Old 08-27-2007, 03:36 PM   #1
IMPORTEDCARS
Member#: 56945
08 STI Base Model
Default Utec w/MBC 22+psi vs. EcuTek Tune 19 PSI
Gentlemen,
Please give us your thoughts on these 2 graphs and voice your opinions.
Thank you
-George
IMPORTEDCARS is offline   Reply With Quote
Old 08-27-2007, 03:45 PM   #2
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
The blue graph is so lean its shocking. I hope this is not pump gas. It has obvious knock correction issues around 4000 rpm. Its 14 to 1 at 2700 which is a bit lean. My opinion of this tune is that something has changed in the tune. I cant see any tuner on these boards letting a car leave with that curve and AFR. Its possible the customer changed parts on the car or a mechanical issue developed that through the tune off. Its also possible that the car had alot of negative AFR correction which pulled the Open loop fueling lean. I would have liked to see this tune after an ECU Reset.
The red graph has major issues with the Fuel map past 5500 rpm. Its hitting 10 to 1 and chugging on fuel. It also has some issue in the timing map around 3600 rpm. It looks as if the UTec sensed knock and yanked timing. That or the next load row had a drop in timing and the one after that had higher timing. It also has a timing issue around 5600 rpm. Looks like at least 1 degree of change going on there. I cant comment on the Power because There is no boost plots. Its possible the red line was running alot more boost.
Was this the same car retuned? The dates of the graph are way off. Its hard for me to comment on the increased low end of the Red graph as we may be dealing with different exhaust, headers, FMIC, intake ect ect ect... For example.
CLark
AZScoobie is offline   Reply With Quote
Old 08-27-2007, 03:48 PM   #3
wuuusaa
Member#: 92894
2015 Wrx
besides for increasing the boost is the map slighty the similar to the ecutek?
is that on pump?
Old 08-27-2007, 03:53 PM   #4
IMPORTEDCARS
Member#: 56945
08 STI Base Model
CLark
Same hardware Clark, the red graph has a dip NOT b/c its knocking, we were dialing in the factory boost solenoid. Yes it shows abit rich on top, its may have been running abit warm on the IAT'S. On the road boost was set with 0 knock! the boost setting does not exceed 19 psi (1.3) bar. On the road AFR"S were 11.0-11.3 @ the very most.
-George
Old 08-27-2007, 03:54 PM   #5
IMPORTEDCARS
Member#: 56945
08 STI Base Model
is that on pump?
Both on 93 Octane.
-George
Old 08-27-2007, 03:58 PM   #6
uncle lewie wrx
Member#: 78066
Ooops mis-read post.
uncle lewie wrx is offline   Reply With Quote
Old 08-27-2007, 04:01 PM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Maybe the extra fuel in the red graph cooled the cylinder temps down to where you could run more boost.
Ok, just joking. I have no idea.
wcbjr is offline   Reply With Quote
Old 08-27-2007, 04:06 PM   #8
IMPORTEDCARS
Member#: 56945
08 STI Base Model
The graph with more power is 19 PSI (Ecutek tuned)
The graph with less power is 22 PSI (Utec tuned MBC)
-George
Old 08-27-2007, 04:08 PM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
What MY engine / boost control?
Care to show the boost plot?
Old 08-27-2007, 04:15 PM   #10
nmyeti
Member#: 4980
-George
Since the UTEC tune was so lean it's likely that a lot of timing was sacrificed to keep it from knocking.
How exactly do you expect to compare one poorly tuned result to another poorly tuned result when almost every single variable on the car changes? For what purpose would you solicit comments on either state of tune when both of them show that they are really poorly done?
I canít think of any other reason to post these graphs ďin comparisonĒ other than to try to either pump up your chest because you made more power with less boost, or to attempt to sell one engine management solution over another. The truth is, in the hands of someone reasonably competent (not to imply that anyone in particular is competent or not) the two solutions will provide almost identical results (to within margin of error of the measurement device).
To imply otherwise is foolish.
Since opinions were asked for, Iíll give mine. Both of those graphs are so poor Iíd be embarrassed to let a customer leave the shop with them.
nmyeti is offline   Reply With Quote
Old 08-27-2007, 04:20 PM   #11
fast_lgt
Member#: 151278
You cant put something like this up without LOGS. POST UP DATA LOGS OF EACH ONE!
fast_lgt is offline   Reply With Quote
Old 08-27-2007, 04:24 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
This comment suggests that these plots dont represent the final "dialed in" tunes. Then why post them?
Old 08-27-2007, 04:34 PM   #13
IMPORTEDCARS
Member#: 56945
08 STI Base Model
There is no reason to pump up any chests.... we were comparing 2 different graph's thats all. No harm here.
