Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 08-22-2007, 07:09 PM   #1
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Default 05 Fp Green Iwg Tmic
I actually tuned this car about 1 year ago.. He added 1 step colder plugs and we switched to a TXS Map sensor. I did a few pulls and to my suprise it made about the same power.. plus 5 more whp..
PUMPGAS
FP green with Internal Gate
Helix TMIC
APS TBE
APS Intake
TXS UTEC + SD
1 Step colder plugs
PE850s
Junior2JZ is offline   Reply With Quote
Old 08-22-2007, 07:18 PM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Race gas?
JMK508 is offline   Reply With Quote
Old 08-22-2007, 07:20 PM   #3
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
93 octane
Old 08-22-2007, 07:20 PM   #4
MrTransAm
Member#: 80744
2005 Subaru STI
Wow,.that's pretty good,.it took Meth for me to get 408hp/407tq.
I'm running almost identical setup.
In fact, I'm seeing more that I did.
Jezz,.you did good brother.
What's the boost set at?
MrTransAm is offline   Reply With Quote
Old 08-22-2007, 07:20 PM   #5
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
boost?
BuggeyEYED is offline   Reply With Quote
Old 08-22-2007, 07:22 PM   #6
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Sorry. forgot to post the boost.. 22psi
Old 08-22-2007, 07:22 PM   #7
BuggeyEYED
Member#: 101691
97 Supra TT
dam..i cant wait to see u in a few days for my tune.
Old 08-22-2007, 07:39 PM   #8
GhoSTI
Member#: 86488
2004 STi
tmic, pump gas?
im sorry dude, but im calling bs on these posts from you lately.
GhoSTI is offline   Reply With Quote
Old 08-22-2007, 07:54 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by GhoSTI View Post
tmic, pump gas?
Its not Junior's fault... that dyno is set up to read really high. It did it when Al was using it and its still doing it now. Get rid of that lame correction factor!
BTW, why is this curve so jumpy? I'm not used to seeing DD curves like this.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 08-22-2007, 08:39 PM   #10
fourmicah
Member#: 128760
2015 STI
tmic, pump gas?
Remember they are just numbers. Every dyno is different. Plus there are cars out there that run good numbers on TMIC and pump gas. What's more important is how the car drives and his 1/4 times.
fourmicah is offline   Reply With Quote
Old 08-22-2007, 08:40 PM   #11
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Yeah. The graph looks amazing. The tuning must be spot on and I know it is because junior tuned it. However. I think you need to turn the dyno back down to factory specs. Its turned up 15 to 20% is my guess. THe only way to explain the small dips and jumps is that the utec is probably toggling between load sites cause a .5 to 1 degree change in timing. I would have to see a log. However. You would never feel this on the road and its not a big deal. Its hard to get a UTec to run super smooth because its a 10X10 map.
C
AZScoobie is offline   Reply With Quote
Old 08-22-2007, 09:12 PM   #12
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
http://forums.nasioc.com/forums/show...ighlight=green
Same car from this post.. I removed the "extra" correction that was used previously on the dyno.. Made the same power it did when I tuned it on the DynoJet... Car has always made good power.. The dips are like Clark mentioned small shifts between load sites.. You dont feel them on the street.
I dont want to be associated with the "other" correction factor that was used.. I didnt go from dyno to dyno trying to match other Dynos.. I could careless... This car with correction OFF makes in the 380whp range.. The car on the street is a monster.. Feels like a VF39 but with ALOT more power.. Like I have always done the 1/4mile is the measuring stick.. I made 310 with the same correction factor on a FV39 5spd car, its trapped 114.XX Almost 115
Old 08-22-2007, 09:25 PM   #13
TurboDXsti
Member#: 106671
2006 Sti
grey
Was there this morning to see this done , nice job , BTW you forget to mention the guy want's to sell , so if anyone want to see if it's for real they should buy the car.
BTW how come my dyno sheet don't get any love from my tuner guess I got to wait till I get a turbo that's worthy
TurboDXsti is offline   Reply With Quote
Old 08-22-2007, 09:58 PM   #14
Boosted98gsx
Member#: 157353
Wow, now that's impressive for pump + a 50 trim! Good tune!
Boosted98gsx is offline   Reply With Quote
Old 08-22-2007, 10:29 PM   #15
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
-- Ed
I actually tuned on this dyno last night. I make Jimmy do the pulls in 4th gear for STi's and set the correction to 1.10.. I'm not a dyno queen numbers chaser, I just like to make sure the car is being loaded properly so that the road tune goes smoothly. My guess is that this car was pulled in third and the CF was set to 1.20 since that seems to be the DJ correction number, or at least that is what Jimmy told me.
