Old 08-27-2007, 04:49 PM   #1
fastlanerex
Member#: 133391
2004 boosted saleen
white
Default hybrid question
Okay my motor and heads have 80k on them is that too many miles to reuse my stock wrx heads with a 2.5 shortblock? And I know there are threads everywhere but how much am i looking at spending for everything I need?
fastlanerex is offline   Reply With Quote
Old 08-27-2007, 08:29 PM   #2
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
depends on the condition. i did the swap at 60k and my cars been fine (knock on wood) as far as what you are spending, it depends on used or new parts. to get it running good, you'll need:
OEM gasket set
fuel pump
pink injectors
tuning (i use accessport, and can get you a similar map so you dont have to pay a million dollars for tuning)
i probably forgot something but thats all i can think of
i would recommend a turbo upgrade. the td04 will lose power fairly quick vf 39 will spool up pretty fast and maintain boost a lot better. of course, you should do a IC upgrade, and exhaust, at some point (and a new tranny )
let me know if you need anything else
Le Saboteur is offline   Reply With Quote
Old 08-28-2007, 05:40 PM   #3
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
Your heads should be good as long as there is no damage to them internally. Make sure to get your heads machined and you might want to look into upgrading your cams.
MindzeyeWRX02 is offline   Reply With Quote
hybrid question (not hg or cam questions btw) AWDWRXLOVER Built Motor Discussion 7 05-11-2009 03:53 PM
To tune.. or not to tune. EJ25 hybrid question FederalAuditor Engine Management & Tuning 5 02-09-2006 12:55 PM
Cam, head, hybrid questions... 2000wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-13-2005 01:44 PM
sti hybrid questions?? werkInProgress Subaru Conversions 2 05-29-2005 10:14 PM
ej257 hybrid question! scoobyimpreza Pre-2002 Factory Turbo Powertrain 19 02-07-2005 02:51 PM
