Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 08-26-2007, 12:27 AM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Looking to upgrade VF34 to 18G.. question
I currently have AP and use protuned maps on my VF34 set up. If I were to upgrade to 650CC and 18G set up, how do I go about safely driving to a nearby tuner other than getting an emaps from PDX, etc?
What do you guys normally do?
gopsu is offline   Reply With Quote
Old 08-26-2007, 01:14 AM   #2
broosewee
Member#: 155938
2002 Impreza WRX
Hey dude, sorry I can't answer your question too well, but was wondering where in the tri-state you're located? I have the same setup as you.
What is your color?
broosewee is offline   Reply With Quote
Old 08-26-2007, 01:40 AM   #3
boostin AWD
Member#: 86397
2005 vf39'd WRX
CGM
Could your tuner email you a base map scaled for the injectors that you could drive there on as long as you don't drive aggressively?
I thought i have heard of tuners doing this.. maybe not?
boostin AWD is offline   Reply With Quote
Old 08-26-2007, 02:00 AM   #4
CynicX
Member#: 48199
06 WRX
Disconnect the BCS so the turbo uses wastegate pressures and limp it there like a 90 year old lady on the way home from church.....
Problem is going to be the injectors, I have no idea how they will act without some sort of tuning....
CynicX is offline   Reply With Quote
Old 08-26-2007, 02:14 AM   #5
Cyclops
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
What I did was upgrade to an ATP 3" MAF housing. You could also use a Perrin Big Maf. This will balance out with the injectors more or less. You'll probably still run pretty rich, which is okay, just limp it along. Otherwise you can get openecu limp maps for pretty cheap.
Cyclops is offline   Reply With Quote
Old 08-26-2007, 07:53 AM   #6
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
650's are too small for a 18g -- they'll work, but you'll have ZERO headroom. Think 750cc or bigger.
Spenk is offline   Reply With Quote
Old 08-26-2007, 08:57 AM   #7
H-Town Wrx
Member#: 71520
1996 Nissan 240sx SE
Uh yeah it's Blue.
Honestly, you should ask your tuner. Disconnecting the BCS is a good suggestion. I would think slow driving and staying out of boost until you got there would be best.
H-Town Wrx is offline   Reply With Quote
Old 08-26-2007, 10:15 AM   #8
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Ask your tuner to send you a temp map so you can drive to his facility. Even w/ the temp map, I would try to drive it without boosting.
Good luck, let us know what's up~
WRX4eva is offline   Reply With Quote
Old 08-26-2007, 02:31 PM   #9
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Carbon Bronson
I'd think you could just drive it mellow and not get into boost. When I did a turbo injector upgrade I couldn't get in for a tune for 1 week and I drove it all week, just not getting into more than a few pounds of boost. Never have had any issues.
575rider is offline   Reply With Quote
Old 08-26-2007, 03:37 PM   #10
CynicX
Member#: 48199
06 WRX
? 650's are fine for a 600 cfm turbo. Hell you can get away with the 06+ stock 550-560's (whatever they are) with like you said zero head room...
I was on the stock injectors for a while. After a retune I didnt see any gains...just lower IDC's with a good safety margin...
Old 08-26-2007, 03:52 PM   #11
WRX4eva
Member#: 103343
It depends on who is tuning. I've seen 18g tuned w/ pinks and still had room on the IDC. Some tuners prefer bigger injectors. For instance, some tuners may want you to get 750's w/ the 18G. Ask you tuner
Unusual 2.0L configuration, looking to upgrade VF34 Simon C Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-24-2010 01:14 PM
Looking to upgrade to VF34 wrx2k4blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 02-03-2007 01:01 AM
Too upgrade or not to upgrade that is the question. scoobyracing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-12-2005 10:06 AM
How hard to upgrade Morettes to HID? deviloftruth Electrical & Lighting 9 03-10-2004 11:37 PM
