Old 08-23-2007, 06:29 PM   #1
DaDonDaDaSuby1969
Member#: 156054
03 2.1 Stroker
MBP Bugeye
Default wuts a good brand of BOV for my 03 wrx??
I have a 2003 bug eye wrx and I heard there were only a few good brands of BOV's that u can buy that wont mess the car up and that will work correctly, does anyone have any suggestions on which kind I should buy??
DaDonDaDaSuby1969 is offline   Reply With Quote
Old 08-23-2007, 06:30 PM   #2
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
you should post this in the newbie forum. Then they will tell you to search and read the faq
silverwrx666 is offline   Reply With Quote
Old 08-23-2007, 06:45 PM   #3
mdunkley43
Member#: 96193
2004 WRX
Java Pearl
agree with above ^ My recomendation would be none at all thou
mdunkley43 is offline   Reply With Quote
Old 08-23-2007, 06:52 PM   #4
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
A good BOV on a Subaru is an oxymoron. They all leak to one degree or the other. Stick with the factory BPV. If you want that pssssht sound, run a search on the snorkus delete mod. It's effective, cheap, and won't eff up your car.
Acostafan is offline   Reply With Quote
Old 08-23-2007, 07:10 PM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
The best one for your car if not highly modified? Made by Subaru..
jigga is offline   Reply With Quote
Old 08-23-2007, 07:21 PM   #6
Full Boost
Member#: 143028
2004 WRB WRX
2003 Nissan 350z 85 Hachi
The only BOV that i have seen work on a wrx without causing problems is the HKS SSQV. But i highly recommend using the stock BPV.
Full Boost is offline   Reply With Quote
Old 08-23-2007, 07:32 PM   #7
joelikewhoa
Member#: 39892
i have the hks ssqv on my 03, have no problems whatsoever. sounds cool too.. except i lost my damn purple insert. anyone have one layin around?
joelikewhoa is offline   Reply With Quote
Old 08-24-2007, 12:08 PM   #8
Nilesh
Member#: 126987
I used to have the HKS SSQV, it sounded cool. I switched back to the stock BOV and noticed my car ran 10 times better. If you have a stock car there is no need for an aftermarket BOV.
Nilesh is offline   Reply With Quote
Old 08-25-2007, 05:59 AM   #9
BALISTC
Member#: 24432
M800, TD06, EJ207
HKS SSQV is the only other BOV apart from a stock one that works well because its a pull type i.e. on boost, the pressure pushes against it and holds it closed, and its pulled open on vacuum to vent the boost pressure.
The only downside is the noise it makes...if you like it then good for you, but if you don't then you'll need to run a plumb back kit or just use a stock BOV
I've got an SSQV in my car and I love it.
BALISTC is offline   Reply With Quote
Old 08-25-2007, 05:00 PM   #10
modaddict
Member#: 95840
sold to a good bud
awaiting next car
You have GOT to be kidding me.
IBTL.
modaddict is offline   Reply With Quote
Old 08-25-2007, 06:33 PM   #11
Drink
Member#: 102682
... ripper's
sister.
the bestest bov is at leest the RFL. itz totally sweet. eyed suggest 3 uv dem at once. ur boozt will be hella tite and ur ride will sound madd dope son.
Drink is offline   Reply With Quote
Old 08-27-2007, 02:26 PM   #12
Momsfavorite
Member#: 135584
The GFB [Gruppe-s] BOV / BPV is nice. Of course I have a fm and needed a bpv. I read an article that said the suby bpv is the best thing to run.
Momsfavorite is offline   Reply With Quote
Old 08-27-2007, 08:31 PM   #13
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
d00d b0vz r00l
really though the GFB is pretty nice...stick with the stocker though FTW
Le Saboteur is offline   Reply With Quote
i am looking for a good working [EGT SENSOR] for my 03 wrx jeremywrx15554 Private 'Wanted' Classifieds 2 11-28-2008 12:52 PM
WTB: any oem rims with good tires for my 03 wrx ScoobyWag03 Tri-State Area Private Classifieds 2 04-02-2007 01:53 AM
WTB Lots of stock front & rear parts for my 03 WRX wagon cky211 Private 'Wanted' Classifieds 50 05-31-2006 12:14 AM
Looking for a good set of headers for my 1998 rs sime Private 'Wanted' Classifieds 0 01-26-2005 10:06 PM
