Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 08-22-2007, 05:34 PM   #1
Optical NZ
Member#: 120463
Default EJ25 open deck block build
Does anyone have any advice on things you can do to strengthen an open deck block for a reasonably high HP build? 400 -450hp
Ive built a few 2L engines up before, but not a 2.5. The only block available in my area is an open deck. Are there things you can do to strengthen the bores? Or will they we ok for that power level?
im not going to go to the effort of sleeving. Will maybe look into doweling the water jacket if it has been proven to be effective?
Thanks
Optical NZ is offline   Reply With Quote
Old 08-22-2007, 09:29 PM   #2
gc835
Member#: 78080
2001 impreza
red biatch
forged rods and pistons and a semi or fully closed deck
gc835 is offline   Reply With Quote
Old 08-22-2007, 09:51 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I know of guys running open deck EJ25's to the tune of 400+whp and haven't had issues
Old 08-22-2007, 09:58 PM   #4
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
use arp head studs..ej25d's have headgasket problems in NA form..boost will add to the problem even more.
mxpunk is offline   Reply With Quote
Old 08-22-2007, 11:25 PM   #5
gc835
Member#: 78080
2001 impreza
red biatch
very true with the hg deal. just be care ful with the boost
Old 08-23-2007, 01:37 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Pinned cylinder walls.
Old 08-23-2007, 01:48 AM   #7
gc835
Member#: 78080
2001 impreza
red biatch
wow pretty nice
Old 08-23-2007, 01:49 AM   #8
gc835
Member#: 78080
2001 impreza
red biatch
why not just start with a semi closed block??? less hassle they are all over the place
Old 08-25-2007, 07:23 AM   #9
Optical NZ
Member#: 120463
well the problem is there are no semi closed blocks that i can get my hands on in New Zealand..
im interested in these strengthening tricks
do you have any more pics Reddevil? are they pinned at top and bottom?
ive thought about tig'ing some metal to brace the cylinder walls, but im unsure how sucessful this would be.. might warp the block and ruin it?
Old 08-25-2007, 11:06 AM   #10
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Just do forged internals..you don't need to make the block stronger unless you're daily driving 50 PSI or so IMO.
Old 08-25-2007, 08:34 PM   #11
Optical NZ
Member#: 120463
the car will be tracked at around 20psi, does that change anything?
Old 08-26-2007, 04:47 AM   #12
bugeyes
Member#: 64494
2001 V7 sti
Here is Australia we have the same problem. There is really only the open deck 2.5 available and they are hard to get also.
Here is what we do.
Overlay a head gasket over the deck. This will show you where to fit the dowel pins so they dont impede water flow.
The two large central pins are 19mm diameter and the smaller ones are 10mm diameter. All dowels are 20mm deep. Dowels are made of machining grade aliminium rod. Readily available and cheap.
Mind you after fitting these the bore will be out of round so a size up in piston will be required. Only go one size up so you leave as much metal in the block as possible.
When fitting the dowels do not take too much out of the inner section of the casting, You do not want to make the bore section weak where the pin is.
Typically the dowel pins are fitted with a thou or two interference fit. You could even leave them in the freezer to shrink them a fraction before fitting.
Make the pins about 22mm long so they are machined flat to the deck when the deck is finished off.
I have attached a pic of what it looks like when its done.
We have guys running high tens at the drags on these blocks so it definately stiffens things up.
If you need more info send me a PM.
bugeyes is offline   Reply With Quote
Old 08-26-2007, 05:38 AM   #13
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I just used brass rod, used a hand drill and reamer, then used a small lathe to mill the rods to press fit.
I did not machine the bores the first time as it was an experiment, and "out of the box" it was running 12.5 @ 112mph.
I have since actually had the block bored to 100mm pistons.
Old 08-26-2007, 07:21 AM   #14
Optical NZ
Member#: 120463
very interesting thanks for the input.
i'll have a chat to some block machinists and see if they are willing to have a go !
oh, do you just put these dowels in at the top of the block? any point in having the at the bottom too, if not?
Old 08-26-2007, 01:40 PM   #15
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I've always wanted to try this stuff : http://www.hardblok.com/info.html
You have to use wax/soluable rods to maintain a water pass through while the stuff sets. You then melt the rods out to remove them. Basically you turn an open deck into a closed deck
They say you can use it on aluminium blocks
mick_the_ginge is offline   Reply With Quote
Old 08-28-2007, 05:44 AM   #16
bugeyes
Member#: 64494
2001 V7 sti
The bottom doesnt need anything as its already supported by the block casting. By having the dowels only 20mm deep it allows for water to pass around the block without restriction.
Open deck EJ22 build --> maybe stroker? deamon64 Built Motor Discussion 11 12-23-2007 01:31 PM
Open deck EJ22 build --> maybe stroker? deamon64 Built Motor Discussion 0 12-11-2007 02:11 PM
EJ25 open deck block bottom end on WRX john banks Normally Aspirated with bolt-on Forced Induction Powertrain 14 02-13-2003 05:42 PM
EJ25 open deck block on WRX heads john banks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-24-2003 08:18 AM
Difference between closed deck and open deck blocks Joe Hogan Normally Aspirated Powertrain 2 03-13-2001 07:34 AM
