Old 08-24-2007, 04:24 PM   #1
V8killah91
Member#: 101299
2004 Subaru STi
Default '04 STi 20g 328whp 347wt
I got tuned at TurboXS in Maryland and hit 328whp and 347wt on a Dynapack. That was with a slipping clutch, on 93 octane, at 22psi peak (was going for 24psi, but he backed it down after the clutch started slipping). Also, the boost tapers more than usual because he didn't want to get very aggressive, with the clutch issue. Other than the clutch problem (which I was unaware of until we started tuning), I had a great experience there.
Here is the mod list:
-FP 20g TD06 8cm (with StaticX wrap)
-Large TMIC
-Deatschwerks 740cc injectors
-Walbro 255lph pump
-1-step colder plugs
-Injen CAI
-Utec
-TurboXS turboback exhaust
What do you guys think of these numbers and how much do you think is left to gain with the new clutch and a more aggressive tune? It's a 3 hour drive for me and with the cost of the re-tune, I'd like to weigh my options to see if the re-tune is worth it.
Graphs Added:
Thanks.
V8killah91 is offline   Reply With Quote
Old 08-24-2007, 04:51 PM   #2
Tgui
Member#: 44771
Well, the hard work is really done. Injectors are working nicely, maf table maybe scaled for your CAI etc. Up the boost yourself a little if you have a WB02 and an EGT once you install a new clutch.
Tgui is offline   Reply With Quote
Old 08-24-2007, 04:55 PM   #3
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Is 330whp a pretty common # for 20g STi's? The number seems kind of low.
C J is offline   Reply With Quote
Old 08-24-2007, 05:24 PM   #4
brickhoss
Member#: 84183
1994 Geo
Prism
Once they get everything straightened out, I'm sure It'll read a little higher then that. I don't think that sounds all that bad though to be honest. Depends on the dyno and correction factors used (see other thread in PPB right now).
brickhoss is offline   Reply With Quote
Old 08-24-2007, 05:32 PM   #5
Zumble
Member#: 34860
2005 Forester CGM
His clutch was slipping.
Zumble is offline   Reply With Quote
Old 08-24-2007, 06:19 PM   #6
V8killah91
Member#: 101299
2004 Subaru STi
Any estimates in whp/wt gains after the retune?
Thanks.
Old 08-24-2007, 08:48 PM   #7
V8killah91
Member#: 101299
2004 Subaru STi
Bump for an answer, please.
Old 08-24-2007, 09:12 PM   #8
Vahnatai
Member#: 25027
Mid 340s
Vahnatai is offline   Reply With Quote
Old 08-24-2007, 09:44 PM   #9
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Depending on what dyno is being used it can vary between 330-360 on straight pump 93
JMK508 is offline   Reply With Quote
Old 08-24-2007, 10:21 PM   #10
V8killah91
Member#: 101299
2004 Subaru STi
Is that whp or wtq? Also, it was on a Dynapack.
Old 08-25-2007, 12:09 PM   #11
V8killah91
Member#: 101299
2004 Subaru STi
Bump for more whp/wtq estimates.
Old 08-25-2007, 12:58 PM   #12
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
I say 350-380whp and 400wtq. That is, if you run ATLEAST 20psi+.
akira02rex is offline   Reply With Quote
Old 08-25-2007, 12:58 PM   #13
UltimateLurker
Member#: 82488
06 Lotus Exige
Wow, thanks for this thread, my set-up will be nearly identical...
-Deadbolt 20g TD06 8cm
-Spearco TMIC
-Walbro 255lph pump
-AccessPort
-APS Intake
-APS 3" cattless TBE
I'm hoping for 350 at the wheels on 93 pump, but will be satisfied with 330.
UltimateLurker is offline   Reply With Quote
Old 08-25-2007, 01:29 PM   #14
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Everyones excuse is "a slipping clutch". Rarely is that the problem. Hell I have tuned cars near 600whp with the stock clutch. THey hold 500 with ease.
If your clutch is really worn out and its slipping you will gain power to the hub dyno. How much is anyones guess.
A 20G on an STI engine makes 330 to 370whp pump 93. You need to get up to 22 psi to make 350. I have never had one cross 400 that I can remember off hand. The compressor is just to small. If the car runs good at 330 then enjoy it. Its that last 20 whp you want that starts to push things.
Clark
AZScoobie is offline   Reply With Quote
Old 08-25-2007, 02:19 PM   #15
V8killah91
Member#: 101299
2004 Subaru STi
My clutch did actually "give" on the dyno and the engined revved up very quickly. Also, if I "floor it" in 5th or 6th, the clutch will "give" and the RPMs rise quickly without any increase in acceleration. There is no question that my clutch is on the way out.
He's cutting me a break on the retune, so I think the extra 20whp would be worth it. 350whp sounds about right and I don't believe that this is "pushing the engine" in any regard. Also, I'm losing power towards redline, moreso than usual, so the wastegate needs tightened, as well (he kept the tune somewhat conservative until I come back). Overall, I may get 20whp extra, but less of a drop to redline would be attractive also.
Thanks for the mention about the stock clutch, btw. I'm debating which one to get and have been questioning the potential of the OEM one. With the stock clutch holding 500+whp, it should hold approx. 350whp daily driven, no problem.
Clark
Old 08-25-2007, 05:57 PM   #16
V8killah91
Member#: 101299
2004 Subaru STi
Dyno charts added...
VA: '04 STi BBS Wheels, HKS Hi-Power Exhaust, '04 Tein S-Tech Springs WRX/STi anzu Private 'For Sale' Classifieds 17 05-18-2006 12:42 PM
VA: '04 STi BBS Wheels, HKS Hi-Power Exhaust, '04 Tein S-Tech Springs WRX/STi anzu MAIC Private Classifieds 18 05-18-2006 12:41 PM
Installing '04 USDM STI Steering Rack in non-'04 STI UTCiv Subaru Conversions 4 01-07-2006 02:31 AM
FS: '04 STi BBS wheels & '04 STi struts Phil H Private 'For Sale' Classifieds 20 11-17-2005 05:37 PM
FT: '04 STi Ecutek ECU for '04 STi Cobb AP + ECU ninjaboy76 Private 'For Sale' Classifieds 8 09-29-2005 12:25 AM
