Old 08-23-2007, 08:18 PM   #1
R.B. WRX Wagon
Member#: 130795
2004 WRX Wagon
Default 04 2.5 Forester motor in a 99 2.5 RS?
will a 2004 2.5 Forester motor (only) swap into a 1999 2.5 RS without changing anything???
dose it need the 04 ECU?
wiring harness?
will it bolt up to the 99's tranny?
Thanx,
~Killian
R.B. WRX Wagon is offline   Reply With Quote
Old 08-24-2007, 11:43 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Use your intake manifold and the attached wiring harness and you will be fine. You don't need the '04 ECU or anything else special. Just stick to your manifold and all of the attached sensors and you'll be fine. In short, just use the Forester longblock...
Old 08-24-2007, 04:39 PM   #3
R.B. WRX Wagon
Member#: 130795
2004 WRX Wagon
awesome thanx for the info. someone said something about the AVCS system...
"And as long as there isn't a significant difference between the heads (don't remember when the Forester got AVCS) and the sensors on them are the same, then, yeah, should be plug and play. And even if the heads are different, you could reuse your old heads, if they're any good. But if the Forester engine has the AVCS, and you can't swap heads, then you would need the ECU, and that would mean harness merging"
dose anyone know if the 04 NA Foresters had that AVCS?
Old 08-24-2007, 06:21 PM   #4
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
According this link:
http://www.cars101.com/subaru/forest...ester2004.html
They didn't get AVCS until 2006.
jey is offline   Reply With Quote
swapping in a 02 forester motor in a 00 RS amyasin Normally Aspirated Powertrain 3 05-02-2009 01:26 AM
need help with ej20 swap in my 99 2.5 rs jonnyquest Newbies & FAQs 12 05-28-2008 03:00 PM
WRX Engine in a 99 2.5 RS? awesome2.5rs Subaru Conversions 11 10-28-2005 04:16 PM
Any intrest in a 99 2.5 RS? cfvwtuner New England Impreza Club Forum -- NESIC 16 04-18-2004 05:25 AM
JDM V8 2.5 Forester Motors ScoobyMods.com Engine/Power/Exhaust 15 03-16-2004 12:06 AM
