Old 08-22-2007, 11:31 AM   #1
Cone Klr
Member#: 73072
02 wrx, 04sti
WRB squared!
Question oil pump, accusump install
technical question, has anyone here tapped into the oil ports at the bottom of the oil pump on a 2.0 or 2.5? I believe one is pressure and the other return. was going to hook an accusump up to them, seems the easiest place and most direct to the oil circuit. does anyone see a possible problem with doing so?
Cone Klr is offline   Reply With Quote
Old 08-22-2007, 12:41 PM   #2
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Check out my pics on posts 151, 160, & 164
http://forums.nasioc.com/forums/show...1176430&page=7
- I think you can plumb thru the pressure port and it should work OK.
altough, if the pump regains pressure, then the Accusump would be working against the flow to go thru the outlet port, albeit just for a very short run.
- The rear or front oil gallery ports on top of the block are closer to where the oil needs to be deliver. You can use a -10AN or -12AN / 18mmx1.5 adapter ( http://www.jegs.com/p/Earl%27s/758331/10002/-1 )to plumb the Accusump thru one of the ports. I'll be plumbing mine thru the rear gallery port, as that will be the 1st one to see the pressure drop.
- Also the hose routing/plumbing might be easier thru the top of the block, specially if you have a FMIC.
engineerx is offline   Reply With Quote
Old 08-22-2007, 12:53 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
- The rear or front oil gallery ports on top of the block are closer to where the oil needs to be deliver. You can use a -10AN or -12AN / 18mmx1.5 adapter to plumb the Accusump thru one of the ports. I'll be plumbing mine thru the rear gallery port, as that will be the 1st one to see the pressure drop.
Rear port is the same place I am planning plumbing mine in
mick_the_ginge is offline   Reply With Quote
Old 08-22-2007, 04:13 PM   #4
Cone Klr
Member#: 73072
02 wrx, 04sti
WRB squared!
Default accusump
cool thanks guys the rear is where the oil pressure guage is currently located but will soon be moved to make way for the accusump. thanks again for the quick response.
Anything Worth Doing to Oil Pump Before Install? williaty Built Motor Discussion 11 09-30-2009 04:49 PM
Accusump and oil pump question apexslider Built Motor Discussion 5 09-24-2009 02:33 AM
FS: NIB Cosworth Subaru EJ25 High Volume/Pressure Blueprinted Oil Pump & install kit ill-luzion Engine/Power/Exhaust 4 10-10-2008 10:55 AM
Accusump Install thejean Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 04-03-2007 03:43 PM
Help! Accusump installation... WRXBob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-17-2006 03:29 PM
