Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 08-22-2007, 05:23 PM   #1
Member#: 117017
03 2.0fpred wrx!!
Default the utec?
hey guys any info on this will be helpful. i have heard mention that the utec will not allow you to run tgv deletes, is this true? if so is there anything i can do to allow the utec to work properly? sorry i did a search and came up with nothing.
spoolinred is offline   Reply With Quote
Old 08-22-2007, 08:07 PM   #2
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
That's because you probably searched in the wrong place, and definitely posted this in the wrong place. Check the Engine Management forum.
wrxfactor is offline   Reply With Quote
Old 08-23-2007, 01:44 PM   #3
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Why would it not let you run tgv deletes. Utec doesnt control them. U'll be fine as long as you tune for it. idle primarily.
NITROS is offline   Reply With Quote
Old 08-23-2007, 04:51 PM   #4
Member#: 60794
2007 Solstice GXP
The UTEC will not eliminate any associated CELs from running TGV-less. You have two options IMHO:
1.) Leave the rods in place, and the sensors connected.
2.) Buy a Tactrix cable, and reflash your ECU to eliminate the codes.
Oh, and wrong forum. This question should be posted in the EM -> UTEC forum.
rewt is offline   Reply With Quote
does the utec use the factory boost solenoid? whiterabbit Engine Management & Tuning 17 03-17-2003 06:40 PM
is the abc for the utec necassary? Otaku64 Engine Management & Tuning 8 02-25-2003 02:35 AM
Does the UTEC always come with the ABC? Wrxified Engine Management & Tuning 1 02-23-2003 10:52 PM
Does the utec/unichip take over timing control or modify the signal to the ECU? trhoppe Engine Management & Tuning 1 10-21-2002 12:18 AM
Can the UTEC switch maps "on the fly"? fastburro Engine Management & Tuning 2 10-07-2002 01:07 PM
