Old 08-26-2007, 07:23 PM   #1
iluvdrt
Member#: 46248
82 Brat
Tan
Default Need help ASAP Please with trans (not hard)
I have a 98 Lego GT wagon with an auto trans. I have installed a HUGE trans cooler, and used only Mobile 1 syn trans fluid since I have owned it.
Well today I blew out a front axle and had to limp her home about 12 miles. It didnt like it, but I made it. While changeing the axle I figured I would change the front diff seal as well (since it was leaking), but the darn retaining plate will not come off, and I broke off a few small pieces trying to get it.
I did get a new retaining plate, but I cannot get the old one off still, so my questions are:
1. How do you get that stupid front diff retaining ring off to change the axle seal (bolt and lock clip already removed), and
2. could I have hurt something driving in RWD mode with the front axle being being broken (I removed the shaft from the trans before driving).
Please help as I need my car to work. My son starts school tues, and I need it to take him......aside from working.
Thanks for any help.
iluvdrt is offline   Reply With Quote
Old 08-27-2007, 01:03 AM   #2
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Those covers spin off. Use a brass drift punch and a medium ball-peen hammer and whack it using the little "arms" provided. I believe they both come out counter-clockwise (Neither side should be reverse threaded).
There is also an o-ring in there, I think, and I'd suggest replacing that as well.
FYI: This knowledge is from a '97 5spd I just installed, so it may not be 100% accurate, but should be the same between MT and AT. If I get the chance tomorrow I'll look at my old AT and see if it's the same setup, but I'd imagine it is...
fastenova is offline   Reply With Quote
Old 08-27-2007, 07:17 AM   #3
brandoncrone
Member#: 152710
It is the same as an automatic. The seal goes on from the inside. Also mark it before you take it out. It has to be turned in exactly the same amount it comes out as the 'wheels' preset the differential bearing preload. The diff could be damaged if they are not put back where they came out.
brandoncrone is offline   Reply With Quote
Old 09-04-2007, 06:33 PM   #4
iluvdrt
Member#: 46248
82 Brat
Tan
Thanks for the help. I finally got it out after breaking it, had to get a new cover. I also didnt know about the preload thing until I had already had it out. I put it in and made it in between tight and snug. The online manual says every bar is apx .002" so I dont think it will that ba
d. 1 week driving and no probs so far.
Need help ASAP please z3coupe Southern California Impreza Club Forum -- SCIC 5 05-23-2003 10:30 AM
Need help ASAP please Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-11-2002 12:57 AM
Need help ASAP please z3coupe Brakes, Steering & Suspension 9 01-21-2002 08:44 PM
where do I get T fitting for boost guage? I need help asap please littleblue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-08-2001 07:05 AM
