Old 08-26-2007, 08:38 PM   #1
C4NiNjA
Member#: 91964
2003 Impreza WRX WRB
Default Question on JDM heads...
I am in the process of purchasing a totaled car that the owner said had a built bottom end/ JDM head and cams and JDM ECU>
I removed the ECU cover on he passenger floorboard and the code on it was AF422 which is a USDM ECU according to ECUtech website. How can I tell if the heads are legit without pulling them. Is there a head code stamped and if so where is it located? Any help would be appreciated.
C4NiNjA is offline   Reply With Quote
Old 08-26-2007, 09:56 PM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
There is a code on the top of the heads right below the injectors.
USDM 2.0 WRX's are LHS20 and RHS20. The jdm verison 6 heads I have are stamped with the same numbers.
I recently did a version 8 swap for someone and the casting was different but I can't remember the actual numbers.
I found this thread when I type in LHS20 http://forums.nasioc.com/forums/show...ighlight=LHS20
LiquidForce is offline   Reply With Quote
Old 08-27-2007, 12:10 AM   #3
BiGtUrBo
Member#: 126022
make sure you inspect the heads carefully especially look for hairline cracks around the spark plug area. My recent experience searching for a set of used WRX heads i found hairline cracks in a number of heads i had inspected. Ended up buying brand new castings.
BiGtUrBo is offline   Reply With Quote
Old 08-27-2007, 08:54 AM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
I have a set of stock 02 heads that have the crack described above. They had it when I pulled them off at 40k miles. When I pulled them off again at 80k miles they were the exact same size. It probably happened the very first time the car was heat cycled.
The crack does not always mean the head is toast but I can certainly understand people being uncomfortable about it.
Old 08-27-2007, 09:19 AM   #5
C4NiNjA
Member#: 91964
The problem I am experiencing is this.. the real reason I am buying the car is that he stated the motor was rebuilt 20,000 miles ago with forged internals. He added JDM heads with a mild port job. My thing is he told me the ECU was JDM to control the AVCS on the heads. So I check the ECU- Non JDM. So now do I believe him about the heads and forged internals. This could be a bone stock 106,000 mile USDM EJ20. My EJ20 is running fine with 112,000 miles but it is my daily driver and I want reliability 1st, power 2nd. So instead of rebuilding one I thought this was a good alternative.... buying one built. My goal now is to verify the heads..to see if they are JDM. From what I have read it looks like I may have to remove them to truely know.
Old 08-27-2007, 09:52 AM   #6
LiquidForce
Member#: 12811
2002 2.5l Wrx
Well if they are at least avcs heads it should be real easy to tell without pulling anything off. Just look for the control solenoids right behind the intake cam gears.
The ecu thing definately sounds shady.
Old 08-27-2007, 10:59 AM   #7
C4NiNjA
Member#: 91964
I will do that this afternoon. Thanks for the quick info and help.
Old 08-27-2007, 11:22 AM   #8
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I was told that car was a 2.5L from a local in Wilmington that I don't even know. I was at a store there and the guy walked up to me asking if I was interested. This was after Kelly told me about the car. There are a lot of flaky stories around about this car dude. Be careful.
CoolRex is offline   Reply With Quote
Old 08-27-2007, 12:15 PM   #9
C4NiNjA
Member#: 91964
Check pm Coolrex
Old 08-27-2007, 01:56 PM   #10
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
PM'd ya back.
Questions on V7 Heads on EJ205 block. 02WRXNY Built Motor Discussion 1 10-23-2008 03:50 PM
Another Question on replacing Head Gasket Mike1967 Normally Aspirated Powertrain 26 03-19-2006 07:03 PM
2.5L STI shortblock on JDM heads and ECU? powerlabs Subaru Conversions 3 03-14-2006 08:21 PM
Noob-like question on valves/heads...please educate gtwagon941 Legacy Forum 26 02-11-2006 11:26 AM
question on repacing heads / head gasket Mike1967 Normally Aspirated Powertrain 18 08-25-2005 10:48 PM
