08-28-2007, 11:33 AM | #1 |
Member#: 123143
SWIC
Vehicle:03 wrx 08 forester 98civic k24/k20 02 Rsx |
Thinkin of geting the hydra
hey all dont really post alot in here but i got A question ill list mods i think its my STOCK ECU.
2.5 Sti Sb W/WRX heads TurboXs FMIC Perrin GT30 Kit Agency power fuelrails(they suck VIVID RACING FTL) Deatschwerks 850cc's STOCK ECU the car is hesitant alot it sucks for reg driving i think this may be because of the injector size on the 2.0L ECU ,also do most of you use a catch can in ur subaru's well you guys that really need catch cans cuz i lost some oil about 1/2 quart and i dont think i burned it off also which hydra would i need for my motor im not running forged pistons its high compression with that wrx head
08-28-2007, 12:27 PM | #2 |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
Do you not currently have any sort of EM (engine management) or a flash or tuning done on the ECU? The stock ECU cannot deal with that large of injectors and any EM will be a HUGE help to stop you from ruining your motor, if that is the case.
offset |
08-28-2007, 02:07 PM | #3 |
Member#: 123143
SWIC
the ecu is tuned with that open ecu or whatever
09-04-2007, 01:27 PM | #4 |
Member#: 135686
NESIC
Either find another tuner or have your current one fix the tune. The car should drive like stock. A Hydra will only make your life a nightmare. The factory ECU does a great job if it is set up correctly, even with a big MAF and injectors.
09-04-2007, 03:09 PM | #5 |
Member#: 32636
09-04-2007, 03:32 PM | #6 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
I can say there are definitely some tuning issues with the Perrin BigMAF that comes with the Perrin rotated kits. But if the tuner knows what to do, it can easily be tuned around. Your other option is to get rid of the BigMAF and go with a blow through setup.
As for getting the Hydra, it's not a necessity with your setup. There are some issues with the Hydra that if you don't have a competent Hydra tuner in your area, you will fumble through them and get frustrated. For example, I haven't been able to get my car to consistently come to an idle without stalling out. Tim Bailey came into town this past weekend, adjusted one setting (which I'm almost positive Phil told me not to mess with as it's for the throttle by cable cars) and my car holds an idle no matter how much I try to make it stall out. I am also still having some very low throttle (<10***37; TPS) bucking because the AFR's are in the 16:1 range. But if I richen it up to fix the problem, then my off throttle AFR is like 15:1 instead of 18:1 to 20:1 and the car doesn't decelerate. But I'm slowly working through them. For someone that does not understand the tuning concept, the Hydra is not for that person. |
09-05-2007, 10:48 AM | #7 | |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
Thanks, Phil www.elmenettuning.com |
09-06-2007, 10:10 AM | #8 |
Member#: 113734
South East
Vehicle:2023 FL5 Type R Subaruless |
I hope you upgraded your Tranny too, +1 for a Hydra
type of sensor the hydra uses for wideband | traction issuez | Other Engine Management | 1 | 06-05-2006 05:56 PM |
Thinkin of an STi spoiler for the RX | Caboobaroo | Interior & Exterior Modification | 19 | 03-15-2006 05:39 PM |
thinkin of sellin my gc8 | brokemypiston | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 05-03-2004 04:13 PM |
New, thinkin of getting Impreza RS pre 2002 body style, help | FlatEngines | Newbies & FAQs | 16 | 09-02-2002 03:24 AM |
Thinkin of sellin my baby | Jebulan Pike | Rocky Mountains Impreza Club Forum -- RMIC | 2 | 10-11-2001 06:17 PM |
