Old 08-28-2007, 07:29 PM   #1
system60
Member#: 97604
05 LGT WGN 5spd
Default Might be a dumb question about Tq curves
Is there any explanation why pretty much every Subaru dyno i've seen there is always a tq peak and it starts dropping down.(I can understand this w/ a small turbo but even the graph on here for TopSpeed w/ a 4094 it does it) While there will eventually be a plateau in the hp curve ?
Just about any other car its the opposite. Its almost like if you flip over a subaru dyno and mark the tq as hp and hp as tq is what most dynos for other cars look like.
system60 is offline   Reply With Quote
Old 08-28-2007, 10:39 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
simply put, volumetric efficiencies start falling off...as boost is a big drive in this department generally peak boost will see the peak VE... VE= volume actual/ volume theoretical...
Old 08-28-2007, 11:05 PM   #3
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default Cams...
I think cams (VE I know), but the profile design plays a big factor in this. Stock cams generally breath well in the low/mid range it seems.
BlackEyeII is offline   Reply With Quote
Old 08-28-2007, 11:19 PM   #4
gold rush
Member#: 90110
2004 wrx wagon
The tq curve on my version 8 ej207 is pretty flat, and not the typical subaru peak. It stays pretty much flat from 4900 to 7000 rpm. Must have to do with how the head was designed to flow, JDM ver 8 heads have bigger ports than USDM heads.
gold rush is offline   Reply With Quote
Old 08-29-2007, 12:50 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
well, that, the rod ratio, equal length manifold and a twinscroll turbo.
Old 08-29-2007, 04:51 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
because of the horizintally opposed layout, the intake and exhaust runner lengths are longer than those seen in any other small displacement, high revving, inline engine.
as a result the VE peak of a subaru engine is relatively low in the RPM range with respect to redline, and that makes the dropoff of torque more noticeable when plotted out all the way up.
Might be a dumb question but ImprezaWRX02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-12-2004 02:45 AM
might be a dumb question, but... wrxmania Texas Impreza Club Forum -- TXIC 9 03-12-2004 12:06 PM
Might be a dumb question, but what's that fan noise? volkl23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-18-2004 02:14 PM
This might be a dumb question, but . . . banman Tire & Wheel 7 11-23-2003 06:53 PM
This might be a dumb question but... akm3 Interior & Exterior Modification 5 08-28-2001 07:33 AM
