Old 08-22-2007, 06:18 PM   #1
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Default FP 3065 Pumpgas 470whp...
FP 3065
Crower Cams
Ported WRX heads
Standard size SS Valves
Springs + Retainers
Turbotrix built 2.5 block
Cosworth Oil Pump
POS FMIC( Probably the worst intercooler I have ever seen in my life )
TXS UTEC + SD
TXS 5Bar
Perrin Rails
RC 800cc
GT Spec Headers
Cooling Mist (NOT USED YET)
I actually street tuned this car.. As you can tell from the run files. It made 450 right off the street on pump gas with 20-21psi.. I turned it up tp 22psi and it made another 20whp until the stock ECU died (ground issues)... Im sure this car will make 475-490whp on plain old 93 octane.. I still have the timing very low.. I knew it felt good on the street, but it was quite the suprise to see the power it made. Next up once I get the ECU sorted I tune it on Meth and then some c-16... I expect the car to make around 520-550whp..
Junior2JZ is offline   Reply With Quote
Old 08-22-2007, 07:44 PM   #2
fourmicah
Member#: 128760
2015 STI
What is an FP 3065? Similar to an FP Red? 65 lbs compressor wheel?
fourmicah is offline   Reply With Quote
Old 08-22-2007, 07:48 PM   #3
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Damn.. 20whp from 2psi! Man.. turn it up more what else does the motor have to say
Goodluck with the rest of the tune..
PaulRex is offline   Reply With Quote
Old 08-22-2007, 08:50 PM   #4
TurboDXsti
Member#: 106671
2006 Sti
grey
Worst intercooler lol lol lol lol rofl For realz
TurboDXsti is offline   Reply With Quote
Old 08-22-2007, 08:54 PM   #5
bakka
Member#: 112072
2004 wrx
blue
Gooood job .I hope i'm not paying by hp.At least the ic is huge.
bakka is offline   Reply With Quote
Old 08-22-2007, 08:57 PM   #6
Boosted98gsx
Member#: 157353
Very nice numbers on pump gas. Add in some fuel and increase the timing though. Get some moar POWA!
Boosted98gsx is offline   Reply With Quote
Old 08-22-2007, 09:20 PM   #7
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
that will be $100 for the first hundred horsepower and $50 for each aditional horsepower after that. just text POWA to 555-2345! Must be 18 or older.
Old 08-22-2007, 09:24 PM   #8
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
nice numbers!
curious as to what turbo this might be, because now i want one.
TopEndPull is offline   Reply With Quote
Old 08-22-2007, 09:31 PM   #9
rewt
Member#: 60794
2007 Solstice GXP
rewt is offline   Reply With Quote
Old 08-22-2007, 09:34 PM   #10
WOR440
Member#: 106807
---> 2011 EVO X
Awesome numbers.
WOR440 is offline   Reply With Quote
Old 08-22-2007, 09:55 PM   #11
mixmatch
Member#: 132057
2007 STi
Urban Gray Metallic
sorry for being a turbo newb but how does this compare to the gt30r and gt35r? is this stock mount or rotated?
better fmic, sti heads, and some meth should help get the boost down a few hundred rpms right?
mixmatch is offline   Reply With Quote
Old 08-22-2007, 11:25 PM   #12
Nuked
Member#: 110329
2016 WRX Premium
ISM
It is basically a 35r compressor wheel and a 30r turbine wheel. Up to 30psi it will make about the same power as a 35r.
SQ
Nuked is offline   Reply With Quote
Old 08-23-2007, 01:25 AM   #13
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
I absolutly couldnt believe this car. I dont want to talk bad about the owner or whoever did the work to this car. The car looked 100% homemade (witch in this case wasnt a bad thing) the thing wasnt the nicest setup or the prettiest but BOYYYY did this car make some stupid numbers on low boost. I couldnt believe it!! Right off the street tune the car made some serious power with not 1 hint of knock. and it was strait 93 oct no alky or racegas or anything. Junior great job, OHHHH YEA JUNIOR YOU FORGOT TO MENTION THE STOCK EXHAUST!!!! If it wasnt stock then it was a spt but that thing had a huggeeee stock looking muffler. another 10-20 there as well i would think
Visconti is offline   Reply With Quote
Old 08-23-2007, 02:22 AM   #14
Member#: 156622
Good job as usual JR it is a pleasure having you ! Keep up the good work !- Jimmy
JK@THESHOP is offline   Reply With Quote
Old 08-23-2007, 04:18 PM   #15
wrxhard
Member#: 108091
Any pics of this car anywhere?
