'll realize that Castrol Syntec 5W-50 flows more like 20W-50 oil in low temperatures. Hydrolic cam followers starve for oil during warm up in cold weather. Lots of valvetrain noise and probably lots of wear. That aside, everybody knows that Castrol Syntec is not really synthetic at all. It costs as much as Mobil 1 but it's not synthetic.
I am sticking with what Subaru recommends from now on -- 5W-30. My engine sounds a lot healthier. I use Mobil 1 all the time.
I really don't get why people use 10W-30 in their EJ25s when Subaru clearly recommends 5W-30 as the preferred weight. I use 10W-30 in my EJ18 because that's what Subaru recommends for that engine.
vvk is offline   Reply With Quote
Old 01-02-2002, 04:29 PM   #15
CosmoTheCat
Member#: 3409
98 My FMIC
Because it's what most stores carry. Some of the places I get my oil at have various viscosities of Mobil 1, but others only carry 1 choice. Besides. 5W-30 is "preferred" for temps ranging from 100 to below -20. 10W-30 and 10W-40 are the recommended weights for temps ranging from -5 to 100+. Severe duty usage vehicles are supposed to use 30, 40, 10W-50, 20W-40, or 20W-50. I figure my driving is closer to that of severe duty when compared to my grandmother (who the book is written for), so I should be using a bit more durable oil. From everything I've gathered about oil, the wider the viscosity spread, the more crap is in the oil, making it less durable.
If I were in a location that frequently dipped below 0, I'd run the thinnest oil I could find during winter, but the fact remains that Seattle doesn't see below 32 very often. It also doesn't get above 100 often at all, but that goes back to the viscosity additives.
Old 01-02-2002, 08:59 PM   #16
mlambert
Member#: 13831
is normal Mobil oil the same as Mobil 1 ?
i just got 4 quarts of mobil 10w30...come to think of it, I didnt even check the capacity. I hope it doesnt take more than 4 quarts!
mlambert is offline   Reply With Quote
Old 01-02-2002, 09:56 PM   #17
mturmel
Member#: 2473
World Rally Blue
Default Capacity...
Well,
The WRX needs 4.5 liters or 4.75 quarts, bummer!! Motul sells its oil in 2 liter cans only...
Matt
Old 01-03-2002, 02:48 AM   #18
CosmoTheCat
Member#: 3409
98 My FMIC
Mobil = dino oil ~$1/quart
Mobil 1 = synthetic ~$5/quart
Old 01-03-2002, 01:40 PM   #19
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
If you switch to Mobil 1 synthetic motor oil, you may experience louder valvetrain noise. Here is a reason why:
Mobil 1 SAE 5w-30:
Viscosity, cSt @ 40C: 53.0
Viscosity, cSt @ 100C: 9.9
Viscosity Index: 162
Pennzoil Synthetic with Pennzane SAE 5w-30:
Viscosity, cSt @ 40C: 57.4
Viscosity, cSt @ 100C: 9.87
Viscosity Index: 159
Quaker State Full Synthetic SAE 5w-30:
Viscosity, cSt @ 40C: 62.05
Viscosity, cSt @ 100C: 10.17
Viscosity Index: 151
Royal Purple SAE 5w-30:
Viscosity, cSt @ 40C: 62.5
Viscosity, cSt @ 100C: 10.5
Viscosity Index: 160
Redline SAE 5w-30:
Viscosity, cSt @ 40C: 65.0
Viscosity, cSt @ 100C: 10.6
Viscosity Index: 153
AMSOIL SAE 5w-30:
Viscosity, cSt @ 40C: 63.4
Viscosity, cSt @ 100C: 11.7
Viscosity Index: 182
Richard
Edit: added Redline 5w-30
Old 01-06-2002, 11:40 AM   #20
Tex-WReX2
Guest
Member#:
Default Re: Capacity...
Originally posted by mturmel
Well,
Matt
Unless they are different from there motorcycle packaging, I don't see why you can't find motul in quarts. It what I use in both of my street bikes.
Old 01-08-2002, 11:51 PM   #21
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
Question
where can i pick up amsoil oil?
SQUAD_907 is offline   Reply With Quote
Old 01-09-2002, 12:33 PM   #22
tofu86
Member#: 12221
2002 wrx wagon
wr blue
you can get it from www.amsoil.com at the online store. I think you need a dealer number which I know a lot of people on bimmer.org or bimmerforums.com have.
tofu86 is offline   Reply With Quote
Old 01-09-2002, 01:19 PM   #23
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
You don't need a dealer number in order to buy AMSOIL synthetic oil from their online store.
I recently switched to AMSOIL 5w-30 at 30K miles, and my RS is running extremely smooth and quiet. No leaks.
Richard
Old 01-09-2002, 03:18 PM   #24
mturmel
Member#: 2473
World Rally Blue
Default SI system...
Tex-WReX2,
We use the SI system up here, remember? So does Japan (Subaru...) and France (Motul...). I could not find a *cough* quart of Motul anywhere, only 2 liter can. Where did you get yours??
Matt
Old 01-09-2002, 04:44 PM   #25
Tex-WReX2
Guest
Member#:
Default hmmmmmmmm
Let me check. I picked up the oil from a local moto shop. Maybe it is repackaged in the states? I have never tried to order it for any of my vehicles.
J
Turbo motor into Porsche 914. Which motor to use and where to get it? pktzygt Subaru Conversions 18 11-08-2008 04:52 PM
Which gauge to use to monitor my O2 bottle jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-06-2004 05:23 PM
Which tool to use to cut a urethane greddy lip? bigbird Interior & Exterior Modification 4 04-29-2003 07:51 AM
Which Wagon to use Stubaru New England Impreza Club Forum -- NESIC 2 07-15-2001 06:24 AM
