Old 08-23-2007, 12:18 AM   #1
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Default What's the best way to remove dust from clean exterior?
I just moved to Phoenix and the dust is a real bugger. I keep my car freshly cleaned but each day there's a new layer of dust. I've tried those static dusters, but they just push the dust around.
Will I have to QD it every day or is there another type of duster?
HAL1 is offline   Reply With Quote
Old 08-23-2007, 02:10 AM   #2
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
what kind of duster did you use? i used a california duster and it worked pretty well.you cant really use it if you have a lot of dust though. it has to be just a light layer. welcome to Phoenix, we have a lot of dust.also, it depends on your color. i have cgm right now and it hides dust no problem. my black car on the other hand is a different story. its the price you pay for living in AZ. ahwatukee huh? maybe ill see you around.
Uncle Buck is offline   Reply With Quote
Old 08-23-2007, 02:20 AM   #3
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
I'm just talking about the thin coat of dust the morning after. As far a the duster, it's the static kind you see advertised "as seen on TV" for household dusting. If I see you around I may be driving my Green Miata.
Old 08-23-2007, 02:40 AM   #4
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
try the California duster. its pretty cheap and it has a wax in it that picks up light dust.
Old 08-23-2007, 07:18 AM   #5
WRXLTD
Member#: 136314
2014 Grand Cherokee
Not wax, silicone.
I have the California Duster and it works great. Couple of pointers though:
1) Make sure you take it out of it's holster when you first buy it and sit the brush portion on newspaper overnight to wick off the excess silicone.
2) Use only when the cars surface is cool and dry. If you don't, it leaves smear marks.
WRXLTD is offline   Reply With Quote
Old 08-23-2007, 08:18 AM   #6
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
Originally Posted by WRXLTD View Post
Not wax, silicone.
+2 for the California Duster....^^great advice too
REXtard04 is offline   Reply With Quote
Old 08-23-2007, 09:52 AM   #7
philbay
Member#: 149817
As long as we're talking about the cali duster,, I heard mixed ideas on cleaning them.. Mine is old and dirty but seems to work fine, I Know if its not broke dont....., just like to shoot the ****.. anyone/ phil
philbay is offline   Reply With Quote
Old 08-23-2007, 10:32 AM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Genuine California dusters are treated with wax. ......parrifin.
Hal,
I typically use the Cal Duster to get off the light layer and then follow up with a QD to wipe down the car. Another alternative you may consider is a car cover for those times when the car sits. Either way you'll still need to remove and dust/debris from the surface before installing the cover to prevent scratches. ......it's a never ending battle. Even with my car parked in the garage most of the week I'm not immune to dust problems.
Kean is offline   Reply With Quote
Old 08-23-2007, 10:40 AM   #9
EdHilario
Member#: 137398
2004 Impreza 2.5RS
I just use a microfibre cloth
EdHilario is offline   Reply With Quote
Old 08-23-2007, 10:48 AM   #10
Chris85xlt
Member#: 141834
i just wash my car again. dont like risking it with a duster. sometimes you dont know what kind of dust you might of pick up.
Chris85xlt is offline   Reply With Quote
Old 08-23-2007, 11:04 AM   #11
Kean
Member#: 25187
'08 Foz Prem TGM
.......properly done, there is little risk of scratches or even micro-marring. There is typically no need to re-wash a clean car that simply has a light coating of dust on it.
Here's a good article describing safe techniques to use when QD'ing:
http://autopia.org/forum/guide-detai...detailing.html
Old 08-23-2007, 11:06 AM   #12
Phoenix Rising
Member#: 136570
2004 Impreza WRX
Java Black Pearl
I personally use the micro-fiber towels...they work really well!
Phoenix Rising is offline   Reply With Quote
Old 08-23-2007, 12:01 PM   #13
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
1. Buy 36 microfiber car towels for 10 bucks from costco.
2. Throw them in the dryer for 40 mins with a couple fabric softener sheets.
3. Take them out and enjoy watching the dust get removed from the paint.
4.
5. Profit.
moosecakes is offline   Reply With Quote
Old 08-23-2007, 12:53 PM   #14
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
4.