wrxhard is offline   Reply With Quote
Old 08-23-2007, 05:37 PM   #16
Sypher
Member#: 106366
2006 WRX
More info would be nice, rotated set up? Stock location just with the flange cut and a custom downpipe? What what? I was thinking of doing something simlier but probably abit more ghetto by just cutting off my stock flange and welding on a T3 4 bolt flange and making a custom downpipe that just dumps haha.
Sypher is offline   Reply With Quote
Old 08-23-2007, 05:45 PM   #17
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
im confused...what cams??
jigga is offline   Reply With Quote
Old 08-23-2007, 07:09 PM   #18
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
I cant wait to see pictures of this ugly car.
Cam gears?
DeliciouSpeed is offline   Reply With Quote
Old 08-23-2007, 09:30 PM   #19
Von Pierre
Member#: 155606
wow, impresive
Von Pierre is offline   Reply With Quote
Old 08-23-2007, 10:01 PM   #20
TurboDXsti
Member#: 106671
2006 Sti
grey
me too want to see some pics , the owner should post some pics lol
Old 08-23-2007, 10:35 PM   #21
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
When I email FP for this turbo I got this replay from Amber Stice ...
I was considering changing my broken GT30R with this the GT3065...
"Jose,
For starters I think you don't quite understand what our FP3065 turbo is
in comparison to standard Garrett GT ball bearing turbos. The FP3065
turbo uses the Garrett GT30 CHRA and compressor housing and mates up to
our Forced Performance turbine housing. This turbine housing has a
standard DSM 4 bolt inlet and uses a 2.5" V Band style outlet. This
turbine housing also has a wastegate mount directly on the turbine
housing for mounting a TiAL 44m V Band wastegate to it. Our FP30 Turbine
Housing only comes in a .70 A/R.
If you are wanting something similar but wanting to use the .82 turbine
housing, what you would be wanting to run would be the Garrett GT3082
turbo that you have the option of picking a .63 or a .82 turbine
housing. This turbo uses the same CHRA as our FP3065, but instead of
using our FP30 turbine housing, it uses the standard Garrett T3 style
turbine housings. Cost on the Garrett GT3082R Turbo is $XXXXX
In my opinion if you are looking for more power, I would go with the
Garrett GT3582R as the Garrett GT3082R or FP3065 would be more of a
lateral step power wise for you.
If you have any other questions, please let me know.
Thank you,
Amber"
AXA is offline   Reply With Quote
Old 08-24-2007, 12:08 AM   #22
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
nice numbers now show us the car!!!!!!! PLEASE!!!!!
Chp_Stix is offline   Reply With Quote
Old 08-24-2007, 01:05 PM   #23
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Woohoo... Heads and cams show what they can do. Thats killer JR. That 3065 pretty much sucks but it sure is working great on this car. Cant wait to see this girl turned up on C16.
Clark
AZScoobie is offline   Reply With Quote
Old 02-24-2008, 01:11 AM   #24
kike_ej20
Member#: 145440
MY96 WRX GT2835-ProS
EJ20G 2123cc!!
Like I always thought...best pump gas turbo.
kike_ej20 is offline   Reply With Quote
Old 02-24-2008, 10:04 AM   #25
TurboDXsti
Member#: 106671
2006 Sti
grey
Clark
Yea what he said , any updates on this project
FS : ID 1000cc,Perrin big maf,FP Red, hottwrx02 MAIC Private Classifieds 8 04-25-2011 02:43 AM
WTB fp 68hta 07subywrxtr Private 'Wanted' Classifieds 3 06-04-2010 11:32 PM
485hp Pumpgas/Meth with an FP-Red TopSpeed Proven Power Bragging 25 02-24-2006 10:04 PM
FS- Brand new never used Turbo FP 3065 Jesus Private 'For Sale' Classifieds 0 08-24-2005 02:20 PM
DEI Neodynium 3065 components elemental Car Audio, Video & Security 11 09-04-2001 09:15 PM
