Old 08-25-2007, 09:42 AM   #1
lgt2000
Member#: 140073
2005 LGT
Red
Default EJ257 Hybrid
Hey guys,
The headgasket on my 2000 Legacy GT with EJ251 SOHC engine is done. Since I have to rip the engine apart I figured I would get something stronger.
Here is the plan:
Keep my stock heads, maybe send them out for Port and Polish.
Picked up an EJ257 shortblock with a bad piston, get it honed then put in new stock pistons.
Pick up stock STI head gasket and head bolts
Put everything together, and bolt up stock WRX turbo components that I have.
Tune everything with emanage.
Upgrade to VF39 later on.
What do you guys think, this is my first engine build of any kind so I would like some advice, is there anything else that needs to be done?
lgt2000 is offline   Reply With Quote
Old 08-27-2007, 12:21 AM   #2
SiouxBe1
Member#: 157247
1991 Legacy L+AWD BJ
What is your Goal?
Do you wanna keep the same MPG?
Or, do you wanna boost it?
SiouxBe1 is offline   Reply With Quote
Old 08-27-2007, 12:38 AM   #3
lgt2000
Member#: 140073
2005 LGT
Red
its going to be boosted with a stock wrx turbo for the moment, and my current goal is 200 WHP, then will upgrade to VF39 and goal will be 250HP, dont care about MPG
Old 08-27-2007, 10:01 PM   #4
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
Impact screwdriver with a BIG phillips to take off the access plates to get to the 14mm allen plugs, a 14mm allen wrench to get out the plugs to get to the wrist pins, and some cleaned up and custom bent welding rods to take out the wrist pins out.
Have fun
fishheadback is offline   Reply With Quote
Old 08-27-2007, 10:05 PM   #5
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Check with Ron at Axis for stock sti pistons. He gave me a very reasonable deal on some new pistons that he had swapped out of a new block.
LiquidForce is offline   Reply With Quote
Old 08-27-2007, 10:38 PM   #6
SiouxBe1
Member#: 157247
Looks like a good plan...go for it!
Old 08-28-2007, 08:48 AM   #7
lgt2000
Member#: 140073
2005 LGT
Red
Here is what the full setup will look like, all the stuff in bold I have already acquired:
The Engine:
EJ257 Shortblock from 07 STI
Cometic STI Head Gasket
ARP Head Studs
Stock SOHC Heads
Should yield about 8.7:1 from what I was told
The FI:
-WRX TD04 Turbo
-WRX Uppipe
-WRX Downpipe
-WRX Heatshields
-WRX Crossmember
-WRX Oil Pan
-WRX Fuel Rail
-WRX Injectors
-WRX TMIC
-WRX Fuel Pump
-WRX Water Pump
-STI Exhaust Manifold
-STI Exhaust
-HKS BOV
-GReddy eManage Blue w/injector and ignition harnesses
-GReddy Profec Boost Controller
-Oil Lines
-Coolant Lines
-Various Gaskets
-Custom Piping from DP to Muffler
My goal is to run the stock 10 PSI for now, which I think should yield me 210-230 whp, once I get everything stable I will upgrade to the VF39 or something bigger and shoot for 300+ whp
Old 09-13-2007, 08:45 AM   #8
lgt2000
Member#: 140073
2005 LGT
Red
got new STI pistons in the mail yesterday, and put down a deposit on an EJ257 block with one bad piston, will pick up soon. Are there any good threads on a diy engine build since this is the first time I will be tackling something like this.
EJ257 hybrid, jdm seats, Perrin CAI, WRX driveshaft, rear axles, door cards/rear seat annointed Private 'For Sale' Classifieds 15 11-28-2005 10:59 AM
EJ257 hybrid oil pump question sheikthin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-28-2005 03:03 PM
My EJ257 Hybrid MY98 RS wont start!!! turboed22 Service & Maintenance 1 08-11-2005 05:01 PM
ej257 hybrid question! scoobyimpreza Pre-2002 Factory Turbo Powertrain 19 02-07-2005 02:51 PM
EJ257 hybrid possible headgasket trouble john banks Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 86 03-25-2004 12:18 PM
