Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 08-27-2007, 04:49 PM   #1
javastiwagon24
Member#: 144372
0407 STIwag & 01 STI
Rotated!Widebodied!RaLLY
Default Check this Vid out, Whacky Boost Problem
So i got done with my hybrid swap everything runs great! only thing is i cant seem to run any boost over .05 7lbs? So i didnt care until i got the car tuned by sense of nature near Chi town, Thanks rob, we tuned it with the tactrix and increased the amount of boost to 19 lbs, we took it for a ride and couldn;t get any boost over 7, went back checked things out thought it maybe a vacuum line took the little pill restrictor out and took for another ride, no go, got home put a different tdo4 in and tried it no go, then i put a blitz ele, boost controller, yeah i had boost but know had other problems, so check this vid out and tell me what you think.
http://s195.photobucket.com/albums/z...t=HPIM0629.flv
and this one
http://s195.photobucket.com/albums/z...t=HPIM0628.flv
thanks for any and all help!
javastiwagon24 is offline   Reply With Quote
Old 08-27-2007, 05:26 PM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
What all was done recently to the car? It kinda looks like a problem I was having to my aftermarket EJ18 turbo setup. In that case the spark plugs I was using were NA plugs, an the turbo once it was getting to around 5psi, the pressures/turbulence in the cylinder was blowing out the spark. So I gapped it down to WRX gap and I was good.
ai42 is offline   Reply With Quote
Old 08-27-2007, 07:23 PM   #3
javastiwagon24
Member#: 144372
I have basic stage 2 +++ up, turboB, protuned with tactrix, grimm spacers, intercooler, 2.5 with wrx heads, custom pistons, 100mm, if Im using sti block with wrx heads should i gap plugs to sti spec, is there a diff? ill check that, thanks.
Old 08-28-2007, 04:02 PM   #4
javastiwagon24
Member#: 144372
any help anybody else, please, do u think that the tactrix tune with uped 19lbs has anything to do with this,
Old 08-30-2007, 06:09 PM   #5
javastiwagon24
Member#: 144372
Default Huhuhu!!!!!!!
come on anybody with the same problem EVER!
Old 08-31-2007, 10:57 AM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
If your tune *was* running at 19psi, and then started running at ~7psi, the first thing I would look at is the IAM. The computer will stop trying to control boost (limiting you to wastegate pressure) if it has seen a lot of knock.
The "bouncing boost" issue that started after the aftermarket boost controller was installed are likely related to that controller... bad plumbing, bad settings?
x99percent is offline   Reply With Quote
Old 08-31-2007, 12:09 PM   #7
MATT0404
Member#: 85765
I had a similar problem with my old WRX when I installed a Greddy Profec B. I could never figure out how to use all of the settings on that thing and ran into the boost fluctuation that you seem to be experiencing. How did I remedy the problem? I took the Profec out and got the car tuned.
MATT0404 is offline   Reply With Quote
Old 08-31-2007, 03:33 PM   #8
javastiwagon24
Member#: 144372
my car is tuned, we changed the factory wastegate duty cycle to 19lbs, but even with that said and the stock electric solenoid i can only reach 7lbs, the blitz is the only way i can get more that 7lbs. i was going to try a manual controller to see if i had fluctuation or not, but cant seem to find it.
Old 08-31-2007, 03:35 PM   #9
javastiwagon24
Member#: 144372
x99 whats iam,
Old 08-31-2007, 03:37 PM   #10
javastiwagon24
Member#: 144372
it was tuned at 19lbs but first run we could only run 7lbs, and then tryed the blitz
Old 08-31-2007, 04:10 PM   #11
x99percent
Member#: 27108
2004 STi
2004 A4
Originally Posted by javastiwagon24 View Post
x99 whats iam,
Ignition Advance Multiplier, sometimes called Dynamic Advance Multiplier. Check it with DeltaDash or one of the free logger programs.
On your car, you want to see 16. After an ECU reset, it defaults to 8, unless you changed the default in the flash. If you're at 4 or less, then the ECU has seen lots of knock... it will disable the boost control solenoid, limiting boost to wastegate pressure (~7-8psi). I wonder if that is why you couldn't get the boost to come up before you installed the boost controller.
Old 09-01-2007, 11:58 AM   #12
javastiwagon24
Member#: 144372
thanks i will check that soon.
