Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Private Classifieds
Old 08-27-2007, 11:05 PM   #1
chudlo
Member Sales Rating: (17)
Member#: 15505
2002 JDMV8 STI Wagon
Default FS: ATX Misc. stuff....
I have a lot of various things left over from doing a complete drivetrain swap on my wagon. Most of the stuff I have came off of my 02 wrx wagon. Some parts are sedan specific and will be labeled as such.
All of this stuff was in another thread but I want to start over so I can get my garage cleaned out. All prices are negotiable and shipping will be paid by the buyer. All parts are located in ATX 78702 except where noted.
"??" means I don't know if I still have it. There are some things that I had but can't find yet due to the move to Austin.
Brakes/Tires/Suspension:
2 Kumho MX tires(less than 50% tread) unmounted
02 WRX wagon driver side control arm w/ Power flex front bushings, rear mount and ball joint $65
02 WRX rear swaybar mounts $10
02 WRX wagon front swaybar $30 ??
02 WRX wagon rear strut assy. $35 each
04 STi front hard brake lines $30 each ??
04 JDM STi front and rear brake lines (new) $25 set ??
STi front control arm mounts (new) $50 each ??
04 STi rear swaybar Sold??? I don't think that I have this now.
02 JDM 19 mm STi fron swaybar $30??
02 WRX wagon rear hubs w/ parking brake cables Sold each
02 WRX steering rack w/ tie rod endssold
04 JDM STi front swaybar w/ endlinks SOLD
04 JDM STi rear swaybar SOLD
WRX rear brake calipers SOLD
04 JDM STi V8 front/rear springs gone
Electronics/Electrical...:
Rallispec DCCD kit w/ ECU, wiring, thumbwheel and instructions $450
MRT EBC $25 (unsure if working properly)
WRX Rear O2 sensor x2 $35 each
WRX DRL module x2 $10 each
Misc...:
02 WRX I/C splitter w/ seal $25 (I had to cut the seal down some to fit a big TMIC.)
02 WRX I/C with Y pipe $75
02 WRX I/C brackets $20
02 WRX charcoal canister $35
02 WRX reservoir coolant tank $20
02 WRX assy belt cover $10 ??
02 WRX hood scoop- black $25
02 WRX 5-speed shifter $25
Ti shift knob, 5 speed $70
Engine/Exhaust/Drivetrain:
02 WRX stock uppipe , downpipe, mid w/ resonator, intermediate pipe and muffler $25 each section
02 WRX driveshaft $20
02 WRX EJ205 oil pump $20
02 WRX EJ205 water pump $15
04 JDM STi V8 twin scroll bulkhead wiring harness (engine bay, exterior fuse box, etc - NO engine harness. This was cut at the firewall. I removed 2 wires from the harness to wire the DCCD plug.) $350 (Not sure where this is, still looking)
04 JDM STi V8 twin scroll wiring harness with ECU plugs. ( Ijust found this one unpacking!) make offer
02 WRX wagon front axles $50 each
02 WRX EJ205 oil pan $20
02 WRX rear subframe $25
02 WRX fuel pump $25
02 WRX Tranny cross member $10
02 WRX EJ205 Heads w/ cams and coverssold
02 WRX EJ205 cam gears R. intake, L intake and exhaust sold each ( missing at least one cam gear)
02 WRX EJ205 timing belt pulleys sold
TONS of misc. hoses and bolts, etc- inquire for details
Note: No body parts(except for the hoodscoop) or interior pieces.
Thanks,
chud
Last edited by chudlo; 02-24-2008 at 11:27 PM. Reason: Updates...price changes..cleaned up a bit....
chudlo is offline   Reply With Quote
Old 08-27-2007, 11:08 PM   #2
chudlo
Member#: 15505
Pictures can be found here.
Sorry about the unorganized pics, I was trying to get them out quickly.
Edit: I don't think I have that a/c compressor in the last pic anymore.
Old 08-27-2007, 11:47 PM   #3
KnightWRX
Member Sales Rating: (4)
Member#: 41664
black
"04 or 03 WRX STi A/C pump $50 ??
02 WRX fuel pump $25"
So your saying you dont have that A/C pump? If you do though, will the 03-04 pumps work on the 02 wrx's?
and also, how many miles were on that fuel pump?
Michael
KnightWRX is offline   Reply With Quote
Old 08-27-2007, 11:52 PM   #4
chudlo
Member#: 15505
Michael
I had both a wrx and an STi a/c compressor at one time. I will try to look for one of them tonight.
The fuel pump has about 82k miles on it. That is when I blew the motor.
Old 08-30-2007, 02:26 AM   #5
sti04j
Member Sales Rating: (1)
Member#: 124433
2004 STI
wrb
size one the rims?
sti04j is offline   Reply With Quote
Old 08-30-2007, 02:29 AM   #6
chudlo
Member#: 15505
Originally Posted by sti04j View Post
size one the rims?