I tuned an 06 Stage II STi which turned out 312whp and 345wtq at the settings above, and that seemed to be pretty close to what it should be making for 20psi with an Invidia Race TBE.
So long as the customer is happy, that's all that matters.
ChrisSK is offline   Reply With Quote
Old 08-22-2007, 10:30 PM   #16
The Blue Pilot
Member#: 101880
2012 Mustang GT
tmic, pump gas?
I think you're used to seeing people run these turbos on 17-18 psi, where they barely break 330-340whp. On a high reading dyno and on 22 psi, I don't have much trouble believing it. It's an FP green on an STi, after all. What did you expect ;P
The Blue Pilot is offline   Reply With Quote
Old 08-22-2007, 11:11 PM   #17
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
I use 4th as well.. I dont know why 3rd gear was previously used.. 1.15 correction as well.. Same one that we used on Boners car when it trapped 114(5SPD) and made in the 310 range.. Im the furthest from a dyno queen most of you guys know that... I wish the owner would take it to the track... but he wont..
Old 08-22-2007, 11:42 PM   #18
brickhoss
Member#: 84183
1994 Geo
Prism
Holy Hell. My FPGreen isn't even in the same ballpark as those numbers on just 93... Jebus...
brickhoss is offline   Reply With Quote
Old 08-22-2007, 11:48 PM   #19
n2oiroc
Member#: 141952
03 11 wrx/13 brz
what did yours run?
n2oiroc is offline   Reply With Quote
Old 08-23-2007, 04:45 AM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Junior,
Why do you use a correction/inflation factor at all? Why not just go with the raw DD numbers like everyone used to?
With regard to the 310whp/114mph trap correlation, while those are great numbers, they were done on a 5MT car. Not only is there one less shift involved at the very end of the track, but the WRX's are lighter as well. Its really not a fair point of reference to use for 6MT STI's.
Anyway, all that being said, I want to compliment you on this tune because the general shape of the curve looks terrific and even without the inflation factor, this car is making ~343whp. This is no small feat with an IWG, small TMIC and pump gas.
Thanks
-- Ed
Old 08-23-2007, 10:29 AM   #21
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Vaus - Jr. ran on an uncorrected unsmoothed (0) dynojet for years, he is not a stickler for numbers, but more for trap speeds. No one is questioning your road dyno software - junior also offered his dynojet comparison of the prior tune. I think this forum has turned into tuner nitpicking - Jr doesn't have anything to prove.
bren wrx is offline   Reply With Quote
Old 08-23-2007, 11:27 AM   #22
Porkchop-WRX
Member#: 33293
2011 4-door STi
Plasma Blue
Last time I was at the Shop and had my 18g+meth tuned I actually got both dyno plots for the dynojet corrected (368)numbers and the raw dyno dynamics numbers.(330) It was about 40HP difference. Junior tuned it BTW.
Porkchop-WRX is offline   Reply With Quote
Old 08-23-2007, 12:36 PM   #23
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That's approximately a 12% inflation factor .
I honestly just don't understand why tuners use inflation factors like this... especially the ones who say they're not concerned with numbers. All these factors do is exaggerate overall numbers and gains and then other tuners feel the need to do the same to keep up... Soon we'll have 600whp FP Green Cars
-- Ed
Old 08-23-2007, 12:42 PM   #24
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
-- Ed
What are you talking about? I'm tuning a 450whp VF39 StageII STi right now..
On 87 Octane.
Old 08-23-2007, 02:11 PM   #25
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Now now guys ... Like usual I will back these "inflated" numbers up... Last time the "inflation" card was thrown on the 350whp STI, I took the car to the track and trapped 115 with it...
f/s turbo xs bpv & fp green iwg actuator toyjunkie Engine/Power/Exhaust 30 04-18-2009 12:38 AM
2005 STi. FP Green, IWG, FMIC OpenECU teesutt Proven Power Bragging 38 01-12-2008 06:30 AM
FP Green/STI TMIC kb2spn Engine/Power/Exhaust 10 04-30-2007 12:07 PM
FP green w/ tmic V.S green with fmic godfather2112 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 02-24-2007 10:26 PM
Norcal: Modified Fp Green, Spearco tmic, cusco heatshield BLUE STINGER Private 'For Sale' Classifieds 12 10-28-2005 10:50 PM
