Old 08-23-2007, 08:45 AM   #1
frayz
Member#: 106909
2002 V7 STi Prodrive
Edition... Black!
Default 2.5 Axis Stage 2 bottom end.... any good??
Hey guys,
Im wanting to swap out my V7 2ltr for one of these.
Anyone here run this block and what are your opinions, quality/performance etc?
I was going to match it to a 7cm Green and then maybe swap the hotside for an 8cm and note the difference.
What HP/torque will this take?
Cheers
Frayz
frayz is offline   Reply With Quote
Old 08-23-2007, 10:29 AM   #2
MNAutomatic
Member#: 50038
2003 WRX Sedan
Axis motors are great and few people have had an issue with them. Do some SEARCHING and you will find plenty of people on here sporting an Axis motor with great succes. I myself am in the debate of buying a 2.5 shortblock and building a hybrid or purchasing a stage 2 motor from axis
MNAutomatic is offline   Reply With Quote
Old 08-23-2007, 11:30 AM   #3
Nilesh
Member#: 126987
Frayz,
I'm just wondering why do you want this motor, did u blow up ur motor or you just want that extra .5L of displacement? I'm pretty sure your current motor can handle the green turbo, is this the same V7 motor that the Japanese get, with forged internals?
Nilesh is offline   Reply With Quote
Old 08-23-2007, 02:42 PM   #4
frayz
Member#: 106909
Edition... Black!
Originally Posted by Nilesh View Post
Frayz,
Yes mate my current motor will handle a green. However i want the low down grunt from the 2.5 not to mention the extra spool on bigger turbos.
My STI 7 EJ207 has the forged internals but im convinced 2.5 is the way forward. You only have to look at the area under the graph to realise its gotta be a better setup.
Im not totally sold on the Axis route so i was going to build my own.
EJ257 SCD block
EJ257 sti forged crank
Wiseco pistons
Crower rods
ACL baerings
ARP studs
Worked heads
Stock cams
Think that should be strong enough for 500bhp???
Old 08-23-2007, 04:02 PM   #5
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
^^That should be fine for what you want to do
Acostafan is offline   Reply With Quote
Old 08-23-2007, 04:12 PM   #6
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
If I would get there shortblock it would be the stage 3. its an extra 1500 or so but well worth it for all the extra stuff you get.
silverwrx666 is offline   Reply With Quote
Old 08-23-2007, 04:38 PM   #7
frayz
Member#: 106909
Edition... Black!
Maybe but if im 100% honest id rather build it myself.
I build engines for a living, but the stg2 interested me due to its price. Im hopefully looking at a bigger spec build now so would like to do it myself.
Its just that everything is so damn expensive this side of the pond
gauging interest: 1998 2.5RS-t with Axis stage 2 motor (new)... Keith Private Vehicle 'For Sale' Classifieds 28 02-18-2009 03:40 PM
2.5 L stage 2 axis block problems cquirki Built Motor Discussion 53 11-30-2008 06:15 PM
Axis Stage 2 vs. USDM STi 2.5 Chad W Built Motor Discussion 14 04-30-2007 12:40 AM
Stage 2 - 2.5 Axis Motor - Oil Consumption? jus-hot Pre-2002 Factory Turbo Powertrain 2 12-08-2006 11:53 AM
2.5 Axis Stage Two - Oil Consumption jus-hot Engine/Power/Exhaust 1 11-30-2006 09:10 AM
