Old 08-28-2007, 11:04 AM   #1
rogue
Super Moderator
Member#: 7977
100% Abuse
Question Torque spec for cam cap bolts?
Arg!
I'm reassembling an old EJ25 DOHC, and have all the specs for head bolts and timing belt and such... but I'm missing the torque spec for the cam cap bolts (small bolts that hold the cam shafts in place on the heads, 6 per cam)
Anyone? Theory is 7-11 ft-lbs.
Thanks!
rogue is offline   Reply With Quote
Old 08-28-2007, 11:20 AM   #2
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
EDIT!!!
7.0 ft/lbs for the two bolts near the belts. It's 14 ft/lbs for the 4 bolts towards the car body. The order is middle two bolts, front-most bolts, then rear-most bolts. See below and remember to tighten them in at least 2 stages.
G C L
E A K
F B J
H D I
conker69 is offline   Reply With Quote
Old 08-28-2007, 12:15 PM   #3
rogue
Super Moderator
Member#: 7977
100% Abuse
Originally Posted by conker69 View Post
7.0 ft/lbs.
I assume you know they should be tightened in two stages and in a specific order??
I guessed as much...
Any info on the order? Just rotating around like the head bolts?
I don't see why it would matter too much what order they're done in, since it's three separate cam caps being held down. Not like with the head when you have one giant mating surface.
Old 08-28-2007, 12:46 PM   #4
avk
Member#: 17252
'06 WX8
59E
For 2.5 I only have what's in the Haynes manual.
According to it, the tightening sequence is
5 1 3
6 2 4
for each of the camshafts.
Left is front.
avk is offline   Reply With Quote
Old 08-28-2007, 12:49 PM   #5
rogue
Super Moderator
Member#: 7977
100% Abuse
5 1 3
6 2 4
Left is front.
So pretty much like the head. Thanks, I appreciate it guys!
Old 08-28-2007, 01:05 PM   #6
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
WAIT!!!
Just did it on mine.
The front caps, behind the cam gears are only 84-96IN lbs, and the middle and rear are just over 120in lbs, or 10 - 11ft lbs.
Kinda wierd but that what SOA recommends.
fishheadback is offline   Reply With Quote
Old 08-28-2007, 01:15 PM   #7
rogue
Super Moderator
Member#: 7977
100% Abuse
Originally Posted by fishheadback View Post
WAIT!!!
Okay, I'm not surprised to hear that... speculation was the fronts were different because of the cam seals.
Though really, the difference between 90 in-lbs and 120 in-lbs is pretty darn small. But I'll keep that in mind, thanks.
Old 08-28-2007, 03:26 PM   #8
conker69
Member#: 59692
WRB-Gold
CHECK MY EDITS!!!!
Sorry.
Old 08-28-2007, 04:01 PM   #9
rogue
Super Moderator
Member#: 7977
100% Abuse
CHECK MY EDITS!!!!
Sorry.
Got it!
Thanks a lot, I appreciate the level of effort you guys put in. I will follow the instructions diligently (breaks out in-lb torque wrench)
However, for the sake of argument, I'd guess that doing about 90 in-lbs all around in any random order would PROBABLY work fine. These are very small forces at play. Not that I want to be the guy to test it.
Old 08-28-2007, 06:51 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
How old is old? The 96 EJ25D uses smaller bolts and a lower tq value than the later EJ25D. The smaller bolts are very prone to stretching as well. Check yours before you put them back in to make sure they aren't stretched or they won't hold correct tq (if they even make it there).
Just a heads up!
Jay
Torque specs for Cosworth rod bolts for EJ25? Navid Built Motor Discussion 0 10-20-2007 10:57 PM
torque specs for ic bracket bolts on driver side? Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-12-2004 08:57 PM
Torque spec for uppipe/exhaust bolts? b16bpower Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-27-2002 10:02 PM
WRX Torque Specs for Exhaust Header Bolts Neil Wallerstein Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-30-2001 01:48 PM
need torque specs for brake caliper bolts, please Lou Technical Forum Archive 2 07-24-2000 04:52 PM