5. Profit.
I LIKE THIS ONE! Has any else tried it? I've use plain microfiber towels, but it just pushes the dust around
Old 08-23-2007, 02:02 PM   #15
michael_wrx
Member#: 130041
2004 WRX
Java Black
+1 for the California Duster. As for cleaning it, I rinsed mine and was a little disappointed that it didn't seem to glide as well over the paint as it did before-hand.
If you just kind of drape the CA Duster so its just barely touching the car it's very unlikely you'll scratch your paint. It'll also give you a good indication of if the dust that is on there should be removed by a different technique.
After a while you'll get used to what it's capable of and be able to visually assess whether the duster is up for the task.
michael_wrx is offline   Reply With Quote
Old 08-23-2007, 02:30 PM   #16
hella_sti
Member#: 139289
2003 WRX Wagon
NO don't use fabric softener when drying your microfiber, it make the microfiber loose the static electricity that make then work so well at picking up dirt and fabric softener also contains small amounts of metalic fibers that will work their way into the cloth which = scratch city. Use the cali duster and spray some quick detailer on it and it'll hold the dirt better and won't spread it as much.
hella_sti is offline   Reply With Quote
Old 08-23-2007, 02:46 PM   #17
fastlanerex
Member#: 133391
2004 boosted saleen
white
micro fiber rags
fastlanerex is offline   Reply With Quote
Old 08-23-2007, 02:49 PM   #18
djosrs
Member#: 101730
02 WRX
Stage III+ PPG Reppin!
CA Duster!!! Its amazing .... when I dust my car every morning ... it stays clean for an extra 2-3 weeks.
I have yet to ever see any sort of scratches from it ...
a rag is too small and might take too long .... I would think. I will even dust my car everytime I get gas or stop for food .... can never be tooo clean
djosrs is offline   Reply With Quote
Old 08-23-2007, 02:52 PM   #19
Newera09
Member#: 125294
California Duster is the shizzzz! When drying you car though definately use microfiber towels. You can also use a slightly moist microfiber towel and wipe down any minor dust that the california duster cannot wipe off
Newera09 is offline   Reply With Quote
Old 08-23-2007, 03:18 PM   #20
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
micro fibers from costco are the ticket to a dust-free car!!!
As for the CA duster, I've used one in the past and it works pretty damn well too...
spoolindc2 is offline   Reply With Quote
Old 08-23-2007, 03:50 PM   #21
ODiz413
Member#: 115207
2005 audi s4
use a clean bedsheet.. the best
ODiz413 is offline   Reply With Quote
Old 08-23-2007, 05:25 PM   #22
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
thank you for backing me up. to the person who said silicon was in it.
Old 08-23-2007, 09:01 PM   #23
Rex87
Member#: 89047
2005 Impreza WRX
The California duster should work good. There is also the Kozak Auto Dry Wash. http://classic-motoring.stores.yahoo.net/koaudrywa.html I don't really have any first hand experience though.
Rex87 is offline   Reply With Quote
Old 08-23-2007, 10:26 PM   #24
02wrbrex
Member#: 103061
98 Impreza EJ207
FJC
Man you all realllllly like swirl marks huh? The california duster will push the dust around, hold on to the dust, and scratch the crap out of your paint while you happily wipe your car off.
I personally would just wash my car again. If you absolutely cant do that I would use "Speed Shine" from Griots Garage with a quality microfiber towel not that crappy stuff from costco or almost any major retail store.
02wrbrex is offline   Reply With Quote
Old 08-23-2007, 10:49 PM   #25
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
I appreciate the suggestion, but as I said in my original post, this is after a freshly cleaned car. I can't really wash my car each morning before I go to work, so I was looking for alternatives.
Whats the best way to remove corrosion from small gold connector contacts? Prod Off-Topic 8 01-11-2007 09:27 PM
What's the best way to remove crazy glue from exterior? Moshpit552 Interior & Exterior Modification 7 12-25-2005 12:33 AM
what's the best way to remove paint? will667 Interior & Exterior Modification 23 09-28-2004 12:58 PM
What's the best way to remove tint adhesive? Porter Interior & Exterior Modification 11 04-30-2003 01:03 PM
What's the best way to remove tint adhesive? Porter South East Region Forum 17 04-30-2003 07:35 AM
