Old 08-29-2007, 12:23 PM   #1
2fst4u2c
Member#: 57589
2011 WRX
A Blu Hue
Default Timing Belt
is the 3.0 the only one with the timming chain?
2fst4u2c is offline   Reply With Quote
Old 08-29-2007, 01:59 PM   #2
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
I do believe the timing belt is found on just about all the subaru models. The 3.0 probably has a chain becuase of the bigger engine (though they could've used a bigger, stronger belt I suppose).
janikphoto is offline   Reply With Quote
Old 08-29-2007, 04:21 PM   #3
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
From cars101.com: http://www.cars101.com/subaru/outback/outback2003.html
* 3.0L DOHC H-6 cylinder engine.
This engine has an aluminum crankcase, double-overhead camshafts (dohc) chain-driven with four valves per cylinder. The timing chain does NOT have a replacement schedule - suggested replacement of the rubber belt on the 2.5L 4 cyl is 105,000 miles.
The 6 cylinder uses Direct Ignition with an individual ignition coil for each cylinder so there is no distributor or sparkplug wires.
The H6-3.0 produces nearly 30 percent more horsepower and torque than the 165-horsepower 2.5-liter H-4 and is only 0.8 inches longer. Premium fuel, 91 octane, is recommended.
o 212 horsepower @ 6,000 rpm
o 210 lb.-ft. of peak torque @ 4,400 rpm
174 lb.-ft of torque @ 2,200 rpm
Huffer is offline   Reply With Quote
Old 08-29-2007, 06:37 PM   #4
brandoncrone
Member#: 152710
Yes the posts are correct, the 3.0 H6 in the Legacy is chain driven. It was done that way because there wasn't enough room in the current Legacy body at the time to fit a 6 cylinder and a timing belt. The chain cover is skinny compared to the tbelt cover.
Now the SVX on the other hand is a belt driven H6. But that is a story for a different time and thread!
brandoncrone is offline   Reply With Quote
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 12:09 AM
Question on how to inspect timing belt. Blitzkrieg Service & Maintenance 5 06-04-2010 08:11 PM
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley Kansai Subaru Service & Maintenance 14 10-23-2008 04:05 AM
FS: Gates Racing Timing Belt NEW/ PE timing belt Keo Engine/Power/Exhaust 6 07-04-2008 03:15 AM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
