Old 08-22-2007, 11:08 PM   #1
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Default Element GT52, Cams Pump + Meth
Dahellwidu's Car on here..
06 STI
Element Gt52
STOCK HEADS with Cosworth Cams
Pe850s
Perrin EL header
Perrin FMIC
CoolingMist
UR Up-pip w/ Tial 44mm
HKS Carbon TI
HKS (POS) DP
Utec + SD
26-27psi
Car has a book shelf for a power band.. Lets see what it traps.. No BS correction factors either.. Same one I have been using, wich trapped 114 w/ 5spd WRX making 310 or so...
Junior2JZ is offline   Reply With Quote
Old 08-22-2007, 11:18 PM   #2
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
nice numbers
silverwrx666 is offline   Reply With Quote
Old 08-22-2007, 11:19 PM   #3
fourmicah
Member#: 128760
2017 STI
Nice work Junior, sweet tune. Does the GT52 always spool that slow? 5K seems a little high but I don't have that much experience with this turbo.
fourmicah is offline   Reply With Quote
Old 08-22-2007, 11:21 PM   #4
sperry7
Member#: 110079
06 WRX
Black on Black
Wow that looks like a fun curve
sperry7 is offline   Reply With Quote
Old 08-22-2007, 11:22 PM   #5
n2oiroc
Member#: 141952
15 legacy 16 wrx
5k is peak torque, not peak boost.
n2oiroc is online now   Reply With Quote
Old 08-23-2007, 12:04 AM   #6
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
wow, those cams are killing the low end
All4bSpinnin is offline   Reply With Quote
Old 08-23-2007, 12:35 AM   #7
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
^^ man that thing is going to lay down some times!
Hey JR how do those cams sound?
PaulRex is offline   Reply With Quote
Old 08-23-2007, 12:49 AM   #8
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
They sound nice... but you can barely tell they are there. When you start turning the RPM though they wake up big time. The "lag" is due to the cams, but they are not that bad.. Also the payoff on the top side is HUGE as you can see in the graph.
Junior
Old 08-23-2007, 02:16 AM   #9
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
nice tune junior. I saw the very last pass you made with it, car sounded realy good. For some reason even with the perrin headers the cars still maintain that a little of that rumble, if if you go ewg all you will here is a loud rush of air anyways. The car didnt sound that lopy at idle either, good luck at the track sat "Dahellwidu".
Visconti is offline   Reply With Quote
Old 08-23-2007, 03:24 AM   #10
Member#: 156622
+1 JR , Keep up the good work - Jimmy
JK@THESHOP is offline   Reply With Quote
Old 08-23-2007, 11:50 AM   #11
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Nice top end! can't to see what it runs in the 1/4 (hopefully it does)
aps2fast4u is offline   Reply With Quote
Old 08-23-2007, 12:51 PM   #12
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
is that car gaining over 30whp with the cams on the top end??
Old 08-23-2007, 07:26 PM   #13
ferrari2479
Member#: 156121
R those whp numbers.I thought the gt52 were only rated at 390whp.
ferrari2479 is offline   Reply With Quote
Old 08-23-2007, 07:32 PM   #14
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
yes whp
Old 08-23-2007, 07:49 PM   #15
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
^^^ From Element's website:
"Typically we see 20 psi by 3600-3800 rpm tuning with the Hydra with pump gas power in the 375-400 whp range. Both housings are completely ported for increased flow and wastegate performance. Race gas power is in the 475-500whp range.
Expect to achieve full boost with the proper modifications and a quality tune between 3500-4000rpms. Fuel upgrades for this turbocharger and proper engine management are required."
Old 08-23-2007, 07:55 PM   #16
lev98
Member#: 140529
01 Ferrari 360 spy
Nice numbers man.
lev98 is offline   Reply With Quote
Old 08-23-2007, 09:12 PM   #17
DaHellWidU
Member#: 67496
2011 Legacy GT
Thanks. This thing hauls, im headed out to englishtown this weekend for the evo vs sti shootout. ill post up the 1/4 mile times, on my "previous tune" on this turbo w\ 360whp i did 12.3 @115.3. hopfully i can dive into 11's with this j-tuned sti.
DaHellWidU is offline   Reply With Quote
Old 08-26-2007, 03:05 PM   #18
PaCmAn84
Member#: 136675
Yo this car did an 11.9 @116.... it was the FASTEST STI THERE .. so for ne one hating on Jr and his tunes are crazy.. if it was night cooler and less humid i think he could have done 11.7 or better this car is still on stock tires... Jr did his thing with the tune and my boy did his thing beind the wheel ..... THE FASTEST STI THERE!!!!
PaCmAn84 is offline   Reply With Quote
Old 08-26-2007, 03:32 PM   #19
keaniegenie
Member#: 94494
2005 Element 92x
Nice.
I'm guessing you're typing from a cell phone with all the typos.
keaniegenie is offline   Reply With Quote
Old 08-26-2007, 04:24 PM   #20
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Yesterday was so bad for racing, it was so hummid all the cars were feeling it. Congrats on the time man, I got to see your run looked good. Take it back to the track on a cooler day and see what it can realy do.
Old 08-27-2007, 05:46 AM   #21
STi*guy.kiev
Member#: 117854
2003 spec c
11.9 isn't all that impressive!
A friend with the following combo:
03 ej207 sti w/ ross pistons,
gt52
ur 44 ewg kit
blitz fmic
kakumei dp/ vibrant cbe
big maf
pe800 lines rails walbro
ran a 11.7 on the street on bold contis
STi*guy.kiev is offline   Reply With Quote
Old 08-27-2007, 05:47 AM   #22
STi*guy.kiev
Member#: 117854
2003 spec c
with an avcr it holds 22psi to 8k rpms
Old 08-27-2007, 07:29 AM   #23
STimo
Member#: 110273
450 whp 30R STI
[email protected]
This is obviously a high reading dyno, and i thought dynojets read higher .. I ran close to the same e.t./trap making a good 70whp less on a dynojet, and it was almost 100 were i ran with ~40mph headwinds n ~60mph gusts.. IMO an 11.9 isnt impressive if the car put down 460whp, even if it was bad conditions.. Not saying the car is tuned poorly or anything, because i have heard good things about JR, but i expect more out of 460whp, just a very high reading dyno obviously..
STimo is offline   Reply With Quote
Old 08-27-2007, 09:21 AM   #24
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
the sacrifice you made on the low end isnt worth what you gained up top unless the car is primary drag racing
Old 08-27-2007, 10:45 AM   #25
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
I felt the same way.... I don't think the car was running to the full potential.. It was going 92-93 to the 1/8 so it was definitely down on some power. When we took it out it did not feel like a 116mph car... I would have guessed it for a 120-122mph car. Going to have to look over the car and see whats up... Either way kick ass driving for MR. DAHELLWIDU, 1.66 60 ft.. and also Congrats for having one of if not the fastest Subie of the day.
junior
2006 STi - ELEMENT GT52 / STOCK MOTOR / PUMP GAS AMR Proven Power Bragging 52 03-28-2008 02:18 AM
Element GT52 Turbo/Hydra/Hydramist 436 whp Element Tuning Proven Power Bragging 60 10-26-2006 12:05 AM
AZ: Element GT52 Turbo, TXS FMIC, Tial 38mm WG hulkmanj99 Engine/Power/Exhaust 5 10-24-2006 10:40 PM
Element GT52 Bolt-on Turbocharger WTillIDIE Proven Power Bragging 11 10-23-2006 02:39 PM
element gt52 redrex2002 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 70 10-19-2006 04:07 PM
