Old 08-26-2007, 05:55 PM   #1
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
Default both low beams went out at the same time, huh?
2005 RS
Sylvania Silverstars(I know just read up on them) 5 Months Old
gf went to leave last night and they worked for about 10 seconds then they both went out at the same time
checked fuses and relays and both came out good(used a meter), high beams work perfect
checked the headlight housing itsself and with the lights in the off position it was not receiving power on both of them and when I went to turn them on they were receving a steady 12v to them.
The thing is I've never seen BOTH headlights go out at the same time and was wondering if I should check something else out first before I go get some new bulbs, obviously not silverstars now.
thanks
pumpkyn is offline   Reply With Quote
Old 08-26-2007, 07:08 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's been known to happen. The only thing I'd check is the system voltage at the battery, it should not be much more than 14 volts with the engine running. If it's 15 or above you may have a problem with the alternator and that can cause bulbs to blow prematurely.
If the voltage is ok you can try your stock bulbs if you still have them, otherwise put some replacements in. And yes stay away from the Silverstars, aside from not really producing more useful light they do not last very long.
Old 08-26-2007, 10:44 PM   #3
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
i knew i forgot another test. Yeah i kept the stock ones knowing to keep them just incase. now i just need to remember where i put them
Old 08-26-2007, 11:03 PM   #4
Jonnyfilmboy
Member#: 68902
2011 WRX - WRBM
1988 Fiero GT - black
Same thing happened to me on a long road trip where I was flipping the high beams on and off. Eventually, both low beams burned out at the same time. I have JDM fogs and the fog light mod (which keeps fogs on when the high beams go on). I also had Silverstars in.
Jonnyfilmboy is offline   Reply With Quote
Old 08-27-2007, 11:17 AM   #5
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
damn.
yeah right before she left she flashed her highs at me rapidly like she always does when she leaves.
Old 08-28-2007, 08:12 PM   #6
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
well put new bulbs in and both Silverstars were melted on the inside.
Both low-beams went out at the same time..help! andron Electrical & Lighting 14 03-03-2011 10:10 PM
both High beam and Fog light bulb went out at the same time :( Mike7 Electrical & Lighting 1 09-28-2009 11:30 AM
Pulling window/regulator/motor all out at the same time? BlackoutWRX Interior & Exterior Modification 0 09-01-2007 01:08 PM
V7 Diagram for High and low beams at the same time WRS Electrical & Lighting 1 08-12-2005 10:33 PM
High beams, low beams, & fogs at the same time il96 Electrical & Lighting 0 03-10-2003 10:08 AM
