Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 08-28-2007, 02:05 PM   #1
recruitX
Member#: 151838
02 WRX
Default Not reaching target (stock boost)
I hooked up my tactrix cable up to my car yesterday and did a pull thrue 2nd gear and noticed that I was not going over 7.2 manifold pressure (boost pressure). Could this be a boost leak somewhere? The previous owner put on a after market solid up pipe. Or should I try pulling in higher gears?
recruitX is offline   Reply With Quote
Old 08-28-2007, 02:28 PM   #2
javastiwagon24
Member#: 144372
0407 STIwag & 01 STI
Rotated!Widebodied!RaLLY
i have the same problem, reflashed with the tactrix last wednesday and set the stock solenoid to 19lbs took it for a run and couldn't get over .05 bar just like you i wish somebody new about this, i have a 04 wag with hybrid motor, up , turboback, intercooler and others seems like you have about the same, tune feels great just cant get the boost up, i hooked up the blitz controller and was able to make more boost except when i got to 16-18 lbs the needle on the gauge started to bob. check this out,
http://s195.photobucket.com/albums/z...t=HPIM0629.flv
http://s195.photobucket.com/albums/z...t=HPIM0628.flv
javastiwagon24 is offline   Reply With Quote
Old 08-28-2007, 02:44 PM   #3
mike_ross05
Member#: 145957
You won't hit full boost until 4th or 5th gear. Make a highway run and see what you hit.
mike_ross05 is offline   Reply With Quote
Old 08-28-2007, 05:03 PM   #4
Zumble
Member#: 34860
2005 Forester CGM
You should be able to get over 7psi in any gear. I can hit 18psi in 1st.
Zumble is offline   Reply With Quote
Old 08-28-2007, 06:13 PM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
Um....
Nuke209 is offline   Reply With Quote
Old 08-28-2007, 07:23 PM   #6
recruitX
Member#: 151838
02 WRX
Question
um..... Can someone confirm what a stock 02 wrx should be boosting in each gear.
Old 08-28-2007, 08:47 PM   #7
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
depending on weather and set up reaching 14 lbs in 1 st is tough--stock set up test would be 3rd-if you are not hitting 14 on a stock car and a stock map--check leaks and also check the pill inside the hose going to the compressor housing. 1.2mm-lately i have been seeing the stk boost solenoids going bad.on the bugeyes
dave
PerformanceAutoSolutions is offline   Reply With Quote
Old 08-29-2007, 08:27 PM   #8
recruitX
Member#: 151838
02 WRX
Tried third today but Im still seeing a peak of around 7.2 psi. Im going to log to a file today and post it up... Also does anyone have a link to the explanation of the Subaru turbo system components (valve, ect...)
Also could this be caused by a leak in the uppipe?
FP16g not reaching target boost wrxaru02 AccessPort 0 06-28-2009 11:59 AM
Not Reaching Target Boost! (02 wrx GM stg 2) **Logs attached recruitX Open Source Reflashes 11 10-08-2008 10:32 PM
Not reaching target (stock boost) recruitX Commercial ECU Reflashes 18 09-10-2007 12:00 PM
Not reaching target boost... crashtke AccessPort 36 08-22-2006 10:27 PM
Not Reaching Target Boost Mr. Mercado Engine Management & Tuning 12 03-23-2005 10:13 AM
