Old 08-24-2007, 12:45 PM   #1
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Default Another well powered, well tuned 07
Mods:
Greedy TBE
255 Pump
c16 gas
The car was tuned at The Shop late last night by Franz. Benoit from Ecuteck Canada was there as well and sold me an Easy ECU so that map switching was possible.
A few things to say dyno-wise before i discuss the power. The dyno dynamics dyno is a fully adjustable dynometer as far as correction factor. As many of you have seen, the other night Junior2jz made some rediculous power out of a stock turbo 07 at the shop. That some 350whp 390wtq was not b.s, it was set to a real dynapack setting. Previously an evo was dyno'ed at The Shop on the Dyno Dynamics, then dyno'ed on another shop's dynapack. The numbers were off by only 4 hp.
With this being said, i was tuned on the dynapack setting
359.6whp
375wtq
21psi
However, at the end of the session I changed the correction over to standard and those numbers changed.
330whp
350wtq
This is what I stuck with numbers wise. I do not have a graph on me, but the power reaches 300 @ 4700RPM, 330 @5400RPM, and 300 is still held at 7000. The curve is amazing and the power comes in soooo smooth.
Used C16 because with all the tuning going on over the last few days all other race gas was out.
STi Mikey is offline   Reply With Quote
Old 08-24-2007, 12:54 PM   #2
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
330whp with C16 is avg power. No graph so we cant comment on the tune. Can you post it? Sounds like a good tune though.
Clark
AZScoobie is offline   Reply With Quote
Old 08-24-2007, 01:24 PM   #3
UM-WRXer
Member#: 44623
Is franz diebold tuning in the suby scene again?
UM-WRXer is offline   Reply With Quote
Old 08-24-2007, 01:53 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Kudo's on running with a 1.0 CF! 330whp is actually very good power without using any inflation factor. That should be good for 114-115mph traps! The torque could be a bit higher, but considering you're only running 21psi, its pretty much right on. Its amazing to finally see some numbers that correspond to mine
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 08-24-2007, 02:29 PM   #5
Member#: 156622
Originally Posted by STi Mikey View Post
Mods:
Greedy TBE
255 Pump
c16 gas
359.6whp
375wtq
21psi
330whp
350wtq
Ok first off - we use a correction factor of 1.1 , when and only when a customer wants to see or know what his or hers particular set would have made on a Dynojet is when and only when we use the correction factor of 1.2 , it has been proven time and time again to be with in plus or minus 5 hp , and in Mikeysti statement he claims or states Dynopak which is in correct , he meant to say or should have said Dynojet - Jimmy
JK@THESHOP is offline   Reply With Quote
Old 08-24-2007, 02:46 PM   #6
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
I don't think he ever stoped
I thought he went out on his own
silverwrx666 is offline   Reply With Quote
Old 08-24-2007, 04:26 PM   #7
Tgui
Member#: 44771
-- Ed
Only 21 psi?? I thought I was nuts for running 20psi. Strange how whats considered kosher for the VF39 is always changing. (I expect that there is a taper to 15 or so psi at redline)
How many psi are people pushing @ peak torque with the VF39 now? EDIT: Yeah, this is the VF43, but the question stands, unless this is not an STi
OP: Good numbers! What kind of injector duty cycle are you seeing at red line?
Tgui is offline   Reply With Quote
Old 08-24-2007, 06:11 PM   #8
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
I think 21 psi is possible due the c16.
I'm hoping for the same results when I get my race gas tune.
on my pump tune I would be happy with 19-20 psi
Old 08-24-2007, 06:12 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
20psi peak is appropriate for pump gas but on race gas I've run as much as 25-26psi peak and made tons of torque. Boost still tapers off to redline of course, so peak whp is usually unaffected... just the area under the curve.
-- Ed
Old 08-24-2007, 07:46 PM   #10
Member#: 156622
-- Ed
I concur , Mikeysti's pump gas tune was set to around 19-20 psi spike and tappering down to around 14-15 psi . I or should i say we , dont like to run more boost then that on a pump gas daily driven car with the factory top mount - Jimmy
Another pricing mistake? well order anyway! lionken07 Off-Topic 18 10-18-2009 10:05 PM
Feeler:FS(LA)02 APS/COBB WRX well sorted-reliable tuned by Cobb 4porsh SCIC Private Classifieds 14 08-15-2008 06:35 AM
Feeler:FS(LA)02 APS/COBB WRX well sorted-reliable tuned by Cobb 4porsh Private Vehicle 'For Sale' Classifieds 13 08-15-2008 06:34 AM
Well my remote tune is done justin time for FIR HPDE Valhakar South West Impreza Club Forum -- SWIC 1 11-09-2006 07:49 PM
another job (very) well done by wakefield subaru yellowscooby New England Impreza Club Forum -- NESIC 0 07-17-2006 11:58 PM