-George
Old 08-27-2007, 04:37 PM   #14
IMPORTEDCARS
Member#: 56945
08 STI Base Model
The Utec is sold, the data logs are up to the tuner to posts.
-George
Old 08-27-2007, 04:48 PM   #15
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
So we are comparing two really bad tunes. Are you asking what one wouldnt blow the car?
JMK508 is offline   Reply With Quote
Old 08-27-2007, 04:53 PM   #16
nmyeti
Member#: 4980
-George
What's the usefulness of the comparison?
I see it now, doe eyed customer leaves your shop with huge warm fuzzy because you made more power on less boost with a richer AFR. While that warm fuzzy is useful for the customer at the moment to feed their speed fix, it is far more useful in making the customer feel better the extra money that has been separated from their wallet because they were sold an EMS that they really didnít need in the first place. While the results they were achieved on the new EMS are nicer, they are still rather poor and there is little point in comparing them to anything other than a work in progress. For the customerís sake, I hope youíre still in the process of tuning this one.
Old 08-27-2007, 05:12 PM   #17
IMPORTEDCARS
Member#: 56945
08 STI Base Model
You have it all wrong, really wrong! im done here b/c of your false assumptions and accusations. If you want get a hold of me off line to furthur discuss this, there is much more to discuss.
-George
Old 08-27-2007, 05:13 PM   #18
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
All dyno charts that I have ever seen had the hp and tq curves cross each other at 5252rpm, why doesn't this one?
This is a strange tune lol.
akira02rex is offline   Reply With Quote
Old 08-27-2007, 05:16 PM   #19
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
they dont cross because of the scaling used.. hp side goes to 350 tq to 400
PaulRex is offline   Reply With Quote
Old 08-27-2007, 05:18 PM   #20
HP ADDICT
Member#: 121366
06 STI
Different scaling of the TQ and HP #s
HP ADDICT is offline   Reply With Quote
Old 08-27-2007, 08:36 PM   #21
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Using this graph since this was his FINAL tune with the utec would be fair... Its run 12 in Jason's folder if you want to over lay it .. 12 pulls from baseline to tuned...
http://forums.nasioc.com/forums/show....php?t=1332699 Same STI limited from this post
http://forums.nasioc.com/forums/show....php?t=1238306
Im pretty sure this is Jason's car... Never ran 22psi on it... especially since it was catted and was always run on PG.. plus he AUTO-CROSSED it. I didn't want to set him up for disaster. .. The map sensor fuel cut was set to 20.5psi MAX and the table was scaled accordingly. Its weird that the car was fine for 4 months and then became so lean... If you look at both the graphs you can see how the power band was relatively smooth even with SMOOTHING SET TO 0 Its very odd that with hotter weather the car would get Leaner as well.. Also the spool or just general look of the curve is very different. Maybe since the UTEC Delta sits on the glove box the MAP was "accidently" changed... Quite a few things could have happened... All that matters is that Jason is happy with the car..
Junior2JZ is offline   Reply With Quote
Old 08-27-2007, 08:42 PM   #22
AZScoobie
Member#: 8785
netcom.com
As I said. Something changed... Thanks for posting that Graph JR. Thats more like it. Nathan. Good to hear from you man. Hope you are doing well.
Clark
Old 08-27-2007, 10:58 PM   #23
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Originally Posted by Junior2JZ;19184929Using this graph since this was his [B
FINAL[/b] tune with the utec would be fair... Its run 12 in Jason's folder if you want to over lay it .. 12 pulls from baseline to tuned...
Good idea - I will post up some graphs later
It is interesting to imagine what could have happend to make the car so lean as if the map switch was changed one would think it would revert rich to a stock map and not lean unless some other maps were on the UTEC?
Anyway - graphs to follow
Dyno Flash is offline   Reply With Quote
Old 08-27-2007, 11:09 PM   #24
GhoSTI
Member#: 86488
2004 STi
In the past I have been guilty of also taking shots at fellow tuners.
However, I have learned that just worrying about my own work is better for business and a more classy approach.
Al
LOL...
GhoSTI is offline   Reply With Quote
Old 08-27-2007, 11:24 PM   #25
Zumble
Member#: 34860
2005 Forester CGM
*grabs popcorn*
Zumble is offline   Reply With Quote
cobb vs utec vs ecutek ridexstraight AccessPort 5 11-07-2008 02:54 PM
Advantages of MBC/EBC with vf39/ecutek tune? Blown95ImpalaSS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-19-2006 06:20 PM
Ap Vs. Utec Vs. Ecutek njskatchmo Engine Management & Tuning 8 05-04-2006 09:38 AM
Vishnu XEDE vs. ECUTEK vs. UTEC stihopeful Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 04-15-2004 04:58 PM
19 psi on stock turbo??? - Tuning Gurus what gives??? meisnerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 10-03-2003 07:21 AM
