#1 |
Vendor
Member#: 73568
Vehicle:'05 STI 11.1 @ 127 03 Evo 8 9.5 @ 149 |
This was a Ecutek tuned 07 with Stage II and walbro pump
I am showing 3 of the final dyno pulls before we took it out on the street to road tune The 07's are great cars ![]()
#2 |
Member#: 78884
Vehicle:Go faster at TopSpeed |
70 degrees, god how nice that must be. Today it was 103 in the shop here.
nice graph. Doug |
#3 |
Member#: 117464
NESIC
Vehicle:-> 2008 Hayabusa 1300R |
#4 |
Vendor
Member#: 73568
#5 |
Vendor
Member#: 73568
#6 | |
Member#: 117464
NESIC
Everybody is getting their race gas tunes this week, at first I forgot about the shootout and was wondering what was going on.. ![]() |
#7 |
Member#: 83790
How come it is so rich after 5k? Was it knocking?
#8 |
Member#: 56945
Vehicle:08 STI Base Model Black |
#9 |
Member#: 142709
NESIC
Vehicle:07 STi Limited FP HTA Green 372whp |
Al, how much boost did u tune this car to? I assume since you posted stage II he has just a TBE? Another nice looking graph.
Bruce |
#10 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
The red run is the last one. Run 65. Its 10 to 1 at 5500 rpm to 6000 rpm. Its getting richer and richer as it got hotter and hotter. Why not take the 2 minutes to fix that? I you look at the graph closely this is effecting power. I am sure you will just claim I am "self promoting" LOL...
Clark |
#11 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
I've always wondered... I know most dyno tuners take the cars out for a brief tune on the road after the dyno work. Have you guys ever put the cars back on the dyno after the road session to see what the changes do to your curves?
-- Ed |
#12 |
Member#: 136694
SCIC
Vehicle:07 STI LimitD #242 SPW Stage 2+ |
Nice numbers. My 07 Limited did similar with a simple stage 2 on crappy 91 octane pump gas. Oh, I was running Cobb AP too. Congradulations!
#13 |
Member#: 56945
#14 | |
Member#: 56945
-George |
#15 |
Member#: 120262
W. Canada
Vehicle:09 WRX Lightning Red |
Daaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaammmmn that's nice.
#16 |
Member#: 78751
Vehicle:2006 WRX STi Black |
#17 | |
Vendor
Member#: 73568
In most cases the tunes are spot on when they leave the dyno and only minor adjustments are needed for boost level or to fine tune the a/f and timing maps. Thekind of changes I am making are only to take into account any effect real world operating has on the settings and to double check the work already done on the dyno. The way I see it - the dyno is a tool that simulates real world operating conditions and quantifies losses and gains in power. A dyno is to get the tuner very close and the road is the place to test the tune as that is where you drive it. Al |
#18 | |
Member#: 26933
BAIC
-- Ed |
#19 | |
Vendor
Member#: 73568
I have a whole range of data logging options including a simulated road dyno application as you have to check and re-check that the ecu is doing exactly what it is supposed to do. Since the customer drives the car on the road and not the dyno it would seem more important that it runs perfectly on the road. I have found in all cases that a car which runs well on the road will run well on our dyno. I think I will test that out a couple of times in the upcomming weeks just for fun. That is my answer. Onto a new subject, the biggest problem I have found in my extensive tuning travels has been dynos which do not load the car similar to the road. When you have an unfamilar dyno and or a dyno that is not configured properly and which does not load the car in a similar fashion to how it is loaded in real world operating conditions - the dyno results and tunes can be almost useless. Since the dyno I am now using a 424 X Dyno Jet which provides a very accurate replication of real world conditions and also becuase I am very familar with how to set the a/f and boost levels on this dyno to match real world conditions 100% I am very confident in the accurancy of the results. I think that in my case carefully testing and maping the car with the Dyno Jet and then test driving the car and readjusting the maps on the road as needed and indicated gives the customers the benefit of having a dyno verified result and also a car which is tested to work well on the road. Although the entire process takes a lot of time and effort it is the only way to do the job properly IMHO. |
#20 |
Member#: 8785
SWIC
If the dyno operator uses the dyno correctly there is no tuning needed on the road. Dynos like the dyno jet which have no load control will always need further adjustment on the road. My tunes do no change. This is due to my experience level. Most of the time if there is a problem down the road I will find out that a part has changed or there is a mechanical issue with the car. Dynso with Eddy load current generators can provide the load of real world and far beyond.
Al is using a Dynojet which has No load generators. Only the weight of the rollers. He cant foot brake to spot load it because there is no mechanical link between the rollers. If he did there would be a run on Center diffs down at the subaru dealer. He cant hit the dyno brake as it is not rated for that and will burn up in short order (its designed only to stop the rollers after a run). As a result he must fine tune the car on the road after the run just as I do when I use a dyno jet. Clark |
#21 | |
Member#: 100274
I would say "In most cases" really applies. I've been reading all these posts lately by tuners with AL in the middle of many of the disputes. Needless to say AL tuned my car twice in a period of a month and a half. My speed limiter was no removed as requested by myself more then a few times. Unfortunately I realized this on the Salt Flats in Wendover, UT where I really needed it. Dead spot in the tune from 2500rpm to 3000rpm where the car threw me forward at part throttle. 5,000 miles later I have 95psi and 35psi in two of my cylinders. How is that for one of AL's many returning and satisfied customers????? |
#22 |
Member#: 82734
#23 | |
Member#: 56945
-George |
#24 |
Member#: 82734
#25 |
Member#: 56945
| Thread Tools | |
| Display Modes | |
| Andrewtech and Turbo XS GT35R 07 STI Limited 430 pump race inside | TAPOUT | Proven Power Bragging | 194 | 06-19-2008 06:05 PM |
| 448 TQ P '07 STI Stage II with pump and Aquamist | Dyno Flash | Proven Power Bragging | 149 | 05-07-2008 02:30 PM |
| 05 STI Stage II 93 Pro Tune Dyno Results | IMPORTEDCARS | Proven Power Bragging | 0 | 08-24-2007 10:17 PM |
| 12.388 @109.69 18G on 93 pump gas w/ HYDRA | CK02WRX | Proven Power Bragging | 51 | 11-10-2004 03:59 PM |
| Nitrous on 93 pump gas | Big Turkey | Water/Methanol Injection, Nitrous & Intercooler Cooling | 7 | 01-19-2004 01:41 AM |
