Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 08-28-2007, 01:01 AM   #1
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
Default ej205 crank in a ej20g block
i want to know if it will work. if not why wont it.
midnight2.5rs-t is offline   Reply With Quote
Old 08-28-2007, 01:14 AM   #2
xtian
Member#: 93248
95 20g powered gc8
PPG'd yO! & is250 AWD
it wont... if i remember correctly. the placement of the crank trust bearing on the phase1 was in the middle while the phase2 trust was on the flywheel side. ive heard about people moving the trust bearing to make it fit. but some say the lenght of the stroke are difrent might be a problem depending also on what heads are goin to be used.
xtian is offline   Reply With Quote
Old 08-28-2007, 01:29 AM   #3
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
alright thanks that is what i wanted to know. also will the ej205 rods and pistons work in it?
Old 08-29-2007, 02:50 AM   #4
poormansporsche
Member#: 79798
The crank can be modified to work in a EJ20G. Ron at Axis does this for like 150 bucks.
cheers
poormansporsche is offline   Reply With Quote
how well does an EJ20G block work with EJ205 heads? Import03WRX Subaru Conversions 3 09-26-2009 09:21 PM
EJ205 Heads on EJ20G Block latenight2736 Built Motor Discussion 0 06-02-2008 04:39 PM
FS in NorCal: Ej20G closed deck block + internals Millencolin! Engine/Power/Exhaust 7 11-19-2007 02:52 PM
Best CRANK to use in 2.5L block Maxspeed23 Built Motor Discussion 12 10-23-2006 10:33 AM
2.0 crank in 2.5 block? Wayne_Coots Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-05-2006 03:23 PM
