Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 08-29-2007, 07:39 AM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Head bolt torque delima. (02 Service manual)
Here's my delima.
I have completed assembling my motor but as I have in the past I used the 02 service manual. The problem lies in the head torque sequence which is apparently very different from the 03 service manual and the 03 is different from the 05 manual.
02: http://65.6.129.58/public/02WRXHeadInstallation.mht
03: http://65.6.129.58/public/2003FSM.pdf
05: http://65.6.129.58/public/2005FSM.pdf
My question is do I need to pull the engine apart and completely redo the head gaskets or can I just go tighten the bolts in order to what ever the final torque spec should be?
Does anyone know what the final torque is?
thanks
Mike
LiquidForce is offline   Reply With Quote
Old 08-29-2007, 09:45 AM   #2
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
Pretty sure there is not a final "torque"
As far as I know the last two steps are 90degree turn increments.
fishheadback is offline   Reply With Quote
Old 08-29-2007, 11:49 AM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
i understand the sequence but I was more concerned that the 02 manual says after backing off 180 twice to torque the inner bolts to 26 lbs and the outside bolts to 11. The 05 manual says to torque them all to 36 lbs. That discrepency before you start the final 90 degree turns is what has me concerned.
Since they aren't currently torqued as tight as they would be with the 05 manual I am just going to back everything off and start the whole sequence again.
My bit of advise from all this is that anyone who is using an 02 manual should throw it away and get a newer one. Along with the incorrect sequence for the headbolts it also has the wrong torque values for the front cam caps. I found that out the hard way too the first time I pulled the heads.
Old 08-29-2007, 11:55 AM   #4
5spdfrk
Member#: 46407
blew
So Mike, you're suggesting that even though I have an '02 I should follow the '05 fsm?
5spdfrk is offline   Reply With Quote
Old 08-29-2007, 12:13 PM   #5
LiquidForce
Member#: 12811
2002 2.5l Wrx
Yes. The torque sequence in the manual is the same one used for the older sohc heads. It worked fine for me in the past but I am going to be pushing closer to 500whp with my new set up and I am not comfortable with it.
Old 08-29-2007, 12:25 PM   #6
5spdfrk
Member#: 46407
blew
If you have the '05 fsm, PM me a link. Thanks.
Old 08-29-2007, 12:46 PM   #7
LiquidForce
Member#: 12811
2002 2.5l Wrx
I don't have the full manual. All I have for the 05 is the link above.
Old 08-29-2007, 01:11 PM   #8
LiquidForce
Member#: 12811
2002 2.5l Wrx
i fixed the link to the 05 page.
Old 08-31-2007, 04:47 PM   #9
THEVERGE
Member#: 127421
2002 Subaru WRX
Sorry to butt in here, but I am currently building an 02 motor and havent installed the cams yet.
What do you mean by the torque values are wrong for the cam caps? What will happen? where can i get the right ones?
Also will i run into problems using the older headbolt specs?
Thanks
THEVERGE is offline   Reply With Quote
Old 08-31-2007, 06:21 PM   #10
LiquidForce
Member#: 12811
2002 2.5l Wrx
Thanks
I snapped one of the cam cap bolts. The manual says 14 ftlbs for the front and 14 for the ones under the valve cover. The ones on the front (outside the valve cover) should only be 7 ft lbs.
I never had an issue with the headbolts using the old routine but I am certain Subabru revised it for a reason.
head bolt torque jim747 General Community 4 11-07-2005 11:15 PM
Head bolts torque turnbuckle1212 Normally Aspirated Powertrain 5 05-26-2005 11:43 AM
Head bolt torque & sequence? Andrew Bacon Normally Aspirated with bolt-on Forced Induction Powertrain 5 02-26-2004 09:47 PM
Head bolt torque and sequence on EJ25? Andrew Bacon Normally Aspirated Powertrain 0 02-24-2004 09:03 PM
I need head bolt torque asap please! Eric SS Normally Aspirated Powertrain 9 05-13-2002 12:31 AM