Old 09-01-2007, 03:11 PM   #13
modaddict
Member#: 95840
sold to a good bud
awaiting next car
isn't the second line on that gauge .1 mpa?
So those video's were taken with the greddy boost controller installed? And you're curious about the fluctuations?
IMO, it's the settings in the boost controller causing that. It looks to me like you're boosting about 17psi or so....
modaddict is offline   Reply With Quote
Old 09-01-2007, 05:37 PM   #14
javastiwagon24
Member#: 144372
okay just hooked up an air compressor and put a tee in where the controller and my gauge get pressure and the other hose went to the in port on the dbcsolenoid, i was changing setting while providing air and you can tell that the dbcs has a studery pulse when at work, kinda like ta ta ta ta ta not steady leakage, does this have anytime to due with the setting of the controller going on percents not lbs, anyways the ? still stand "WHY WITH THE STOCK SOLENOID CAN I ONLY GET .05BAR AND NO MORE,
History of the car,
Brand new motor,
ej257 with wiesco pistons 100mm
stock sti crank
stock sti rods
stock wrk heads with .006 intake and .012 exhaust
compression ration around 8.9 -9.1
grimm speed 3mm spacers,
tumbler valve deletes with rods and sensors in, "soon to be changed to stripped"
turboxs Port and polish intercooler
afe short ram intake with lid and heat sheild
Uppipe and Turboback
and stock 04 wrx ecu with custom tune by sense of nature with the tactrix cable,
Problem i see is even before i got the tune i could hit .1bar with no controller just stock equipment, but could notice it not always getting there,
Do you guys think that something could have happened before and then when i got the tune it just finished it off. Im clueless now its been 2 weeks of thinking and no result,
Only other thing i can think is that after the tune got to .1bar for 2 secs in 6 gear deep on the freeway, went back to the house and decided to take out the pill restrictor and from that point have never got to stock boost, only steady .05bar WHY!!!!!!!!!!
Old 09-01-2007, 05:43 PM   #15
javastiwagon24
Member#: 144372
i think the controller sucks, sorry blitz, but why doesnt the stock work???
Old 09-01-2007, 05:45 PM   #16
modaddict
Member#: 95840
sold to a good bud
awaiting next car
check to make sure you have power and ground to the solenoid. Also make sure it is plumbed right with the hoses.
Old 09-01-2007, 07:11 PM   #17
javastiwagon24
Member#: 144372
Dont get me wrong the controller does work it just doesnt work to my satisfaction, like the video shows it gets to what ever boost i want 1-20+lbs its just that when it gets there it starts to boob, i should think that a good controller would have a nice smooth valve, not a sputery popping effect like im getting right now, But the question at hand is why doesnt the stock solenoid go to 19lbs like we had it set with the tactrix. only gets to .05 like the solenoid is always closed, giving the car only wastegate pressure and always opening it at .05bar. GAY!!
Old 09-02-2007, 01:27 AM   #18
x99percent
Member#: 27108
2004 STi
2004 A4
..... Have you checked the IAM ?
Old 09-02-2007, 06:25 AM   #19
p1prodrive
Member#: 149827
2000 600 bhp p1
sonic blue
deffinately running actuator boost there
p1prodrive is offline   Reply With Quote
Old 09-02-2007, 05:17 PM   #20
Momsfavorite
Member#: 135584
With my AVC-R the boost will fluctuate if the solenoid duty is set to high.
Momsfavorite is offline   Reply With Quote
Old 09-11-2007, 06:13 PM   #21
wrxzzz
Member#: 137105
did you try putting the restrictor pill back in the vacume line? It should even out the preasure being sensed by your boost controler. I think so anyway. It's been a while since I had my solenoid, turbo ect apart. If your boost controler is made to work with the restrictor then I would use it.
wrxzzz is offline   Reply With Quote
Check this vid out Subarau Brumbie fastlanerex General Community 6 04-19-2008 10:13 PM
Check this vid out!! dsmkid95 Mid West Subaru Owners Club Forum -- MWSOC 6 03-20-2007 12:14 AM
Check this vid out! allsubaru83 General Community 5 03-16-2005 07:00 PM
wow... check this vid SilentBob Off-Topic 21 05-01-2004 12:07 PM
Chromed out Mercedes. Check this thing out. Bling... Eric SS Off-Topic 48 01-07-2004 08:02 PM