The rims are Subaru OEM 02 wrx 16"x6.5".
Old 08-30-2007, 01:17 PM   #7
unloco187
Member Sales Rating: (10)
Member#: 98467
2002 wrx
hey man if the front axles will work on my 2002 wrx, I need one. Let me know.
unloco187 is offline   Reply With Quote
Old 08-30-2007, 03:20 PM   #8
chudlo
Member#: 15505
They were taken off my 02 wrx, so....should be good.
The only thing we have to check is if they are wagon axles or not. There is not much difference in length, if any. You can come check them out if you like.
Old 08-31-2007, 06:50 PM   #9
chudlo
Member#: 15505
bump.........
Old 09-13-2007, 09:58 PM   #10
HOLLYW00D
Member Sales Rating: (9)
Member#: 44954
2004 FXT
still have the gutted uppipe? where abouts in austin are you?
HOLLYW00D is offline   Reply With Quote
Old 09-13-2007, 10:07 PM   #11
chudlo
Member#: 15505
Yes.
I am 2 miles East of the Capitol.
Old 09-13-2007, 11:29 PM   #12
HOLLYW00D
Member#: 44954
2004 FXT
pm'd you
Old 10-14-2007, 11:06 PM   #13
chudlo
Member#: 15505
Buythisandputitonyourcarbump.
Old 10-16-2007, 05:12 PM   #14
Selmak
Member Sales Rating: (11)
Member#: 45751
2015 WRX
Dark Grey Metallic
Will that work on a 04 WRX? What's the difference between that and what comes with the wrx?
Selmak is offline   Reply With Quote
Old 10-16-2007, 05:45 PM   #15
chudlo
Member#: 15505
The STi has a different abs pump that might locate the lines in a different place than a wrx.
It should be the same, but you will want to confirm that independently.
Old 10-16-2007, 06:28 PM   #16
imma_stocker
Member Sales Rating: (23)
Member#: 97043
08 STI
02 Z28 - project
Have a radiator that will drop in an 02 MT WRX? Preferably with the top brackets
imma_stocker is offline   Reply With Quote
Old 10-16-2007, 07:44 PM   #17
chudlo
Member#: 15505
Sorry, but I traded the stock radiator for Ti JDM shift knob.
Old 11-26-2007, 04:17 PM   #18
Gilla-Machster
Member#: 24740
Head donkey meat
distributor in USA
PM sent about the heater core.
Gilla-Machster is offline   Reply With Quote
Old 11-26-2007, 06:28 PM   #19
ovedrivex
Member Sales Rating: (15)
Member#: 116774
1997 Project GC8
in addition to the pm i also need som other random bolts... i one of the long bolts that hold down the tgv . i also need the two bolts that hold the pwr steering pump bracket on the front of the block(i think they are the 12mm with the 8. not the 14mm with the 8). also need 4 inner timing cover bolts(the short ones with the rubber/metal washers on them) also on the back of the block between the flywheel mount and the large metal plate theres a plug there i need that too... its amazing what disapears when your block just sits there for a year.
ovedrivex is offline   Reply With Quote
Old 11-26-2007, 10:15 PM   #20
chudlo
Member#: 15505
I sold the block some time ago. I am not sure if I stripped off any of the items that you are looking for.
Are you near Austin by any chance? It might be easiest for you to look through the extra bolts I have rather than me try to find them.
Old 11-27-2007, 04:28 AM   #21
ovedrivex
Member#: 116774
1997 Project GC8
nope. im in houston. the bolts i pmed you about are the only ones that i really need since they are subaru specific bolts/adapters. im not to keen on paying 90bux for two bolt/adapters.
Old 11-27-2007, 08:12 AM   #22
chudlo
Member#: 15505
Well, maybe I can take a pic of some of the stuff. Perhaps that would help.?
Old 11-28-2007, 01:19 AM   #23
ovedrivex
Member#: 116774
1997 Project GC8
its ok. not unless you think you have the crank shaft sensor adapter and the oil cooler adapter. i just figured id ask about the other bolts just incase you had those two. i can get the regular bolts from autozone or something. im thinking of making my own adapters...90bux is ridiculous for just 2 adapters.
Old 12-02-2007, 08:57 PM   #24
djburn1200
Member#: 54081
2003 WRX
MBP
Pm'ed
djburn1200 is offline   Reply With Quote
Old 12-03-2007, 01:03 AM   #25
chudlo
Member#: 15505
^^^PM returned....
FS: CT misc stuff Skala21 NESIC Private Classifieds 25 06-08-2008 01:01 PM
FS: NH, misc stuff SoonerOrLater NESIC Private Classifieds 11 12-12-2006 09:52 AM
FS: Lotsa misc stuff, oem and aftermarket Elwood MWSOC Private Classifieds 14 03-20-2006 10:56 PM
FS: Local Misc stuff for WRX and testing waters for TBE Sisqocqk Bay Area Impreza Club Forum -- BAIC 6 10-01-2003 01:38 AM
